GEN 3 (2022+) Wheels and Tires Photo thread
Discussion in 'Wheels & Tires' started by Tsquare, Jan 16, 2022.
  1. Oct 27, 2024 at 6:24 AM
    #5191
    ramnj
    ramnj New Member
    NJ
    ‘24 Platinum
    Made the following to my Tundra.
    Method 316 Matte Black 18x9” +18
    NITTO Ridge Grapplers 305/65-18
    ReadyLift 2" Front Leveling Kit
    No Rubbing
    Word of advice on the ReadyLift 2" Front Leveling Kit. After the kit install, I took the truck for a frontend alignment and the tech could not get the caster dialed in. Started doing some research and seems like I'm not the only one. Solutions are from finding a reputable alignment shop to adding adjustable caster bolts and many others. If the alignment problem can't be solved I'm going to remove the leveling kit and install the TRD 3" lift when Toyota releases the stop sale on the lift.
    Took the truck for a 20 mile drive and it is tracking straight and feels like there's no problems. Overall I'm happy with the way it looks but for me it has a little too much poke.
  2. Oct 27, 2024 at 1:35 PM
    #5192
    Foster1
    Foster1 New Member
    2023 TRD Off Road
    • Nitto Ridge Grapplers in 275/65R20 116T SL
    • Stock 20" TRD Off Road wheels
    • No lift, but the back is squatting in the pictures because I have 8 tires and 4 wheels in the bed.
    • No rubbing
  3. Oct 28, 2024 at 3:05 AM
    #5193
    the4rdan
    the4rdan New Member
    Pennsylvania
    2025 WCP Ltd. TRD OR CrewMax
    Looks great! Do you have a side-on pic of the truck? Curious how this size looks with the cap?
  4. Oct 28, 2024 at 11:13 AM
    #5194
    NewToTRD
    NewToTRD New Member
    Nick
    2024 Tundra TRD Pro
    Seems a little bulky for a leveling kit, but you do you.
  5. Oct 28, 2024 at 11:27 AM
    #5195
    slcsez2000
    slcsez2000 New Member
    Will 295/70/18 Nitto Recon Graps fit on stock 2024 suspension SR5 with little to no rub/trimming ?
    I have read in here a couple times it can but seems like that is from folks with TRD Pros.
    Wheels are 18x9, 12mm offset.
    I plan to lift later in a couple months
    Just wanted to drive em on stock suspension until then.
    thanks!
  6. Oct 28, 2024 at 11:43 AM
    #5196
    Foster1
    Foster1 New Member
    2023 TRD Off Road
    What leveling kit?
  7. Oct 28, 2024 at 11:49 AM
    #5197
    NewToTRD
    NewToTRD New Member
    Nick
    2024 Tundra TRD Pro
    Just making a joke about the weight in the back leveling out the truck. Joke wasn't very funny. It happens.
  8. Oct 28, 2024 at 11:50 AM
    #5198
    az 3rdGen
    az 3rdGen New Member
    Arizona
    2022 Black Tundra SR5
    it was a decent dad joke. got a laugh outta me
    NewToTRD[QUOTED] likes this.
  9. Oct 28, 2024 at 11:52 AM
    #5199
    NewToTRD
    NewToTRD New Member
    Nick
    2024 Tundra TRD Pro
    You looking at the SL ones. I'm curious about how those perform in the rain. I want a lightweight tire and am leaning towards those or the Bridgestone Dueler Ascent A/T in 295/70R18.
  10. Oct 28, 2024 at 11:58 AM
    #5200
    Foster1
    Foster1 New Member
    2023 TRD Off Road
    I see, joke flew right over my head. It is funny now that I get it. Good job.
  11. Oct 28, 2024 at 12:48 PM
    #5201
    slcsez2000
    Yup looking at those
  12. Oct 28, 2024 at 4:22 PM
    #5202
    slcsez2000
    Welp I ordered them with no lift yet
    Wheels should be here by end of week
    Hope I can drive home and not rip anything
    BoomBoomGanoom likes this.
  13. Oct 29, 2024 at 2:36 AM
    #5203
    Yotaholic4life
    Yotaholic4life New Member
    24 TRD Limited CM LB, 23 SR5 8ft bed DC
    24 TRD Lift
    I had to trim the mudguards and pin back wheel well liner to get away from the slight rub at full lock. No lift , no leveling kit !
    slcsez2000[QUOTED] likes this.
  14. Oct 29, 2024 at 2:40 AM
    #5204
    slcsez2000
    I need to read up on how folks are pinning back the wheel liner, I keep reading it but haven’t “seen it”
  15. Oct 29, 2024 at 5:05 AM
    #5205
    Yotaholic4life
    24 TRD Lift
    Its very easy ! There are existing holes for the pin clip in the steel frame . Just pop a small hole in the fabric and push the clip in and your done.
  16. Oct 29, 2024 at 7:43 AM
    #5206
    SrgJigPog
    SrgJigPog New Member
    '23 Tundra Limited Trd Off Road
    Awesome looking. Same wheels I want with the +40 offset. Hopeing they are back in stock soon.
    I had +18 316 wheels on my 19 Tundra but it was too much poke for me spending time on dirt roads.
  17. Oct 29, 2024 at 11:25 AM
    #5207
    vichmr
    vichmr New Member
    Scott
    Suwanee, GA & Highlands, NC
    '25 MGM Platinum TRD OR 6.5 w/ factory lift
    Go Rhino Dominator D6, Diamondback HD
    Toyota has a stop sale on the lift? I’ve found one expected to the dealer by Dec with the TRD Lift and am about to make an offer. Please advise though I will scour the internet for info. Thanks!
    BTW, that’s a damn fine looking truck you have!
  18. Oct 30, 2024 at 9:22 AM
    #5208
    4x4Remedy
    4x4Remedy New Member
    24 Tundra
    3” Toyota factory lift. Icon 17” wheels
    I have the factory installed 3”TRD lift. It’s great. I had Icons on my last Tundra, this is just as good so far. IMG_1782.jpg IMG_0420.jpg
    vichmr likes this.
  19. Oct 30, 2024 at 10:37 AM
    #5209
    slcsez2000
    New shoes arrived
    295/70/18 nitto recon graps SL
    18x9 offset 12mm black rhino diamondback
    not much poke
    Got the rough country sport flares ordered anyway.
    no lift (yet)
    Pinned back the liner so hope no rub
    Haven’t seen these wheels anywhere on a tundra or any vehicle before. (Fairly new)
    wheels are 27.7lbs and tires 52.49lbs (each)
    Should be only around 5-7lbs each more than stock. Was trying to keep it as close as possible.
  20. Oct 30, 2024 at 10:44 AM
    #5210
    BlackNBlu
    BlackNBlu Cranks Nickelback in Target order pickup lane
    Rich
    MN
    24 Limited CM 5.5 Blueprint TRD OR
    5100's, 285/75/18, Air Lift bags, bits and bobs
    Unique design, I like 'em.
    Any chance you know what the rims weigh? Black Rhinos always seem to be heavy-ish....
    I wish Nitto would make the new G3's in that size in a SL. so far just E's.
    (Or make the Recons in a 3PMSF....)
  21. Oct 30, 2024 at 11:41 AM
    #5211
    slcsez2000
    added more pics above
    BlackNBlu[QUOTED] likes this.
  22. Oct 30, 2024 at 11:42 AM
    #5212
    slcsez2000
    added more pics above ☝
    JTundra2009 likes this.
  23. Oct 30, 2024 at 3:53 PM
    #5213
    JTundra2009
    JTundra2009 New Member
    Nice!!!!!!
  24. Oct 30, 2024 at 6:43 PM
    #5214
    Swarley
    Swarley New Member
    Good choice, my order in matte black just arrived today.
    Crawldad[QUOTED] likes this.
  25. Oct 31, 2024 at 6:54 AM
    #5215
    Crawldad
    Crawldad New Member
    2024 Tundra Limited TRD OR w/3” Lift
    Nice, I was torn between matte black and gloss gunmetal. I had matte black Ray10’s on a Tacoma so I thought I would try something different this time. Mine were delivered yesterday also. Now I need to get a tpms for the 5th wheel.
    SCSPerformance likes this.
  26. Nov 1, 2024 at 5:59 AM
    #5216
    Oakman
    Oakman New Member
    Michigan
    I am looking for the same setup without adding leveling or lift kit, what did you end up doing? I am looking into 275/65r20 Vs 285/60r20
  27. Nov 1, 2024 at 12:07 PM
    #5217
    Foster1
    Foster1 New Member
    2023 TRD Off Road
    275/65R20 is the only one that offers non-E load tire options if that matters to you at all.
  28. Nov 1, 2024 at 1:23 PM
    #5218
    Oakman
    Oakman New Member
    Michigan
    For me it is fine, rubbing is my concern.
    Anyone knows what is the max tire diameter I can use on stock rim (R20) without running into rub, thats for 1794 TRD offroad,
  29. Nov 1, 2024 at 2:14 PM
    #5219
    ramnj
    ramnj New Member
    NJ
    ‘24 Platinum
    I’m running 305/65-18 with no rubbing.
    mayan, cartage1, SoCal_Erik and 2 others like this.
  30. Nov 4, 2024 at 12:46 PM
    #5220
    SCSPerformance
    SCSPerformance #teamstealth Vendor
    Vin
    Bay Area, CA
    Here are a few from our customers.
