GEN 3 (2022+) Wheels and Tires Photo thread
Discussion in 'Wheels & Tires' started by Tsquare, Jan 16, 2022.
  1. Aug 19, 2024 at 9:56 PM
    #5101
    ksj0823
    ksj0823 New Member
    2024 Tundra Platinum 6.5 MGM HV
    update. A post from 4Gen Tacoma forum confirmed that 2022+ tundra wheel fits on 2024 tacoma.
  2. Aug 20, 2024 at 7:59 PM
    #5102
    TundrX
    TundrX New Member
    Toan
    Sacramento, CA
    2024 Tundra Hybrid Platinum
    Thanks! I went with these, specifically because they had a more positive offset. I don’t recall the PM2 being available when I ordered these (I had them a year before the truck lol), I might have gone that route. But the offset of the SB’s is in that sweet spot of how much poke I wanted.
    I think with your lift kit, your wheels and offset is gonna look sick!! I’m sure you’ll be happy either way!
    Here’s some straight-on shots for reference:
    import36 likes this.
  3. Aug 24, 2024 at 6:56 AM
    #5103
    insomnia413
    insomnia413 New Member
    2024 1794 I-Force Max
    Hi there.
    2024 1794 ed., completely stock with no lift.
    Finally got my set up completed, and wanted to post my results.
    FN Wheels, Five Stars - 17" (25 mm offset)
    Cooper Discoverer A/T3 4S, P285/70 R17s
    I wanted to maintain OEM circumference, be as light as possible, but strong enough to tow with, and above all I wanted MORE SIDEWALL. I live off some poorly maintained country roads and do a fair amount of off-roading. The stock 60 profile tires are not good for either.
    Here's Tire Comparison for stock/OEM compared to what I have now. >25% more sidewall(!!!) while no real change in acceleration/braking performance and speedo/mileage readings are basically identical.
    Overall, I really couldn't be happier with the look and ride characteristics with this set up. I really like this sort "just enough" poke, and running over rough pavement now and even bumps on the highway is just a different world. I didn't really know how bad it was until I got this.
    Thanks to everyone else posting on here as I really got a lot of help in picking what I wanted. And thanks for FN Wheels for offering a really nice choice for someone who needs some extra rubber. If anyone was curious, I got exactly 24.6 pounds each per wheel for my Five Stars (bathroom scale), which is very light compared to what's out there, and the Coopers are 46 pounds each per Tiresize (didn't weigh them myself).
    Bryzzo, kirkb, FNWheels and 2 others like this.
  4. Aug 24, 2024 at 1:51 PM
    #5104
    Paul499
    Paul499 Large Member
    Paul
    Sarasota, FL
    2024 Platinum Hybrid
    Weld 20x9, Toyo 285/60, RC N3 level, ceramic tint
    Hey ^ looks great! Great strategy. And the beefy tires with a lil poke just looks so much better than stock.
  5. Aug 25, 2024 at 4:44 AM
    #5105
    mbean224
    mbean224 New Member
    Matthew
    2024 Ice Cap Tundra Limited w/ TRD off road
    First picture stock
    Second Picture Tires 275/65/20 Nitto Recon Grappler SL rated
    Third Picture is Tires 275/65/20 Nitto Recon Grappler SL rated & Cornfed 1 inch front
    "level"
    Front Center Hub to Bottom Fender - Driver side = 22 3/8"
    Rear Center Hub to Bottom Fender - Driver side 23"
    csmobley, BLCKBIRD, Paul499 and 8 others like this.
  6. Aug 25, 2024 at 5:02 AM
    #5106
    SoCal_Erik
    SoCal_Erik New Member
    2023 SR5 Sport 4x4
    this looks great! Didn’t know about corned. Been debating about the RC spacer but I keep reading lots of cons.
    Cbrash likes this.
  7. Aug 25, 2024 at 6:15 AM
    #5107
    mbean224
    mbean224 New Member
    Matthew
    Also. I did some measurements so others would know the difference front to back. I feel this is the "level" I'm looking for. I cant say enough good things about David from Cornfed Suspension.
    Edit: added them to OP
    SoCal_Erik[QUOTED] likes this.
  8. Aug 25, 2024 at 11:07 PM
    #5108
    4x4silverbullet
    4x4silverbullet New Member
    Has anyone tried running pizza cutters on their 3rd gen? 255/80 r17.
  9. Aug 26, 2024 at 12:20 PM
    #5109
    4x4silverbullet
    Hi are you having any rubbing issues with this set up? I’m look to get some Falken at4w’s in this size with similar rims. I haven’t be able to get an answer about the rubbing issue.
  10. Aug 27, 2024 at 5:28 AM
    #5110
    Yotaholic4life
    Yotaholic4life New Member
    24 TRD Limited CM LB, 23 SR5 8ft bed DC
    24 TRD Lift
    Well , I got tired of waiting for the TRD kit to be released so I installed my wheels and tires today .
    RTX Patton 18x9 +10 with Toyo 295/70/18’s
    No Lift , has some slight rub on inner section of mudguard . Heat gun and some remoulding will cure it .
    ninja edit : Heat gun didn’t work out so I trimmed the guards and pinned back the felt liners . No rub :)
  11. Aug 27, 2024 at 9:37 AM
    #5111
    mbean224
    mbean224 New Member
    Matthew
    Looks great. Can you tell me more about your bug guard. Maybe a link to where to get it and how does it install?
  12. Aug 27, 2024 at 11:21 AM
    #5112
    Yotaholic4life
    24 TRD Lift
    Thanks !! It’s the Toyota deflector straight from the dealer . Installs in 20mins with rubber bumpers and protective film for the paint and screws directly into existing holes under the lip of the hood with brackets and 10 screws .
    Shooter8571 likes this.
  13. Aug 27, 2024 at 11:26 AM
    #5113
    mbean224
    mbean224 New Member
    Matthew
    Dang, I'm looking right now and can't seem to find it on toyota parts. If you find it, mind sending me the link.
  14. Aug 27, 2024 at 11:33 AM
    #5114
    Yotaholic4life
    24 TRD Lift
    Might be a Canada only thing . It’s listed in accessories menu . Here’s the part # pk175-34n00
  15. Aug 27, 2024 at 11:58 AM
    #5115
    mbean224
    mbean224 New Member
    Matthew
    Pefect. Thank you. Looks to be a Canada thing. Im looking now in the US
  16. Aug 27, 2024 at 2:23 PM
    #5116
    RickyPNW
    RickyPNW New Member
    '23 TRD 1794, FWC Raven
    To be honest I like your current setup more than what I had planned with my 18x9 et0 TEs. Only thing about the SBs is that I believe it has a lower load rating compared to the others?
    Have you thought of adding the Pro flares with marker lights? That would work perfect with your setup.
  17. Aug 29, 2024 at 11:19 AM
    #5117
    Mflyer598
    Mflyer598 New Member
    Mark
    Exact look I’m going for! Did you go with zero offset on the Technics?
  18. Sep 4, 2024 at 5:12 PM
    #5118
    Nomoredomestics
    Nomoredomestics New Member
    GA
    2023 TRD Sport 4x4
    Finally got new tires! I had originally put on Cornfeds 1" leveling spacer and wanted to go back to a tad bit of rake, so swapped for the 1/2" kit and went with recon grappler 275/65 20. Some people will say I should have left the thicker spacer but me likey!20240901_120347.jpg
    BWag5, MSPlatty and SilveradoSwap like this.
  19. Sep 7, 2024 at 1:56 PM
    #5119
    FNWheels
    FNWheels New Member
    Dustin
    2005 Tundra and 2019 Tundra
    You will not have any rubbing with stock suspension, 17x9" +25mm offset FN Five Stars or Six Shooters and 285/70R17 Falken Wildpeak AT4W tires. :)
  20. Sep 7, 2024 at 3:44 PM
    #5120
    SilveradoSwap
    SilveradoSwap New Member
    2024 1794 Edition Tundra
    How many of ya’ll put the stock wheels back on for the winter? I live in PA and winter weather is hit or miss. However, they tend to salt spray a lot when its in the forecast. When it does snow, salt and cinders everywhere.
  21. Sep 7, 2024 at 4:34 PM
    #5121
    BlackNBlu
    BlackNBlu Cranks Nickelback in Target order pickup lane
    Rich
    MN
    24 Limited CM 5.5 Blueprint TRD OR
    5100's, 285/75/18, Air Lift bags, bits and bobs
    Every vehicle I've had with aftermarket "nice" wheels has had the factory set kept for winter tires. This one will be no different. I'll let the stock 20" Mildpeaks get me through this winter. Didn't really get enough snow last winter to give a fair assessment. Depending on how they do in snow, I either keep them for upcoming winter(s) or ditch them for something better.
    Either way, a new set of light 18's and 295/70/18 116S Recon Grapplers in the Spring!
  22. Sep 7, 2024 at 11:17 PM
    #5122
    Yotaholic4life
    24 TRD Lift
    I always take the oem tires off not long after purchase. Use the stock wheels for the winter tires and toss the original all seasons back on them when it’s time to sell the truck . Fresh rubber always helps with resale lol . I live in salt 1/2 the year :(
  23. Sep 9, 2024 at 4:57 PM
    #5123
    HunterLT
    HunterLT New Member
    Hunter
    2022 Magnetic Grey Tundra SR5 TRD
    After 47k on the stock tires I finally upgraded to some 285/75/18 KO3s. Still stock suspension and wheels. upload_2024-9-9_18-56-36.jpg
    COTundra23, Shooter8571 and ARCOVT23 like this.
  24. Sep 10, 2024 at 2:31 PM
    #5124
    Gobstopper
    Gobstopper New Member
    Crazy how the 3rd gen's look equally as good with smaller 285/70/17 as they do with nearly 35's. I had 285's on my 2nd gen and they just looked way too small.
  25. Sep 11, 2024 at 10:34 AM
    #5125
    Savagesawyer
    Savagesawyer New Member
    Beaverton, OR
    Probably too broad of a question, but here goes: I really like the 3rd gen pro wheels, but I think mainly the offset/stance it gives the truck. What wheels are comparable? I'm putting the pro flairs on my 1794 and would prefer the tires be flush with that.
  26. Sep 11, 2024 at 4:37 PM
    #5126
    Tundrraguy
    Tundrraguy New Member
    18x9 -12 offset on 285/75r18. I like how it comes out.
  27. Sep 11, 2024 at 4:56 PM
    #5127
    SilveradoSwap
    It looks great :thumbsup:
    Tundrraguy likes this.
  28. Sep 12, 2024 at 10:35 AM
    #5128
    Tundrraguy
    Thank you sir!
  29. Sep 14, 2024 at 3:17 AM
    #5129
    11CMGray
    11CMGray New Member
    looks good. I had some bronze icons on my 2.5 gen and loved them. though black would go well with my new lunar rock, the bronze really stands out, what wheels are those, 4play?
  30. Sep 14, 2024 at 3:40 AM
    #5130
    11CMGray
    11CMGray New Member
    How are you liking the 17" wheel. I went down to a 17" on my last gen Tundra to get a bigger tire look, other than not being able to get a wheel brush behind the brake caliper to clean it was great
