GEN 3 (2022+) Wheels and Tires Photo thread
Discussion in 'Wheels & Tires' started by Tsquare, Jan 16, 2022.
  1. Jul 8, 2024 at 7:24 AM
    #5011
    machd08
    machd08 New Member
    CLARENCE
    Sumter, South Carolina
    2025 Land Cruiser/Land Cruiser
    Questions and yes I did search, but no luck.
    I have a 24 1794 LE, that came with TRD Pro 1.1 lift, I changed (because I wanted to), to Icon 3.0 Coilovers and UCA’s got an additional 2” lift, in my mind that would be 3.1” lift over stock.
    So questions are am I correct in assuming it’s 3.1” over stock and should I be able to fit
    Michelin Defender LTX Platinum in 295/65/20 without mods?
    Thanks
  2. Jul 8, 2024 at 7:26 AM
    #5012
    machd08
    machd08 New Member
    CLARENCE
    Michelin Defender LTX Platinum in 295/65/20 without mods on stock wheels.
    Thanks
  3. Jul 8, 2024 at 7:34 AM
    #5013
    gesekee19
    gesekee19 New Member
    Toyota sells tundras off the lot with the 3” trd lift, stock 20” wheels and upgraded 295’s so I imagine you’d be okay.
    I’m running on a King 2.5 lift with the front lift being about 1.8”. I have 295/70/18 and have no issues with rub and no modifications
    machd08[QUOTED] likes this.
  4. Jul 8, 2024 at 8:08 AM
    #5014
    machd08
    machd08 New Member
    CLARENCE
    Will see today, going to Discount tire and they will trial fit to make sure no rubbing, just called and said they had set in. Thanks for the input.
  5. Jul 8, 2024 at 11:46 AM
    #5015
    tundrabobbob
    tundrabobbob New Member
    I paid 820 shipped for them.
    Chomponthis[QUOTED] likes this.
  6. Jul 8, 2024 at 11:48 AM
    #5016
    tundrabobbob
    Can someone tell me what tire pressure I should be running on these daily? 295 70 18 ko2's. I'm thinking 38-41?
    Tundrastruck91 likes this.
  7. Jul 8, 2024 at 11:49 AM
    #5017
    machd08
    machd08 New Member
    CLARENCE
    Well the Michelin Defender LTX Platinum 295/65/20 will fit, no rubbing no mods, and mud guards are still on it, will get better pics. They ride pretty quite.
  8. Jul 8, 2024 at 2:08 PM
    #5018
    Chomponthis
    Chomponthis New Member
    Billings, MT
    2023 Tundra Limited Cremax 4x4, TRD OR
    Ended up weighing my new wheels and tires:
    77 lbs TRD Pro wheels with General Grabber ATX 275/70R18 (SL)
    73 lbs TRD OR wheels (20in) with stock Falken Mildpeaks
  9. Jul 8, 2024 at 2:17 PM
    #5019
    drewpweinerMD
    drewpweinerMD MPG’s are for your moms Prius.
    Jeremy
    2024 Limited TRD OR
    RB20 Slims, BAK X4s, Fabtech Level, Cooper 35's
    I would suggest, from my own R&D department, 50-55 upfront and 40-45 in the rear
  10. Jul 8, 2024 at 6:43 PM
    #5020
    Exec_TRD
    Exec_TRD New Member
    2024 Tundra Limited TRD Off Road
    Do you like the platinums? I was thinking about getting them in 285/65/20 for my ram 2500, or doing the recon grapplers like I did my tundra. I like the defenders for my 4Runner.
    txez and machd08[QUOTED] like this.
  11. Jul 9, 2024 at 12:04 AM
    #5021
    xptundra33
    xptundra33 New Member
    do you know what offset your wheels have?
  12. Jul 9, 2024 at 1:29 AM
    #5022
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2023 Tundra Platinum Hybrid
    Dobinsons IMS 2"/1", BMS 1" Wheel spacers with OEM Platinum Wheels. Icon Sway Bar Spacer. 285/65/20 Firestone Destination XT Tires.
    Where'd you get your center caps?
    FaFaFranko likes this.
  13. Jul 9, 2024 at 3:50 AM
    #5023
    Dave3196
    Dave3196 New Member
    Dave
    SE PA
    2024 SR5 TRD Offroad
    Bulletpoint dash mount, Method 316, BFG KO2
    2024 SR5 with Method 316 +25 and BFG KO2 285/70-17
  14. Jul 9, 2024 at 5:47 AM
    #5024
    machd08
    machd08 New Member
    CLARENCE
    Only have about 30 miles on them, so far they are great
  15. Jul 9, 2024 at 5:48 AM
    #5025
    machd08
    machd08 New Member
    CLARENCE
    Whatever the offset is for OEM wheels, I have no idea
  16. Jul 9, 2024 at 5:48 AM
    #5026
    machd08
    machd08 New Member
    CLARENCE
    They came on the truck, came on 1794 LE
    harrybdoyleiv likes this.
  17. Jul 9, 2024 at 7:42 AM
    #5027
    tundrabobbob
    That seems pretty high. Are you sure? Is there a reason for the front/rear difference?
  18. Jul 9, 2024 at 9:04 AM
    #5028
    AZxp
    AZxp New Member
    '23 on 3.ohs and dirty sevens
    agreed that is a little high. front gets more because its heavier (assuming unloaded bed/no trailer on the rear) b/c of engine + front end components.
  19. Jul 9, 2024 at 11:29 AM
    #5029
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    If you ever get a chance to take a picture of the back of the cover for the part number, you'd forever be my hero.
    edit: nevermind found it from another thread PT998-35221-3S for anyone that needs it.
  20. Jul 9, 2024 at 1:39 PM
    #5030
    machd08
    machd08 New Member
    CLARENCE
    Will do, it’s in the shop now getting some warranty work done, be few days
    PVT Pablo likes this.
  21. Jul 9, 2024 at 5:01 PM
    #5031
    Yotaholic4life
    Yotaholic4life New Member
    24 TRD Limited CM LB, 23 SR5 8ft bed DC
    24 TRD Lift
    Test fitted 295/70/18 Toyo OC on RTX Patton +10x9 today on work truck . Mildly touches mud guard and front fender liner at full turn . New 24 TRD CM shows up Thursday , so no TRD lift ( Stop sale order ) . I think I’m gonna leave the big wheels until the new spring compressor gets approved . Look like a squat truck , I dunno ?
  22. Jul 9, 2024 at 9:13 PM
    #5032
    jachal
    jachal jachallen
    andy
    FLX, NY
    2023 Black Platinum Hybrid
    added 1” spring spacer to the rear 2” lift coils.
    Wood-Dro likes this.
  23. Jul 10, 2024 at 7:39 AM
    #5033
    drewpweinerMD
    Jeremy
    2024 Limited TRD OR
    This thing is sickkkkkkkkkk
    jachal[QUOTED] likes this.
  24. Jul 10, 2024 at 11:05 AM
    #5034
    carbinefreak
    carbinefreak New Member
    The load charts say 35psi, I like 37 for road trips. I've run as low as 32 on my dirt roads "around town" and it rides very nice. Anything above 40psi is very harsh since this truck doesn't weigh enough to compress the tires.
    tundrabobbob[QUOTED] likes this.
  25. Jul 10, 2024 at 11:10 AM
    #5035
    tundrabobbob
    Thank you for the info. I will try 37 for now and go from there.
  26. Jul 10, 2024 at 4:47 PM
    #5036
    Tessa2022
    Tessa2022 New Member
    Cj
    2022 tundra sr5
    IMG_20240706_101945_125.jpg IMG_20240706_101945_229.jpg IMG_20240706_101945_272.jpg 20240705_110556.jpgtis 563bz 20x9 +18.
    Nexen atx 275 60 20
  27. Jul 12, 2024 at 3:16 PM
    #5037
    Coronerrpm
    Coronerrpm New Member
    Bob
    22 tundra red sport
    Non yet
    Westcott. Toyo open country at3. 295/65-20
    22 trd sport. Hated how it sat 1” lower from the factory. Love it now.
    Perfectly level now. Picture makes sense t look low but it’s not
  28. Jul 12, 2024 at 3:17 PM
    #5038
    Nomoredomestics
    Nomoredomestics New Member
    GA
    2023 TRD Sport 4x4
    Just a level?
  29. Jul 12, 2024 at 6:20 PM
    #5039
    Nomoredomestics
    GA
    2023 TRD Sport 4x4
    Wha?? I was asking if it was a level or lift
  30. Jul 12, 2024 at 6:53 PM
    #5040
    tonyusmc
    tonyusmc New Member
    2022 Tundra
    TRD Parts
    i'm looking at possibly changing from the 20 inch TRD Adventure wheels to the TRD Pro Wheels, what's a good price to pay for on market place ? Just Wheels no tires or anything else. Thanks all
    TundraDan723 likes this.
