GEN 3 (2022+) Wheels and Tires Photo thread
Discussion in 'Wheels & Tires' started by Tsquare, Jan 16, 2022.
  1. Apr 18, 2024 at 4:28 PM
    #4741
    Welderdude80
    Welderdude80 New Member
    JP
    Alberta
    2023 Tundra limited hybrid crew max
    working on it
    Aftermaket +18
  2. Apr 18, 2024 at 4:49 PM
    #4742
    Battousai
    Battousai New Member
    OC
    2024 iforcemax tundra limited
    Ordered a borla atak delivery April 2!!
    dagsom, BIGrun20 and Welderdude80 like this.
  3. Apr 18, 2024 at 4:57 PM
    #4743
    paulphilly
    paulphilly New Member
    Paul
    Upstate NY
    '24 TRD Pro
    Stock flaps and zero rub, even at full lock forward or reverse
  4. Apr 18, 2024 at 5:18 PM
    #4744
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    My 295/60/R20 with +15 rub on the liners and mud flaps. Mud flaps are off right now but going back on with some trimming.
    I don't mind the liner rubbing but need the mud flaps to protect paint so time to get cutting!
  5. Apr 18, 2024 at 5:31 PM
    #4745
    Welderdude80
    JP
    Alberta
    working on it
    Crap. Post a picture when trimming is done and flaps back on I’m curious
    Thanks
  6. Apr 18, 2024 at 5:36 PM
    #4746
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Note that wheels and tires fit pretty good except the little rubbing while turning. The OE mud flaps have a bump in them that others have cut off and that worked.
    No trimming of the truck!
    I think the liners can be pinned back to keep it away from the tires.
    Not too big a deal and I have had the wheels on the truck for about 14 months.
  7. Apr 18, 2024 at 6:25 PM
    #4747
    Welderdude80
    JP
    Alberta
    working on it
    I see. Easy peasy.
  8. Apr 18, 2024 at 6:51 PM
    #4748
    benca1
    benca1 New Member
    2023 TRD Offroad SR5 Crewmax 4x4
    295/60/20 Wildpeaks 20” limited wheels TRD running boards TRD exhaust OEM bed mat OEM bedcover OEM all weather Mats 4Knines rear seat cover
    Yeh it’s not only the offset of yours but also the width vs my factory 20x8. I can go full rotation with 35x11.50x20 or 295/65/20 or what I have 295/60/20. The 295/60/20 was the safest bet for no rubbing on stock suspension with my oem 20x8 wheels. As you go aftermarket u run into most are 9” wide and usually a little more aggressive offset. I think you will be ok with some pinning back and taking out that little black box behind the front wheels.
  9. Apr 19, 2024 at 1:09 PM
    #4749
    LunarNick
    LunarNick New Member
    Nick
    2024 Limited Tundra
    Icon 3in lift 37x12.5 17 no rub at all
    sportbike37, Battousai, Helo and 3 others like this.
  10. Apr 19, 2024 at 1:37 PM
    #4750
    Welderdude80
    JP
    Alberta
    working on it
    i think I’ll be ok with pinning back the mudflaps by 3/4” just need to figure how to do so.
    benca1[QUOTED] likes this.
  11. Apr 19, 2024 at 1:38 PM
    #4751
    benca1
    benca1 New Member
    might want to take out that metal bracket too. Gives way more clearance and only two bolts.
  12. Apr 19, 2024 at 7:47 PM
    #4752
    SilveradoSwap
    SilveradoSwap New Member
    2024 1794 Edition Tundra
    Perhaps its the picture perspective, but the truck looks like it has a fair bit of rake. Icon looks to be well built parts.
  13. Apr 20, 2024 at 10:50 AM
    #4753
    Reaper1911
    Reaper1911 New Member
    2024 White Tundra Limited Off-Road
    -TRD pro reaper bumper panels/fender flares -Catalytic converter cover -Bak revolver x4s tonneau cover
    Clean looking. Getting 35's of those KO2's put on in a couple of days. Any issues with them?
  14. Apr 20, 2024 at 11:34 AM
    #4754
    Dabutcher
    Dabutcher New Member
    D
    Twin Cities
    2022 Tundra 1794 Supersonic Red
    Nitto Ridgegrapplers 175/60/20
    275/60/20 Ridgegrapplers on stock 20’s.Peace. D
    ytank1 and Welderdude80 like this.
  15. Apr 20, 2024 at 6:21 PM
    #4755
    Reaper1911
    Hey I'm days away from installing the same size wheels and exact same tires. What's your offset? Because the place installing them convinced me I needed a 25 offset or the tires would "stick out too much." Not sure if it's a little poke or they'd be way out there.
  16. Apr 20, 2024 at 9:40 PM
    #4756
    Brian422
    Brian422 New Member
    Birmingham, AL
    23 Limited 4x4
    +25. They stick out just a little bit.
    Bryzzo likes this.
  17. Apr 20, 2024 at 10:25 PM
    #4757
    Reaper1911
    Got any pics of how it looks?
  18. Apr 21, 2024 at 10:06 AM
    #4758
    LunarNick
    Nick
    2024 Limited Tundra
    Parked at a weird angle kinda sloped
  19. Apr 21, 2024 at 9:34 PM
    #4759
    LunarNick
    Nick
    2024 Limited Tundra
    They don’t balance well at least not 37’s balanced them 9 times not perfect but good enough for now
  20. Apr 21, 2024 at 10:33 PM
    #4760
    LunarRockAgave
    LunarRockAgave New Member
    LimitedCrewMaxLunarRock24
    20x9 Fuel Rebel 6's +20mm offset. On 35x12.5R20 Toyo Open Country A/T III's
  21. Apr 22, 2024 at 7:15 PM
    #4761
    SilveradoSwap
    Any poke at all on that? I was going to go with an 22x10 -18 offset but calcs say it would poke a lot. Ended up buying a 22x9.5” at +20 offset with a 305/45r22. Hope there is at least some poke, should be based on the numbers.
  22. Apr 22, 2024 at 9:39 PM
    #4762
    Bruski208
    Bruski208 New wheels and Tires
    Idaho
    2023 "Wind Chill Pearl" Tundra Ltd. 4x4
    Dealer mods: Fuel Maverick, BFG K03 275/65R20, Leer Canopy, Paint protection film, Window visors, Side Steps (fixed), and more that I don't recall...
    I'm kinda anal about tire/wheel weight and how it affects MPG. I believe the stock 20 set up ('23 Ltd w/265/60R20s) is about 68 lbs. ea. I calculated this by weighing stock wheels with snow tires I bought from TireRack (and they list weights with the specs of each item.) My snow tire set up weighed 87 lbs/ea. I found the weights of the snow tires (TireRack) and stock tires (Discount) and calculated what the stock set-up should weigh. I did this because the dealer I bought my truck from had installed Fuel wheels with over sized BFG KO3s and my mileage suffered (less than 15 MPG hwy.) I have more info if interested, PM me
  23. Apr 22, 2024 at 9:59 PM
    #4763
    Bruski208
    Idaho
    I just had these Black Rhinos with Nitto Grapplers mounted. Truck came with a 2" lift from the dealer and Fuels with BFGs. That set up yielded less than 15 MPG so I found a lighter combo. I'm going for 18 MPG or better... Sorry about the full truck image -it's wide angle because I couldn't get back further
  24. Apr 22, 2024 at 10:54 PM
    #4764
    LunarRockAgave
    There's roughly a 1 to 1 1/4 inch poke. I had some Black Rhino Wheels 20x9.5 at -18 offset and the shop that did my work was concerned with potential rub using these wheels. Ultimately it wasn't the rub but the amount of poke with those that made me pivot to these +20mm offset wheels. Here's a pic of the poke with the -18mm at x9.5 wheel, where yours was X10, even more poke.
    3d_pilot likes this.
  25. Apr 23, 2024 at 2:44 AM
    #4765
    O2_Stat
    O2_Stat New Member
    Rick
    2024 Limited Trd Off-Road
    looks clean bro. What made you go with 35x11 vs 35x12? Any rubbing issues ?
  26. Apr 23, 2024 at 3:10 AM
    #4766
    O2_Stat
    O2_Stat New Member
    Rick
    very nice looking tundra bro. Ordered the wescott design pre collar lift kit. Do you happen to know the specs to align after the lift? And also how do you like the ride with the Toyo AT3s? I'm getting the same tires too. Any rubbing issue? Thanks
  27. Apr 23, 2024 at 3:40 AM
    #4767
    SilveradoSwap
    Thanks for that visual, very helpful. That wheel and tire combo looks good you installed. I ended up going with a Vossen wheel in bronze and AT3 tires. Been nervous and excited about the fitment since placing the order.
  28. Apr 23, 2024 at 3:41 AM
    #4768
    SilveradoSwap
    I agree 100%, truck looks super clean.
  29. Apr 23, 2024 at 6:51 AM
    #4769
    LunarRockAgave
    I was between black and bronze. Bronze will look good. Which Vossen wheel, they make some nice wheels.
  30. Apr 23, 2024 at 6:56 AM
    #4770
    SilveradoSwap
    Vossen HF6-4 in Terra Bronze. Using black Vossen lugs as well. 22x9.5
