GEN 3 (2022+) Wheels and Tires Photo thread
Discussion in 'Wheels & Tires' started by Tsquare, Jan 16, 2022.
  1. Mar 17, 2024 at 7:15 PM
    #4591
    benca1
    benca1 New Member
    2023 TRD Offroad SR5 Crewmax 4x4
    295/60/20 Wildpeaks 20” limited wheels TRD running boards TRD exhaust OEM bed mat OEM bedcover OEM all weather Mats 4Knines rear seat cover
    I haven’t full flexed but never rubbed anything in and out of steep driveways like from highways and such. The 275’s will clear the UCA’s easily but are a tiny bit taller. I would prefer that setup with at least a level. I know you won’t have any issues out back but up front flexing hard it might rub.
  2. Mar 17, 2024 at 7:18 PM
    #4592
    caveman_rox
    caveman_rox New Member
    Brand new...nothing yet!
    Well, I'll have about 800+ pounds in the truck bed with a popup tent camper and a small off-road trailer being towed... so I've got serious concerns...haha. Appreciate all the input...
    Anyone know what you the max size 20s you can while also maintaining full flex?
  3. Mar 17, 2024 at 7:24 PM
    #4593
    cvd2312
    cvd2312 New Member
    2023 CrewMax SR5 TRD OR
    I don’t flex my suspension that much, but theres a lot of room in there with the 275/65 size.
    FYI sidewall height on the 275/65/20 is basically the same as the 265/70/18 stock tires that came on the truck
  4. Mar 18, 2024 at 8:40 AM
    #4594
    dccrens
    dccrens New Member
    Leesburg, VA
    2024 Tundra I-Force Max Hybrid, Lunar Rockin!, 6.5 Bed
    2024 Limited, iForce Max hybrid, 6.5ft bed, TRD off-road package, TRD 20in wheels, TRD Grille, TRD skid plate, blacked-out badges, NYTOP Rear Recovery Points; Red, aFe Power Front Tow Hooks Red
    Is that the 3" factory lift?
    Looks great.
  5. Mar 18, 2024 at 2:05 PM
    #4595
    arrampico
    arrampico New Member
    2023 SR5 CM 4X4 SB Silver Tundra
    Wheels:
    FN BFD Gloss Graphite @FNWheels
    18x9
    22.4 lbs.
    +20 Offset
    Tires:
    Cooper Discoverer AT3 XLT LT275/70R18
    Stock 2023 SR5
  6. Mar 18, 2024 at 2:32 PM
    #4596
    dklehman
    dklehman New Member
    Darin
    2024 sr5 Tundra
    Looks great
    arrampico likes this.
  7. Mar 18, 2024 at 2:51 PM
    #4597
    arrampico
    Glad I went with these over Michelin’s….and they look way better in person. I think 33’s look perfect with no suspension upgrades.
    Tundrastruck91 likes this.
  8. Mar 19, 2024 at 10:26 AM
    #4598
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    P rated ? Weight should also be close to stock oem.
  9. Mar 19, 2024 at 10:33 AM
    #4599
    Marc4x4
    Marc4x4 New Member
    Now that youv'e had it for awhile do you have any rubbing with the swaybar. Thanks
  10. Mar 19, 2024 at 2:36 PM
    #4600
    arrampico
    E…DT said 54lbs.
  11. Mar 19, 2024 at 2:44 PM
    #4601
    Breathing Borla
    AZ
    way more than stock
  12. Mar 19, 2024 at 4:02 PM
    #4602
    cvd2312
    cvd2312 New Member
    His wheels are 8-9lbs lighter than stock, tires are about 16lbs heavier. So overall only about 7lbs per corner heavier than stock
  13. Mar 20, 2024 at 1:13 PM
    #4603
    FNWheels
    FNWheels New Member
    Dustin
    2005 Tundra and 2019 Tundra
    2023 Tundra
    • 17x9" +25 6x139.7 95.2 FN Wheels Six Shooter flow formed (matte black)
    • 37x12.50R17 BF Goodrich All Terrain KO2
    • 2" front coilovers / 1" rear springs lift
    Wheels were designed, engineered and tested to fit the 2022+ Tundra.
    Photos courtesy of The 4x4 Center in South Burlington, VT.
    • 95.2mm hub centric center bores (no need for hub rings on the 2022+ Tundra).
    • Lug holes/stud openings machined to accept extended thread lug nuts for maximum stud engagement on short, OE Toyota wheel studs.
    • Special high strength, high ridigity, and high clearance flow formed barrel that we designed specifically to fit over the Tundra brakes with plenty of clearance for stick-on wheel weights.
    • FN Wheels are manufactured from high purity Dubal 6061 T-6 aluminum alloy (no re-casts).
    • 2,500lbs+ load rating per wheel (5,000lbs per axle) as tested to SAE J2530 testing standard with up to a 37" tire diameter. Larger tires exert more load, so we tested and load rated our 17" wheels to handle 37" tires with a load rating that exceeds the Tundra axle rating by 20%+.
    • Reinforced flanges and lips for maximum strength and durability.
    • Raised bead humps with knurled bead seats for improved bead retention at low PSI (i.e. when aired down while off-roading).
    • Relatively light weight of approximately 26.5lbs per wheel given all of the strength and off-road enhancements.
    • Durable paint/clear coat (extremely fade resistant compared to our competitors' matte black finishes).
    • Simple, strong, and easy to clean design.
    ARCOVT23, Siopao, HSrider! and 3 others like this.
  14. Mar 20, 2024 at 1:19 PM
    #4604
    Breathing Borla
    AZ
    I think you have to be an approved vendor here to sell stuff, just throwing that out there.
    anyways, what does that weight per corner for wheels and tire? got to be super heavy
  15. Mar 20, 2024 at 1:41 PM
    #4605
    FNWheels
    FNWheels New Member
    Dustin
    I can delete or re-write the post if deemed necessary. I'm not trying to ruffle any feathers. I just figured that anyone reading would want to know all of the specs, but if it comes off as an advertisement I'd be happy to modify the post. I intentionally didn't insert a link or a price, because I didn't want my post to come off as an advertisement. I read through the terms of service https://www.tundras.com/help/terms and didn't see anything that I would interpret as prohibiting my post.
    I'm not familiar with any other 17" wheels that are available right now that were designed specifically by Tundra owners for Tundra owners. I also haven't seen any other wheel manufacturers or vendors on here engaging with Tundra owners and answering questions. I thought it would be helpful for me to do so (check my post history).
    Regarding the weight per corner for this setup - it's all relative. This is actually a pretty light weight set up for 37's.
    Compare this, for example, to the combination that this gentleman posted just a few posts prior to mine (here).
    The 4x4 Center's 2023 Tundra:
    26.7lbs per wheel (17x9" +25 6x139.7 FN Six Shooter flow formed)
    64.8lbs per tire (37x12.50R17 BFG KO2 load range C)
    91.5lbs approximate weight per corner (a little more by the time you balance the wheel/tire combination)
    ADSFM's Tundra from the post referenced above :
    31.2lbs per wheel (18x9" +0 6x139.7 Method MR309 Grid)
    60.3lbs per tire LT275/70R18 Falken A/T4W
    The 17" Six Shooter combination with 37" tires is basically the same weight as the 18" Method MR309 combination with 33" tires. This isn't to say that there's anything wrong with his wheel and tire set up. I like the way his truck looks, and I don't think his combination is too heavy for a Tundra either. I just used his truck as an example since it was one of the most recent posts in this thread, and you asked about a weight comparison.
    If we were to install a lighter weight 285/70R17 (33" OD) we could easily get the 17" combination under 75lbs per corner.
    *Post edited because I had two different sources for the weight of the 37x12.50R17 BFG KO2 load range C tires. I changed the calculation in my post to include the heavier of the two weights.
    Sources:
  16. Mar 20, 2024 at 2:21 PM
    #4606
    jdietrich
    jdietrich New Member
    Kansas City, Mo
    2023 Platinum Wind Chill Pearl
    TRD Pro Grille, Diodedynamics light bar & fog lights, Talon Cat guard, RCI Skid, Suntek Paint Protection, Century Topper, Paint match mustache, GG Off-road Re-Locator
    Put on some new shoes.
    275/60/20
    Cooper AT3 4s
    Ride is just as plush as OEM with a bit more stiffness on side to side turning.
    Highly recommended if not wanting to add weight and roughness.
  17. Mar 20, 2024 at 4:11 PM
    #4607
    dklehman
    dklehman New Member
    Darin
    2024 sr5 Tundra
    Most of the method, fuel and icon wheels I looked at were 31 to 34 lbs and the heaviest was 39 lbs. The FN BFD 18 inch wheels were a little over 22 lbs so a huge saving in weight compared to other aftermarket wheels.
    arrampico and FNWheels like this.
  18. Mar 20, 2024 at 4:54 PM
    #4608
    Chad365
    Chad365 New Member
    GA
    2023 HV MGM 1794 TRD OR 4x4
    Chrome delete and more to come WIP …. Lol
    Offset ?
  19. Mar 20, 2024 at 9:27 PM
    #4609
    romanlegion
    romanlegion New Member
    Roman
    Katy, TX
    2022 Tundra SR5 TRD Off-Road Lunar Rock
    New shoes on the Tundra.
    ICON Recon 17X8.5 +0 offset
    Venom Power Swampthing A/T 37X12.50R17
  20. Mar 21, 2024 at 5:49 AM
    #4610
    4lo Toys
    4lo Toys New Member
    Andrew
    Yes, a tiny bit. The mudflaps rubbed bad and I Zipp tied them back, swaybar rubs a tiny bit at full lock. Was worse at the beginning but after the suspension settled a little it’s pretty minimal.
  21. Mar 21, 2024 at 11:31 AM
    #4611
    arrampico
  22. Mar 21, 2024 at 11:42 AM
    #4612
    Ryan P
    Ryan P New Member
    Ryan
    2022 Tundra Platinum
    Another set of FN Wheels. Total weight of the out going set of worn 20" tires/wheels was ~72lbs. The FN wheels with Cooper Discoverer 275/70r18 Load E are 83 lbs.
    Those running Load E, what pressures do you prefer? I was running about 40psi and the truck felt SLUGGISH. Raising them up to 50psi seemed to take care of most of that, while still feeling only slightly stiffer than stock.
    I also wanted to add that Dustin at FN Wheels was a joy to deal with. You can tell he is a passionate dude that cares deeply about his customers.
  23. Mar 21, 2024 at 12:11 PM
    #4613
    arrampico
    yessir! looking good - i got your twin but silver.
    And Dustin is great!
  24. Mar 21, 2024 at 2:00 PM
    #4614
    Chadillaac
    Chadillaac New Member
    Chsd
    Future Tundra Owner
  25. Mar 21, 2024 at 7:24 PM
    #4615
    Shadd85
    Shadd85 New Member
    Cody
    KC Kansas
    2023 Platinum MGM
    295/55 Recon Grapplers Sentry CT cover with Tonneau Mate toolbox TRD Full Skid Plate OEM Black Lug Nuts Weathertech Mud Guards 20% Ceramic tint - Front doors Protech Gauge, Infotainment and console film
    295/55 Recon Grapplers, completely stock suspension. New to the Tundra, got the pickup two weeks ago and loving it. PXL_20240316_163757104.jpg PXL_20240321_233751138.jpg PXL_20240321_233523973.jpg
    mayan likes this.
  26. Mar 22, 2024 at 5:16 AM
    #4616
    arrampico
    I’m running mine at 40….going to chalk test next week.
  27. Mar 22, 2024 at 7:00 AM
    #4617
    ArBrnSnpr
    ArBrnSnpr New Member
    Colin
    22' AG SR5 TRD OR
    Dustin,
    I think your reading of the guidelines is accurate. I understand the forum's desire for vendors accounts, but as a forum user, I really appreciate a company that will openly discuss all the details of their product, so I can make a better decision.
    I have a set of FN wheels on my GX and they have been amazing! They were the lightest, strongest, least expensive wheel I was able to find and they still look amazing (minus where I gouged them into rocks) 6 years later.
    If a company is going to make a wheel that's tailored to fit the 3rd gen Tundra in a sea of wheels that "fit", but poke out 3 inches, or weight 35 pounds or don't have the correct hub diameter, ect, I'd like to know all about them.
    I'm just waiting for Dustin to release his next wheel for the Tundra, hopefully by summer and I'll be buying another set from him.
  28. Mar 22, 2024 at 8:28 PM
    #4618
    Siopao
    Siopao New Member
    Paolo
    2023 Tundra Limited
    Cut and clamp carven exhaust
    This thread has been very helpful!! Thanks everyone for all the great content and resources. After reading through this thread I've decided to rock the fuel hype 17x8.5 +10. Paired with toyo open counyry at3 285/70/17 sl. I kept my suspension stock and tried to keep weight as low as i could. Rims are at 26lbs tires at 53lbs. Could of gotten baja boss sl and it weighs in at 48lbs but really wanted the white outlined letters to give me setup an old school classic feel. 20240321_180610.jpg 20240321_180553.jpg 20240321_183156.jpg
    pandatss22, mayan, gnc1017 and 6 others like this.
  29. Mar 23, 2024 at 6:52 AM
    #4619
    Chadillaac
    Chsd
    Future Tundra Owner
    Hows your GPM and ride quality on this? Looking at this exact tire setup for my new TRD when it comes in. I'll have the same wheels. THANKS!
  30. Mar 23, 2024 at 7:20 AM
    #4620
    CitySlicker1794
    CitySlicker1794 New Member
    Those look great! What was the offset with the 295/70 R18? have you experienced any rubbing at full lock, or off road?
