GEN 3 (2022+) Wheels and Tires Photo thread
Discussion in 'Wheels & Tires' started by Tsquare, Jan 16, 2022.
  1. Mar 9, 2024 at 11:31 AM
    #4531
    ipw20
    ipw20 New Member
    Bruce: 2024 Black Tundra TRD Pro
    Just strapped on 35x12.5r18 Falken Wildpeak A/T4Ws. Stock TRD Pro suspension and wheels. Snug fit but no rubbing. Specs say these are full 35s (35.1"). IMG_6333.jpg IMG_6334.jpg IMG_6336.jpg
  2. Mar 9, 2024 at 2:24 PM
    #4532
    TundrX
    TundrX New Member
    Toan
    Sacramento, CA
    2024 Tundra Hybrid Platinum
    Heh. Strap on. Please excuse me, I’m still an adolescent boy at heart.
    But in all seriousness, it looks great.
    BabyMoose likes this.
  3. Mar 9, 2024 at 5:12 PM
    #4533
    2494
    2494 New Member
    2024 Tundra 1794
    After a bunch of research I’m thrilled I went with the Nitto Recon Grappler 275/65/20…only 48 lbs and drives like a dream. IMG_2169.jpg
    Justinfro, Lebo, Tundraman479 and 4 others like this.
  4. Mar 9, 2024 at 5:32 PM
    #4534
    Markus
    Markus Hermitic Member
    Mark
    Boring, MO
    2 1794 Tundys 2014 and 2023 AG TRD
    A few
    Leveled?
  5. Mar 9, 2024 at 6:11 PM
    #4535
    2494
    2494 New Member
    2024 Tundra 1794
    Wescott 3/1
    Markus likes this.
  6. Mar 10, 2024 at 8:41 AM
    #4536
    TWade
    TWade New Member
    Tanner
    2023 Tundra TRD Pro Black on Black
    Added Wildpeak AT4W yesterday in 295/70 R18 on stock suspension. Loving them so far.
  7. Mar 10, 2024 at 1:56 PM
    #4537
    SM Tundra
    SM Tundra New Member
    Cody
    2024 Limited Smoked Mesquite Tundra
    How you liking these so far? was looking at the same tire and size. Also looking at the ridge grapplers too. I’m not going to lift or level, but believe the 34” tire should fit no issues.
  8. Mar 10, 2024 at 2:11 PM
    #4538
    2494
    2494 New Member
    2024 Tundra 1794
    Incredible difference between these and the Toyo AT3s I had on my GMC. I’m on the road most of the time and don’t need an E rated tire and all the extra weight.
  9. Mar 11, 2024 at 10:42 AM
    #4539
    Bonesaw
    Bonesaw New Member
    Went with 35x12.50x20 Toyo AT3s on stock wheels because I’m not a fan of most aftermarket wheels. Have the Westcott Designs spacer lift and 1” spacers front and rear. The first alignment shop couldn’t get it right because inexperienced guy had no clue what he was doing.. second place got it right to the specs Westcott recommends.
  10. Mar 11, 2024 at 10:47 AM
    #4540
    lapoolboy
    lapoolboy New Member
    Looks phenomenal!!
    Any rubbing? I have same wheels but my truck has the factory 3" lift installed. How much clearance do you have between tire and UCA? How close to the swaybar?
  11. Mar 11, 2024 at 12:00 PM
    #4541
    TundraRyan68
    TundraRyan68 New Member
    I'm debating lifting my Tundra 1.5" and adding bigger tires. Have any of you experienced a decrease in fuel mileage and increased road noise?
  12. Mar 11, 2024 at 12:10 PM
    #4542
    dklehman
    dklehman New Member
    Darin
    2024 sr5 Tundra
    Yes to both
    TundraRyan68 likes this.
  13. Mar 11, 2024 at 12:12 PM
    #4543
    dklehman
    dklehman New Member
    Darin
    2024 sr5 Tundra
    Bigger tires adds rotational mass so your truck will be a little slower of the line and you will lose some on gas depending how big and how heavy the tires are that you choose. When you lift it more air and lift under the truck will also take away from your mileage.
  14. Mar 11, 2024 at 12:18 PM
    #4544
    Bonesaw
    Bonesaw New Member
    No rubbing with 35s as long as you pin back the Liner that Westcott recommends. Watch their videos and you’ll see what they recommend. No rubbing the control arm at full lock either way, got about 1/2inch of space.
  15. Mar 11, 2024 at 12:52 PM
    #4545
    Northern Toyota
    Northern Toyota New Member
    2023 Tundra TRD Off Road, 2022 Tacoma TRD off road premium
    Tires and bilstein
    my 23 on 295/70r18 gets worse highway mpg than my 20 on 275/65r20.
    TundraRyan68[QUOTED] likes this.
  16. Mar 11, 2024 at 1:06 PM
    #4546
    Bonesaw
    Bonesaw New Member
    The twin turbos are gas hogs.. especially when you’re a spirited driver
    drewpweinerMD likes this.
  17. Mar 11, 2024 at 1:12 PM
    #4547
    Brian422
    Brian422 New Member
    Birmingham, AL
    23 Limited 4x4
    17-8.5 Icon six speed +25 Bronze, wrapped in BFG KO2 315 70 17
    akira and Reaper1911 like this.
  18. Mar 11, 2024 at 1:20 PM
    #4548
    TundraRyan68
    currently my 22 has 265/60R20s on them. Fuel mileage has been great so far. Was just curious how much worse it got with a slight lift and bigger tires
  19. Mar 11, 2024 at 1:24 PM
    #4549
    dklehman
    dklehman New Member
    Darin
    2024 sr5 Tundra
    Most tundra aftermarket wheels are 33 + lbs and as much as 39lbs that is a ton of extra weight to be turning before even adding bigger tires
  20. Mar 11, 2024 at 1:31 PM
    #4550
    Northern Toyota
    Tires and bilstein
    your size can be had in p metric or lower load ranges. Load range e on larger tires adds weight and kills mileage.
    2494 and TundraRyan68[QUOTED] like this.
  21. Mar 11, 2024 at 3:13 PM
    #4551
    cvd2312
    cvd2312 New Member
    2023 CrewMax SR5 TRD OR
    Just installed Toyo AT3 LT275/65/20. On limited off-road wheels I bought off Facebook. My truck also has a cornfed 2/1 lift.
    I was worried about the ride quality going to E range tires but I have to say I wouldn’t be able to tell a difference if I wasn’t looking for it. These tires ride great from the limited driving I’ve done so far.
    Will get some better pictures later, it’s a mucky rainy afternoon in Oregon right now. IMG_0480.jpg
    lavern23, Lebo, Muleycrazy13 and 2 others like this.
  22. Mar 12, 2024 at 7:14 AM
    #4552
    Capecodpat
    Capecodpat New Member
    patrick
    2024 platinum tundra
    My 22 stock 1794 got about 19/20 mpg and now my 24 platinum hybrid with factory lift and 285/70/17C gets barely 15
  23. Mar 12, 2024 at 5:44 PM
    #4553
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    I have a 1.75" leveling and bigger tires, Cooper AT3 XLT 275/65/20 (34") and there is definitely a change in MPG. Slight road noise also but not bad.
    On the OEM tires I was able to get well over 20 MPG, up to 24 if I am very careful, but now I hardly get 18 or 19 at best.
    You can clearly see on my chart where I added the tires. :)
    Leveling was installed within the first month so you can see the first 2 tanks were higher and then dropped a little bit, but after the tires it was a considerable drop.
    Txrx and TundraRyan68[QUOTED] like this.
  24. Mar 12, 2024 at 6:21 PM
    #4554
    Chadillaac
    Chadillaac New Member
    Chsd
    Future Tundra Owner
    Thinking this similar setup.Looks great! What type of MPG are you getting?
  25. Mar 12, 2024 at 6:38 PM
    #4555
    cvd2312
    cvd2312 New Member
    Hard to say, I just got them on yesterday afternoon and have only driven about 50 miles. So far getting about 16.7 adjusted for tire size. Was averaging around 18 give or take this time of year on the stock Michelin’s
  26. Mar 12, 2024 at 6:40 PM
    #4556
    cvd2312
    cvd2312 New Member
    A few more pics of the the Toyo AT3 275/65/20
    Lebo and kirkb like this.
  27. Mar 12, 2024 at 7:36 PM
    #4557
    SM Tundra
    Cody
    So how do the E rated tires ride? I loved my toyos on my Tacoma and would like to throw them on my tundra but everything I read says E rated tires ride terrible. So I’ve been looking at the nittos that come SL rates. But would rather go toyo
  28. Mar 12, 2024 at 7:43 PM
    #4558
    2494
    2494 New Member
    2024 Tundra 1794
    I went through this dilemma…ended up with the Nitto recon grappler 275/65/20 SL rated. Super glad I did. I’m on the road most of the time, don’t need the extra weight of the Es
    SM Tundra[QUOTED] likes this.
  29. Mar 12, 2024 at 8:01 PM
    #4559
    cvd2312
    cvd2312 New Member
    I was in your same position, deciding between the E range Toyos and the SL nittos. Really preferred the Toyos due to the snowflake, and I do tow a 6,000# travel trailer so I thought maybe the stiffer tire might be helpful there. The E toyos are also only 6 pounds heavier than the SL nittos.
    Long story short, they ride nice! Gun to my head I’d probably say I can notice a bit more stiffness compared to my stock Michelin’s, but I was also so worried about a poor ride with these tires that I was looking for it. If I didn’t know the tires were different, I’m really not sure if I would’ve noticed.
    Hope that helps, I know your agony. I went back and forth on this for months and went to the deepest depths of the internet!
    All else fails and you hate it, Toyo has a 45-day satisfaction guarantee. You can always return them
  30. Mar 12, 2024 at 8:25 PM
    #4560
    Marc4x4
    Marc4x4 New Member
    How’s the road noise with those, I’m looking at those except 285/65/6R20
