GEN 3 (2022+) Wheels and Tires Photo thread
Discussion in 'Wheels & Tires' started by Tsquare, Jan 16, 2022.
  1. Jan 21, 2024 at 10:44 PM
    #4291
    TundrX
    TundrX New Member
    Toan
    Sacramento, CA
    2024 Tundra Hybrid Platinum
    Coming from a stock (non-lifted) platinum with 285/75/18's = ~34.8" x ~11.2", since you're lifted, I think the 12.5" would look much better.
  2. Jan 22, 2024 at 9:39 AM
    #4292
    sjs0433
    sjs0433 New Member
    2023 Tundra Limited
    Any more pics, particularly down the side, so I can see how much they poke?
  3. Jan 22, 2024 at 6:03 PM
    #4293
    alkalinedevin
    alkalinedevin New Member
    2023 TRD Pro
    Decided on the 35" Wildpeak RT01's in load range C. Can't wait to mount these up!
  4. Jan 23, 2024 at 3:30 PM
    #4294
    Jnickle25
    Jnickle25 New Member
    2022 Tundra sr5 trd sport black
    Lost a little on mpg but wasn’t concerned about it as I went to more aggressive heavier tire. Speedometer is off by about 2-3mph depending on speed.
  5. Jan 23, 2024 at 8:10 PM
    #4295
    jachal
    jachal jachallen
    andy
    FLX NY
    2023 Black Platinum Hybrid
    dealer installed trd lift w
    2” rear coil springs
    35x12.5r18 firestone destination xt’s
    on kmc impact +18
    Hoody, TRD L Power, 4mm and 2 others like this.
  6. Jan 24, 2024 at 6:06 AM
    #4296
    Nardogg
    Nardogg New Member
    Ryan
    Alberta
    24 Wind Chill Platinum Hybrid
    Wheels/tires, Bumpershellz, trd intake
    A few more of the kmc/yokohama setup
    bigbear503, jachal, Yaboy and 2 others like this.
  7. Jan 24, 2024 at 8:08 AM
    #4297
    2snailsandabattery
    2snailsandabattery New Member
    2023 limited
    Icon stage 1
    Any issues with the rrw 17's and caliper clearance? I am 99% sure this is the brand I am going with. I love your setup
  8. Jan 24, 2024 at 9:29 AM
    #4298
    jachal
    jachal jachallen
    andy
    FLX NY
    for the RR7S 17’s i see a weight of
    26 lbs on their site, and the tires i see weighing 57 lbs. — my 18” kmc’s are 29 lbs and 35” firestones are 59. a difference of 83 lbs vs 88 lbs at all four corners. the slight issues i have are that the 315’s aren’t a true 35”, they’re also right on the edge of the rim width, which i don’t feel super comfortable about. but most importantly, your C rating has a max load of ~2,500 lbs and my E rating has a max load of ~3,500. i’ll gladly take a 3 lb heavier tire that has another 1k lbs of load capacity; especially on a 3 ton truck. (although i do have the heavier hybrid configuration) and lastly i just think 18’s look better on these full size trucks vs a 17 inch wheel. but just my opinion.
  9. Jan 24, 2024 at 9:52 AM
    #4299
    obs1921
    obs1921 New Member
    Jesse
    2024 TRD PRO TUNDRA
    FIFTEEN52 wheels Toyo RT Trails 35” Random other things
    sjs0433[QUOTED] and Yaboy like this.
  10. Jan 24, 2024 at 10:00 AM
    #4300
    jachal
    jachal jachallen
    andy
    FLX NY
  11. Jan 24, 2024 at 10:05 AM
    #4301
    jachal
    jachal jachallen
    andy
    FLX NY
    i now see there’s two goodyear wrangler territory in 315/70r17, the only differences being the weight, 56 lbs vs 52lbs, and a tread width of 8.7 vs 9.2 — but the 17 in. diameter and 1k max load rating differences still apply. hope this clarifies.
  12. Jan 24, 2024 at 12:09 PM
    #4302
    CT303
    CT303 New Member
    2024 Tundra Capstone w 3” TRD Lift
    3” TRD Lift. 35” Black Rhino 20” Wheels with 35” Mickey Thompson Baja
    YO!
    Just purchased a 2024 Capstone and had the factory TRD 3" lift put on with 20" Black Rhino Wheels and 35" Mickey Thompsons.
    Had no idea how expensive these can be. Ugh.
    • I weighed the truck before the lift and it was 7220 and after it was 6440. Leads me to believe I did it wrong or a bad scale but I wanted to see how much weight the lift added.
    • MPG went from about 18 to 12.
    • Factory lift removed the dynamic from air spoiler
    Few other mods:
    • OEM Black chrome exhaust
    • OEM Bed extender
    • Window tint
    • OEM Black Tundra lettering
    • OEM Door sill guards
    • OEM Go pro truck mount
    • OEM Warranty extension (from a contact I got on this forum)
    • I WANT the OEM Trailer Back up Camera (but cant find it in stock anywhere)
    • Just ordered the Diamondback Tonneau cover and will post more photos once installed
    Questions for this awesome community! (just joined and love seeing all of this)
    1.) Should I put the TRD performance badge on the wheel center caps? See photo with and without. Toyota sells these for $70 a pop. Just for looks.
    2.) I was looking at Racing Designs Red Brake caliper covers. Would that look better than the stock ones? https://www.roughcountry.com/product/tundra-brake-caliper-cover-71152
    3.) Looking at a light bar from Baja Designs for the center grill. Baja any good? Yellow or White? https://theyotagarage.com/products/...ro-grille-center-light-kit-2022-toyota-tundra
    4.) MY BIGGEST QUESTION: Do I leave the Capstone grill with all the chrome or do the TRD grill? https://theyotagarage.com/products/trd-pro-grille-2022-toyota-tundra
    If you want to comment on ANY or ALL of these I welcome it. THANK YOU ALL for the posts as I learned a lot from this community before buying and owed it to you all to share mine.
  13. Jan 24, 2024 at 4:00 PM
    #4303
    JP_Trex
    JP_Trex New Member
    Finally get to post in this thread.
    TREX Wheels T200 Forged Monoblock in Machined Clear finish. 20X9 +18
    Nitto Ridge Grappler 295/60/20
    Rough Country N3 2" Level Kit Front
    Cornfed Suspension 1" Spacer Rear
    Dfrink, Yaboy, brtnstrns and 3 others like this.
  14. Jan 25, 2024 at 6:20 AM
    #4304
    4lo Toys
    4lo Toys New Member
    Andrew
    Are you getting the rub on the sway bar everyone else is talking about with the TRD sway bar drop?
  15. Jan 25, 2024 at 6:55 AM
    #4305
    4lo Toys
    4lo Toys New Member
    Andrew
    Truck looks great, so few 6.5' beds. Thats the only reason I am upgrading from my 2014 is to get the CrewMax and my 6.5' bed.
    Did you have rubbing on the sway bar with this setup?
  16. Jan 25, 2024 at 6:07 PM
    #4306
    FNWheels
    FNWheels New Member
    Dustin
    2005 Tundra and 2019 Tundra
    Hi @arrampico
    Regarding the load rating - more often than not the tire load rating is going to be higher than the wheel load rating (for almost every vehicle, not just the Tundra). This doesn't necessarily present a safety issue as long as both the tire and the wheel load rating exceed the axle rating for the vehicle. The axle rating is denoted on your VIN placard in your door jam under GAWR FRT (front axle rating) and GAWR RR (rear axle rating).
    You are also correct that the load rating for the OEM 265/70R18 Yokohama Geolandar tires is 2,756lbs per tire.
    However, please note that the OEM 245/75R18 Yokohama Geolandar, the OEM 265/60R20 Yokohama Geolandar / Bridgestone Dueler H/T 685 / Falken Wildpeak A/T3W and the OEM 265/50R22 Bridgestone Dueler H/T 685 tires all have load ratings of 2,469lbs per tire.
    Our 18x9" +20 6x139 FN BFD flow formed wheels have a load rating of 2,500lbs as tested with up to a 35" tire diameter. It's important to note that we tested with a 35" tire diameter, since larger tire diameters exert more stress and load onto the wheel. OEM tire diameter is 32.5", so the load rating for our wheels would be comparatively higher if we had only tested with up to a 33" tire diameter. Also, it's worth noting we have two new 17" wheel designs that were engineered to handle up to 37" diameter tires while maintaining a robust load rating (more info here: https://www.fnwheels.com/17-five-star-and-six-shooter-new-fitments-available-now/).
    Back to the axle rating vs. wheel/tire load rating:
    The Tundra GAWR rating is approximately 4,100lbs. The front or rear GAWR could be a little lighter depending on the trim level and whether the truck is a 4x2 or a 4x4. 4,100lbs is a good approximation and is rounded up from the heaviest number we have seen which is actually 4,080 lbs.
    There are two wheels and tires per axle on a Tundra, so you multiple the wheel load rating x2 to compare to the axle rating. The load rating of our 18x9" BFD flow formed wheels is 2,500lbs per wheel which equates to 5,000lbs per axle. The BFD exceeds the axle rating by approximately 22%. As long as you don't overload the truck and exceed the axle rating (which could potentially snap an axle as well), you won't have any safety concerns or issues with the BFDs.
    The same methodology and standards apply to the tire load ratings, which is why the Tundra doesn't blow out the tires with the 2,469lbs load rating (when properly inflated of course). 2,469lbs per tire x 2 tires per axle = 4,938lbs load rating (exceeds the axle rating of 4,100lbs by approximately 20%).
    Since this is photo thread, I can't make this post without including some pictures of the 18x9" FN BFD flow formed wheels submitted recently by customers with 2022 and 2023 Tundras. :):thumbsup:
    2023 Toyota Tundra SR5 TRD Offroad CrewMax Supersonic Red
    Ironman 2.5" lift (F/R)
    18x9" +20 6x139.7 (95mm hub centric) FN BFD Flow Formed matte black wheels
    LT285/75R18 Goodyear Wrangler Duratrac Tires
    Daniel 2023 Tundra Red FN BFD Flow Formed 18x9 +20 6x139.7 FNBFD89639205 - 1200.jpg
    2023 Toyota Tundra SR Crew Max Celestial Silver Metallic
    OEM suspension / ride height
    18x9" +20 6x139.7 (95mm hub centric) FN BFD Flow Formed matte bronze wheels
    P275/65R18 Goodyear Wrangler All Terrain Tires
    Chris C 2023 Tundra silver 18x9 +20 BFD flow formed matte bronze FNBFD89639208 - 1200.jpg
    2023 Toyota Tundra SR5 Double Cab Celestial Silver Metallic
    18x9" +20 6x139.7 (95mm hub centric) FN BFD Flow Formed graphite gunmetal wheels
    LT285/65R18 BFG All Terrain KO2 tires
    Mike 2023 Tundra Silver 18x9” +20 6x139.7 BFD Graphite Gunmetal FNBFD89639206 (5) -1200.jpg
    2023 Tundra Silver 18x9” +20 6x139.7 BFD Graphite FNBFD89639206 without center cap - 1200.jpg
    Mike 2023 Tundra Silver 18x9” +20 6x139.7 BFD Graphite Gunmetal FNBFD89639206 (4) -1200.jpg
    2022 Toyota Tundra SR5 Crewmax Lunar Rock
    LT275/70R18 Toyo Open Country R/T Trail tires
    2023 Tundra Lunar Rock 18x9 20 6x139.7 BFD graphite FNBFD89639206 1200x800.jpg
  17. Jan 25, 2024 at 6:56 PM
    #4307
    royaldouchebag
    royaldouchebag New Member
    G
    2024 Limited Crewmax 6.5 TRD OR
    3” factory lift
    2024 limited crewmax with 6.5 bed, TRD OR and 3” factory lift coming next month.
    I think I read every page of this thread and now can’t keep it all straight. My plan was method 705s 18x9 +18 with 305/70/R18 ST Maxx for summer and 285/75/R18 yoko geloander at hd studded for winter. Not interested in cutting. Local shop suggesting 295/70/R18 yokos on the methods for the summer, and keeping 20” stock rims with 275/65/20 studded yokos for winter. Shop thinks that’s biggest without cutting. I’m concerned I spend $4-5k on undersized tires. Thoughts?
  18. Jan 25, 2024 at 7:06 PM
    #4308
    jachal
    jachal jachallen
    andy
    FLX NY
    my thoughts are run AT’s year round
    22platitundy likes this.
  19. Jan 25, 2024 at 7:10 PM
    #4309
    royaldouchebag
    G
    3” factory lift
    I hear you and appreciate the response. I just live on a rough road that requires studded tires or I can’t get home some days. I could just swap out tires on the 18s seasonally, but easier with two sets of rims. I don’t really want to buy two sets of rims, so thought maybe I could make the stock TRDs work.
    @Mikeeemoore - I see you did 295/65/20 with only mudflap rub on stock rims with the 3” lift. If this was in a snowy area would you feel you have enough clearance? I need to stud mine and live on a steep dirt road that is snow covered Nov-march.
    jachal[QUOTED] and doublethebass like this.
  20. Jan 25, 2024 at 11:49 PM
    #4310
    philsam33
    philsam33 New Member
    Phil
    2024 White Tundra Limited TRD Off-Road
    TRD 3” Lift, 37” BFG KO2’s, 17” Method 315 Machined
    IMG_4816.jpg 24 Limited TRD Off-Road
    TRD 3” Lift
    37” BFG KO2’s
    17” Method 315 0 Offset
    Horn Chop to fit
  21. Jan 26, 2024 at 5:37 AM
    #4311
    the_rooster
    the_rooster New Member
    2024 White Tundra SR5 CrewMax
    Hello all. I have a stock 2024 SR5 CrewMax and am wanting to know what tires will fit without any lift or level. I want a 17" wheel and looking at "pizza cutter" tires such as a 255/80/17. Does anyone know if that will fit without rubbing? Also, what offset would work for this setup? Leaning toward the RRW RR6-H.
    Thanks!
  22. Jan 26, 2024 at 10:11 AM
    #4312
    Northern Toyota
    Northern Toyota New Member
    2023 Tundra TRD Off Road, 2022 Tacoma TRD off road premium
    Tires and bilstein
    I ran my 295/70/18 before my 1” level. No issues. 255/80/17 would look small I would think. A lot of Tacoma owners run this size
  23. Jan 26, 2024 at 11:00 AM
    #4313
    the_rooster
    Yeah, I think the main difference between the two is the tread width, which is just over an inch wider for a 295 vs 255. The 80 size is still a 33'' height. In other words, the 255/80/17 would just look a bit skinnier from the front and the same from the side.
    Do you think wheel offset would play a factor in this?
    Thanks!
  24. Jan 26, 2024 at 11:21 AM
    #4314
    4genRunner
    4genRunner New Member
    Southwestern MO
    2022 SR5 CrewMax TRD OR 4x4 CSM
    RB20's, Extang Xceed Cover, Tint.
    Just FYI, a 295/70/18 is a 34.3" tall tire, so it's a little over an inch taller than a 255/80/17.
  25. Jan 26, 2024 at 11:38 AM
    #4315
    the_rooster
    Oh ok, I was using tiresize[dotcom] which says it's 33.3'' but I'm sure it depends on each tire, too.
    I may look into that size as well. Just don't want to do any cutting or a lift/level right now.
    Thanks
  26. Jan 26, 2024 at 11:53 AM
    #4316
    lapoolboy
    lapoolboy New Member
    Is the owner of this truck on here?
    arrampico likes this.
  27. Jan 26, 2024 at 12:23 PM
    #4317
    Northern Toyota
    Tires and bilstein
    Mine are 18”, if you’re doing a 295/70/17 it would be a smaller diameter. Every inch you go down in wheel diameter you have to go up 5% on the aspect ratio. So the equivalent would be a 295/75/17.
    The sidewall of my falkens say 34.5” x 11.5”
    once again they fit on a stock sr5 trd off road.
  28. Jan 26, 2024 at 2:26 PM
    #4318
    creynol6
    creynol6 New Member
    Southeast
    '24 SR5 CrewMax
    Long-time lurker, this thread has been very helpful in deciding which route to go.
    Calling this my "phase one" until I decide on a lift kit. 18in Method 318s w some 33in Continental TerrainContacts. Truck is leveled w Fabtech's 1.5in front level kit.
    jachal, Texastaco11 and 4mm like this.
  29. Jan 26, 2024 at 3:25 PM
    #4319
    Magnetic1
    Magnetic1 New Member
    Int
    Looks good
  30. Jan 27, 2024 at 12:32 PM
    #4320
    Minarets
    Minarets New Member
    Nashville
    2021 TRD PRO
    This looks great on the capstone.
    Some of the TRD lifts with 35s still look like too much lift or too much wheel well. That looks fantastic
    CT303[QUOTED] likes this.
