GEN 3 (2022+) Wheels and Tires Photo thread
Discussion in 'Wheels & Tires' started by Tsquare, Jan 16, 2022.
  1. Dec 12, 2023 at 7:50 AM
    #4081
    pmichelsen
    pmichelsen New Member
    2013 Rock Warrior 2024 Platinum Hybrid
    I kind of hate this thread, just when I think I know what I want someone posts something else and I change my mind. :annoyed:
    Currently a stock 2024 Platinum, but I think I'm leaning toward a Cornfed 2/1 with 275/65/20 Recon Grapplers.
    Rigger, Paul499, Avy and 2 others like this.
  2. Dec 12, 2023 at 9:02 AM
    #4082
    kirkb
    kirkb Lurking Member
    DFW
    2024 Tundra Limited 4x4 WCP Nightshade
    Same. I must have changed my mind a dozen times since I started reading this thread in Oct.
    vichmr likes this.
  3. Dec 12, 2023 at 7:10 PM
    #4083
    vichmr
    vichmr New Member
    Scott
    Suwanee, GA & Highlands, NC
    '25 MGM Platinum TRD OR 6.5 w/ factory lift
    Go Rhino Dominator D6, Diamondback HD
    [/QUOTE]
    Are those amber LEDs up front? If so, where'd you get them?
  4. Dec 12, 2023 at 7:53 PM
    #4084
    vichmr
    vichmr New Member
    Scott
  5. Dec 12, 2023 at 8:01 PM
    #4085
    vichmr
    vichmr New Member
    Scott
    That's a great look, but I'd want to lift the front some - maybe 2" or so and perhaps 1" in the back. Looks awesome though!
  6. Dec 12, 2023 at 9:40 PM
    #4086
    Henry2019
    Henry2019 N/A
    Houston, Texas
    2019 SR5 CM CEMENT GREY
    3/1 Lift Kit 20X9 Fuel Assaults +1 295/60R20 Falken Wildpeak A/T3W
    ok
  7. Dec 14, 2023 at 6:05 AM
    #4087
    cvd2312
    cvd2312 New Member
    2023 CrewMax SR5 TRD OR
    What wheels are these and where did you get them?
  8. Dec 14, 2023 at 6:10 AM
    #4088
    Tom
    Tom New Member
    Got new set up.
  9. Dec 14, 2023 at 11:31 PM
    #4089
    Capecodpat
    Capecodpat New Member
    patrick
    2024 platinum tundra
    Does anyone have any experience with 305/70R17 tires? That is what is suggested from the company I got my wheels from. Not a size I hear about often. Any pros and cons? Will be in 2024 platinum with factory 3” lift.
  10. Dec 15, 2023 at 2:02 AM
    #4090
    Tom
    Tom New Member
    It’s a nice size to live with. Not too tall and wide. My two wheel drive Tundra never got stuck in sand while running these Goodyear MTR. But good luck finding them. For some reason it’s been on back order for awhile now.
  11. Dec 15, 2023 at 4:52 AM
    #4091
    kirkb
    DFW
    Nice. Is the truck color wind chill pearl?
    Blufin likes this.
  12. Dec 15, 2023 at 5:08 AM
    #4092
    Tom
    Tom New Member
    Yes.
    kirkb[QUOTED] likes this.
  13. Dec 15, 2023 at 5:10 AM
    #4093
    Blufin
    Blufin Seasoned member
    Bob
    Cape Cod,MA.
    23 Capstone
    Looks a little different with out the piller wrapped.
    Nice rig best of luck with it.
  14. Dec 15, 2023 at 10:33 AM
    #4094
    boomtime
    boomtime New Member
    So I got the TRD lift kit put on while I had 285/75r18 and the installing dealer had to disable PCS which also takes away radar cruise control. They sent me the tables. According to their tables my tire is 34.8" diameter and the limit is 34.6" (or an overall camera height increase of greater than 4").looks like 35x12.5 is a diameter of 34.5" so I am just over by 0.3". Actually if you look at other acceptable diameters 34.6" is good so I'm only 0.3" over. I'm hoping I can find someone local to swap wheels and tires with me so I can go back and get PCS turned back on. They said they'll do it for free but they just don't want the liability of doing something outside Toyotas specs. I'm in california zip code 91020 if anyone wants to help out :)
  15. Dec 15, 2023 at 1:55 PM
    #4095
    boomtime
    boomtime New Member
    A couple pics:
    Siopao, forzamrit, Markus and 2 others like this.
  16. Dec 15, 2023 at 8:01 PM
    #4096
    Jnickle25
    Jnickle25 New Member
    2022 Tundra sr5 trd sport black
    Put new tires 275/65/20 on my TRD sport. No level/lift, stock suspension. No rubbing or issues. Liking the new look so far.
    boomtime, Nashtucky, Jorts and 2 others like this.
  17. Dec 16, 2023 at 3:39 AM
    #4097
    Blufin
    Bob
    Cape Cod,MA.
    23 Capstone
    Here are the real world specs on your tires, the 3" factory lift is actually 2.5" so you maybe compliant to the cruise control specs.FYI.
    boomtime[QUOTED] likes this.
  18. Dec 16, 2023 at 5:31 AM
    #4098
    boomtime
    boomtime New Member
    The dealer goes off of a spec sheet from Toyota and they won't budge. They don't care about real world vs what's on the spec sheet. If the sheet says 285/75r18 and the lift gives an overall front end lift of over 4 inches they won't calibrate it. I tried to tell them I won't hold anyone liable for anything but they won't budge over the 0.1 inch height exceedance. My rig rubs the sway bar at full lock so I may get smaller tires just because of that issue too.
  19. Dec 16, 2023 at 7:29 AM
    #4099
    boomtime
    boomtime New Member
    So with 285/75-18 on the trd pro rims with the trd lift kit here is the clearance between the tire and the sway bar. Debating on new rims or smaller tires. Smaller in width and diameter to be safe...
    This is the point where the tire is rubbing the sway bar under certain maneuvers
  20. Dec 16, 2023 at 9:23 AM
    #4100
    ryanjay11
    ryanjay11 New Member
    Are those amber LEDs up front? If so, where'd you get them?[/QUOTE]
    They are these. I'm very happy with them, but I'm putting on a C4 full bumper in a couple of weeks, so I'll post them in the classifieds shortly.
    19PlatinumCrew likes this.
  21. Dec 16, 2023 at 11:59 AM
    #4101
    GojiraPRO
    GojiraPRO New Member
    2022 White Tundra TRD PRO
    Stock
    Curious and I’m sure this has been asked already, but what PSI do you guys run at with 295/70/18?
    I just got my Baja Boss on my TRD pro 22.
    It rode really stiff and realized they had the PSI a little too high but also don’t want to undershoot it.
  22. Dec 16, 2023 at 12:41 PM
    #4102
    Northern Toyota
    Northern Toyota New Member
    2023 Tundra TRD Off Road, 2022 Tacoma TRD off road premium
    Tires and bilstein
    Had mine at stock psi then just bumped them up to 38-39
  23. Dec 16, 2023 at 1:47 PM
    #4103
    Blufin
    Bob
    Cape Cod,MA.
    23 Capstone
    With them being sticklers for not calibrating but yet they slide on letting you go with rubbing on the swaybar,hmmm I would bet my bottom dollar is the fact that they probably sold you the tires.
    Which is a liability,up here most tire shops won't install tires with a 3% closeness range due to insurance and liability...
    BTW your Rig looks great with the lift & nice color to!
  24. Dec 17, 2023 at 11:02 AM
    #4104
    Mrconnsmythe
    Mrconnsmythe New Member
    Saskatchewan, Canada
    2025 Tundra Ltd TRD OR WCP
    WheelsCo. Replica's. +15 offset.
  25. Dec 17, 2023 at 9:19 PM
    #4105
    Welshflynavy
    Welshflynavy Flyin Jets!
    Austin
    Pensacola
    24 MGM Limited TRD OR
    Picking up my 24 limited OR tomorrow. Going to order some 295/65/20 Toyo AT3s. From what I’ve seen they should have no rubbing issues on stock setup
  26. Dec 19, 2023 at 9:04 AM
    #4106
    1794TundraOC
    1794TundraOC New Member
    Luis
    2024 Black Tundra 1794 Edition
    Paragon Tonneau Cover
    Is anyone running raceline wheels? Its odd I cant find many companies that run a positive offset and I dont want to be running Methods like everyone else is.
  27. Dec 19, 2023 at 9:28 AM
    #4107
    brtnstrns
    brtnstrns New Member
    2024 Tundra Platinum HV; 2022 Polestar 2
    I had Raceline 950b Gauge wheels on my Tacoma because I could get them in negative offset to get the nice looking concave face. Unfortunately 0 or positive offset in that wheel looks kind of dumb in my opinion because you lose the concavity which is the entire selling point of the wheel.
    Not a huge fan of any of their other offerings really.
    My plan is to go with Brink wheels for the Tundra in a +18 offset. Get a decent concavity without a ton of wheel poke and not everyone is running them. Plus they look about as close to an OEM style wheel as you can get compared to most truck wheels.
    Paul499, Jorts and ytank1 like this.
  28. Dec 19, 2023 at 9:31 AM
    #4108
    1794TundraOC
    Luis
    Yah I am not a huge fan of the concave stuff but its more of a offset issue. The poke is kinda a bit on the 0 and not a lot of companies offer + offset. I was looking at some KMC GRS wheels but same thing just 0 offset. I refuse to go Method like the masses.
    Blufin likes this.
  29. Dec 19, 2023 at 3:23 PM
    #4109
    boomtime
    boomtime New Member
    Went down from 285/75 r18 to 275/70 r18 to avoid rubbing the sway bar with the trd lift kit... I'm happy with it. Now I need to sell my set of barely used 285/75 r18... let me know if you're interested.
    4lo Toys and Markus like this.
  30. Dec 19, 2023 at 4:55 PM
    #4110
    Blufin
    Bob
    Cape Cod,MA.
    23 Capstone
    Your Rig looks great Man,glade you got new sneakers that ain't gonna rub!
    Best of luck with it.
    Cheers!
