GEN 3 (2022+) Wheels and Tires Photo thread
Discussion in 'Wheels & Tires' started by Tsquare, Jan 16, 2022.
  1. Oct 18, 2023 at 7:47 AM
    #3841
    Morning_Rock
    Morning_Rock New Member
    I believe 3rd Gen Tundras are lug-centric. I do have hub-centric rings as well, but it didn't help with the vibration.
  2. Oct 18, 2023 at 12:37 PM
    #3842
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    Cooper Discoverer AT3 XLT 275/65/20 (One size up in width and in sidewall from OEM 265/60/20) About 34"
    Lebo and boomtime like this.
  3. Oct 19, 2023 at 9:58 AM
    #3843
    Livin
    Livin New Member
    Kevin
    24 Black Pro
    Looking to swap out tires on pro ,, hard to find anything decent in a less than 10 ply ! Any suggestions?
  4. Oct 19, 2023 at 5:25 PM
    #3844
    GojiraPRO
    GojiraPRO New Member
    2022 White Tundra TRD PRO
    Stock
    Guys..I have scanned this thread for a year now since owning my 22 TRD Pro, and im still undecided on the size I want, torn between the
    295/70r18 or 305s in the Toyo open country, with stock suspension no lift or anything. I don't plan on adding a lift as I want it to fit in my garage, its winter 6 months of the year here in Canada, lots of snow in my province as well. Wanted your guys opinion as I honestly cant decide. The look of the 35s definitely fill out the truck better, but I don't want any rub at any lockout or anything without removing anything either as I cant legally take off my mudflaps, also dont want to worry too much about the speedo, (that part isnt a a big deal). I like the ride of the OEM feel as well, and the acceleration of course, a smaller tire of course would be a little lighter as well. Definitely pros and cons to both. Having snow here most the time, the 295s might be better? Sorry completely new to this!
    I have seen some TRD Pros on this thread with 295s on and it still looks alot better than stock. Thoughts?
    WesternDawg likes this.
  5. Oct 19, 2023 at 5:35 PM
    #3845
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I have Toyos in 295 on 20” wheels, they are more like 34” tall but do look proper.
    These tires are 10 ply so they are heavier and this will probably be felt in the mileage.
    if you use the OE wheels, you will probably be fine but an aftermarket wheel will usually have an offset that pushes wheels out. This will be where the rubbing will occur.
    nodak67 and in_the_mud like this.
  6. Oct 19, 2023 at 5:41 PM
    #3846
    GojiraPRO
    Stock
    Thanks! I plan to use my OEM wheels as I love the look. Sorry I forgot to mention that, but yeah pretty much the whole truck will be stock except tire size. What Load did you go with?
  7. Oct 19, 2023 at 5:47 PM
    #3847
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Mine are LT295/60/R20. 126/123S 10ply
    I think they weigh 60lbs and my wheels weigh 27lbs.
    I have all 5 wheels the same.
  8. Oct 19, 2023 at 6:18 PM
    #3848
    cvd2312
    cvd2312 New Member
    2023 CrewMax SR5 TRD OR
    Nitto Recon Grapplers come in an SL Load range for size 295/70/18. Only 53 lbs, by far the lightest tire in that size.
  9. Oct 19, 2023 at 6:34 PM
    #3849
    DMackler
    DMackler New Member
    Dustin
    Burleson, Texas
    2023 Celestial Tundra CM TRD OR
    Those recon grapplers are probably your best bet. General also makes the grabber atx in a 275/70/18 in a SL. That's the tire on the F150 tremor. Not much bigger than stock, just a much better quality tire than the factory falkens
    Livin[QUOTED] likes this.
  10. Oct 19, 2023 at 6:56 PM
    #3850
    81trekker
    81trekker New Member
    2024 Platinum 4x4 iForce Max
    24’ Platinum Max with King 3.0 IBP shocks, Built Right upper arms, Method 305 17” +25mm, 315/70/17 Toyo RT
  11. Oct 19, 2023 at 7:09 PM
    #3851
    81trekker
    Rides night and day better than the AVS stuff it came with
    akira and Yaboy like this.
  12. Oct 19, 2023 at 7:12 PM
    #3852
    tkcowboy45
    tkcowboy45 New Member
    24 Limited TRD Off-Road with TRD factory lift. Icon Rebound 18” +25, 295/70/18 Falken Wildpeaks.
    Hoody, WesternDawg and Yaboy like this.
  13. Oct 19, 2023 at 7:15 PM
    #3853
    tkcowboy45
    I had these Falkens on a previous truck for about 5 days before I hit a deer. Totaled truck so moved them to this new Tundra. Love the look but man they ride rough. I can feel every pebble I hit. Considering pulling off and going to a 35x12.5 D rated tire. Anybody make that move that can say how much better ride was?
  14. Oct 19, 2023 at 7:17 PM
    #3854
    Northern Toyota
    Northern Toyota New Member
    2023 Tundra TRD Off Road, 2022 Tacoma TRD off road premium
    Tires and bilstein
    What’s your psi ?
  15. Oct 19, 2023 at 7:24 PM
    #3855
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    When I put my Toyos on, the ride was a bit rough. Then I put 1” westcott spacers in the rear not expecting much other than a bit of rake. The rear suspension came alive and the ride has transformed. I can’t explain it but it is so much better now.
    My guess is that the rear shocks are able to work now.
  16. Oct 19, 2023 at 7:26 PM
    #3856
    tkcowboy45
    Was running 36 but actually ran them down to 32 this am. I know some will roast me for that low. It did help a bit though.
  17. Oct 19, 2023 at 7:29 PM
    #3857
    Northern Toyota
    Tires and bilstein
    Mine are around 34 cold. Likely drop lower now that temps have dropped. I’ve only ever ran E load tires on all my trucks and I find these in an 18” at least, ride smoother than my last set of ko2’s but they were 20”
  18. Oct 19, 2023 at 8:20 PM
    #3858
    Dirtsurfer83
    Dirtsurfer83 New Member
    Olalla, WA
    '23 Tundra TRD
    Dobinsons IMS 2/1 Method 703 Toyo RT Trail 35x12.50r17
    IMG_5396.jpg IMG_5395.jpg Dobinson IMS 2/1
    Method 703 17x8.5 0 offset
    Toyo RT trail 35x12.50R17
    TUNDRA117!!, Azrsx, mayan and 2 others like this.
  19. Oct 20, 2023 at 3:57 AM
    #3859
    Livin
    Livin New Member
    Kevin
    24 Black Pro
    Thanks ! Don’t need much bigger ,, I’ll look into those
    Troyboy84 and DMackler[QUOTED] like this.
  20. Oct 20, 2023 at 4:09 AM
    #3860
    DMackler
    DMackler New Member
    Dustin
    Burleson, Texas
    I've noticed that discount tire only lists the 10 ply on their site, but tire rack and others show the SL tire. There is also a Goodyear in a 275/70/18 that is a LR C, it's the tire being put on the new Silverado zr2. It's much more aggressive looking compared to the general.
    Livin[QUOTED] and Troyboy84 like this.
  21. Oct 20, 2023 at 7:08 AM
    #3861
    Livin
    Livin New Member
    Kevin
    24 Black Pro
    Yeah the wranglers ,,,
  22. Oct 21, 2023 at 12:48 PM
    #3862
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Where did you get the mud colored slicks? Looks great with the silver paint.
    Tantal and HiUp like this.
  23. Oct 21, 2023 at 4:27 PM
    #3863
    GojiraPRO
    Stock
    Beautiful truck. I am on the fence about 295s or going straight to 35s, but I want value my MPG and ride quality. Also dont want any rubbing at all, dont plan to put a lift on my stock 2022 TRD PRO. Did you do anything to yours?
  24. Oct 21, 2023 at 5:17 PM
    #3864
    GojiraPRO
    Stock
    Wow I am on the fence right now between 295s or 305s. Leaning towards 295 now. this is on the stock TRD Pro suspension and factory lift correct? How does it ride?
  25. Oct 21, 2023 at 5:23 PM
    #3865
    GojiraPRO
    Stock
    How does it ride with the 295s? I have a pro as well and debating 295s in the Toyos! dont want any rubbing or anything on stock TRD pro :)
    drewpweinerMD[QUOTED] likes this.
  26. Oct 21, 2023 at 6:48 PM
    #3866
    TundrX
    TundrX New Member
    Toan
    Sacramento, CA
    2024 Tundra Hybrid Platinum
    A sneak peak, if you will. Gotta get ‘em cleaned up from after install. Haven’t seen this specific model on a truck before, so I took a gamble.
    Volk TE37SB 18x8.5 +22
    Cooper Discoverer AT3 XLT 295/75/18
  27. Oct 21, 2023 at 8:31 PM
    #3867
    Cova_84
    Cova_84 New Member
    Stephen
    Southern California
    2024 Terra Tundra TRD Pro
    Nitto Recon Grappler LT295/70/17 Taco Vinyl Heritage front grill vinyl Tint 50% windshield 15% all other windows. BAKFlip MX4 Bed Cover
    295s are perfect. No modifications other than tint and tires. The ride is great. I did notice some road noise however it isn’t bad at all. Also, since they’re 70 vs 65, it had a tad to the height but again, nothing too bad.
    Tundrastruck91 likes this.
  28. Oct 22, 2023 at 7:04 AM
    #3868
    Northern Toyota
    Tires and bilstein
    Castrol super clean
    Eurodriver likes this.
  29. Oct 22, 2023 at 9:29 AM
    #3869
    ColumbiaGorge
    ColumbiaGorge New Member
    Joe
    Columbia Gorge
    24 Limited
    I can’t remember if I’ve said it on this thread before but if they’re always coming out looking dirty I found a solution that works for me detailing cars years ago. Give them a good cleaning and put some tire shine on. After an hour (or next day if you want) pressure wash the tire shine off. I’ve found it returns it to that new tire look without the shininess.
    Eurodriver[QUOTED] likes this.
  30. Oct 23, 2023 at 5:08 AM
    #3870
    johnson156
    johnson156 New Member
    Ron
    2022 Lunar Rock TRD OR
    35/12.5/17 Toyo open country A/T
    RRW RS2-H
    iiawah808 likes this.
