GEN 3 (2022+) Wheels and Tires Photo thread
Discussion in 'Wheels & Tires' started by Tsquare, Jan 16, 2022.
  1. Aug 31, 2023 at 12:50 PM
    #3661
    osu1978
    osu1978 New Member
    Method makes the 318 and 319 in 18x8.5 +40
    Method makes the 703, 705, 706 in 17x8.5 +35
    Neither should give you crazy poke since your stock offset is +60 I believe.
  2. Aug 31, 2023 at 1:51 PM
    #3662
    Callmedaddy
    Callmedaddy New Member
    23 blue limited 4x4
    saw that one already looking for others some more.
  3. Sep 2, 2023 at 2:39 PM
    #3663
    ArticTundra
    ArticTundra New Member
    Cold
    Mickey Thompson Baja Boss AT
    35x12.5r17
    KMC summit 17’s with +18 offset
    little too much poke for me, but it is what it is at this point. Love the look otherwise
    dagsom, urmomspad, ytank1 and 4 others like this.
  4. Sep 3, 2023 at 6:21 AM
    #3664
    Blufin
    Blufin Seasoned member
    Bob
    Cape Cod,MA.
    23 Capstone
  5. Sep 6, 2023 at 5:47 AM
    #3665
    scw156
    scw156 New Member
    Dumbass here. For all of you who got new tires and an alignment on the TRD PRO, did you have the shop just do an alignment or did you provide them with the Toyota alignment/handling specifications for the Pro? I'm upgrading from stock tires to 35x12.5x18 and I don't know if they'll look at me like an alien if i try to hand them the alignment spec document to follow.
    KClav likes this.
  6. Sep 6, 2023 at 6:50 AM
    #3666
    drewpweinerMD
    drewpweinerMD MPG’s are for your moms Prius.
    Jeremy
    2024 Limited TRD OR
    RB20 Slims, BAK X4s, Fabtech Level, Cooper 35's
    Not dumb - great question _ I would like to see how others respond as I need to cross that bridge shortly...
  7. Sep 6, 2023 at 10:41 AM
    #3667
    kilocharlie106
    kilocharlie106 mmmm Bourbon
    TRD Pro in LR
    The Pro specs are not correct, outside tire wear occurs. Try to get them to get your camber below 0.4 on each side.
    ReCKzX and drewpweinerMD like this.
  8. Sep 6, 2023 at 12:47 PM
    #3668
    FLKX
    FLKX New Member
    vichmr likes this.
  9. Sep 6, 2023 at 1:27 PM
    #3669
    osu1978
    osu1978 New Member
    My Pro alignment was a mess day one so I went in a week or so later and had an alignment shop adjust to .4 camber and .10 toe.
  10. Sep 6, 2023 at 4:40 PM
    #3670
    PapaDave418
    PapaDave418 A Dude who knows a Dude
    Dave
    North Idaho
    3rd Gen Limited TRD
    37’s—PullKitchen--KB Voodoo Rack & Full Ext Cargo Tray
    I recently put on 37’s and used one of my 35’s as a spare. A friend gave me an older Lexus 17” wheel and I mounted it up today. The spare is a 265/70R18 at 32.6” which is a long way from 37”, so I figured my 315/70R17 (34.4”) is closer. A 37 will not fit under the 5.5’ bed.
    I mounted up a 35 and it leaves just under an inch of room from the pan bar. The tire is snug against the hitch and I aired down to 12psi to help a little. BTW I have onboard air if I need to use the spare. I don’t foresee the width of the tire being an issue. I hit some speed bumps hard and the pan bar doesn’t touch so far. Yeah, speed bump testing haha
    6C6CAF22-B7B4-4560-8804-795A0C4B2CAF.jpg 142EA73F-923F-44F1-B44F-B32A524FA5EB.jpg 269C5F3E-D30E-47FA-8F0B-876DFB5D08B1.jpg 9E343B26-5FAA-4C3F-859D-25224EA09FC0.jpg
    Black22tundra likes this.
  11. Sep 6, 2023 at 4:43 PM
    #3671
    Bourbonator
    Bourbonator New Member
    North ID
    '23 LE CM 6.5
    Is it because of the lift, different UCAs, lower offset wheels? Would the alignment specs for the pro be useful for others with lifts, aftermarket UCAs, and lower offset wheels? I don't have any of the above, but it seems at this point a lot of others have, and no one likes burning through sets of expensive tires needlessly.
  12. Sep 6, 2023 at 8:36 PM
    #3672
    KiloOps
    KiloOps New Member
    Dustin
    2023 Army Green Tundra Limited TRD Off Road
    Purchased the truck on Jun 10, 2023, modifications will be made!
    Started with the factory 2023 TRD Off Road 20" with Falken Wildpeak AT3W 265/60r20 tires.
    Now sitting on 17" Raceline 953BZ Krank wheels (17x8.5" with +18 Offset) and Falken Wildpeak AT3W 37x12.5r17.
    Just added the Wilco spare tire mount yesterday. It mounts to the factory bed rail on the back of the cab.
    dan81, BoomBoomGanoom, Cap24 and 3 others like this.
  13. Sep 6, 2023 at 10:18 PM
    #3673
    Ben Dover
    Ben Dover New Member
    That looks great !!
  14. Sep 9, 2023 at 10:15 AM
    #3674
    Trdtundra77
    Trdtundra77 New Member
    Central Il
    2022 Tundra limited 4X4
    Looking at this setup for my 22 double cab limited 4x4 stock suspension
    Lt285/65/18 BFG k02
    Method MR305NV +18 Double black
    Will it fit with no issues or rubbing?
    Thank you
    Yaboy likes this.
  15. Sep 9, 2023 at 11:35 AM
    #3675
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    You’ll be fine
  16. Sep 9, 2023 at 11:37 AM
    #3676
    Trdtundra77
    Central Il
    Thank you !! I'll post pics once I get them mounted up
  17. Sep 9, 2023 at 12:37 PM
    #3677
    81trekker
    81trekker New Member
    2024 Platinum 4x4 iForce Max
    Hi guys I’m new here and have been searching like crazy for a pictures of a Tundra with KMC GRS wheels in a +18mm with no luck… Ideally wind chill pearl with black rims. Thanks!
  18. Sep 9, 2023 at 6:02 PM
    #3678
    Joshuak175
    Joshuak175 New Member
    How’s the ride quality compared to stock?
  19. Sep 10, 2023 at 6:24 AM
    #3679
    Blufin
    Bob
    Cape Cod,MA.
    23 Capstone
    In a real bind here and really need some tire Guru Help please!!!
    I'm looking to get new tires with some sidewall meat I don't really want to stuff 35X12.5 and do the minor cutting of the plastic wheelwell guards and the tire stop, I can/could do it I'm not worried about the inner astectics of it out of site out of mind,but even if I do it'll look completely
    un proportionately stuffed in the well with stock suspension to say the least.
    The tires that came with it are Bridgestone Dueler H/T 260/60R22 the sidewall is 3.25 which ain't worth a shit for hitting potholes or a chipmunk they are good for city driving and cruising pristine HWY's and ideal weather conditions but I do not trust them for New England winters or even light beach combing.
    Also the truck has AVS and don't want to lose that by lifting it (even with compatible lifts) the 3" OEM will remove the AVS capabilities,I really want to keep the stock rims I do like them,yeah maybe I'm asking for the world but I like them.
    Maybe my resources are limited but having zero luck finding 295/70 (or around that size) M/S, AT's there all friggin street tire that have no sidewall and no bite to the tread.
    Please my intentions are not to piss anyone off or offend i'm genuinely just asking for any and all advice it will be MASSIVELY AND TRULY HELPFUL AND APPRECIATED!
  20. Sep 10, 2023 at 8:35 AM
    #3680
    Morning_Rock
    Morning_Rock New Member
    Sitting on 17x8.5 -10 with 35x12.5.17 Toyo Open Country AT3
    Anyone running the same tires and getting a slight vibration at 60+mph?
    mayan, a_double, Yaboy and 2 others like this.
  21. Sep 10, 2023 at 2:41 PM
    #3681
    81trekker
    I just test fit a wheel off of my off road truck and have some questions. The wheel is a 17x8.5 trail ready bead lock with -25.4mm BS and has 37x12.5 BFG race tire. When I bolted it up the tire stuck a full 4” past the fender flair. I was thinking about using a 0mm wheel which would be exactly 1” narrower but it’s still sticking out 3” past the flair. My question is for guys with 0mm wheels does the 3” past the flair look like too much?
  22. Sep 10, 2023 at 2:57 PM
    #3682
    k96payne
    k96payne New Member
  23. Sep 10, 2023 at 5:47 PM
    #3683
    TundraMoe
    TundraMoe New Member
    2023 GMC Sierra Denali 3.0 Duramax
  24. Sep 11, 2023 at 8:39 AM
    #3684
    STEPBRO
    STEPBRO New Member
    2022 SR5 TRD OR
    Does it look to much for you? You can add TRD PRO flares to help get another 1" of coverage as well.
  25. Sep 11, 2023 at 9:50 AM
    #3685
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    Everyone's taste is different, but for me it would be a bit much. I like the stance, but only if there are flares to cover it up a bit.
    I think the widest available fender flares will be the Rough Country options. They have 3 options, depending if you like the rivet-look or not. They add about 2", so it will cover about half of your poke.
    I like the wheel & tire combo though.
  26. Sep 11, 2023 at 10:13 AM
    #3686
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    On my limited, I found about 5/8" to 3/4" more coverage with the TRD Pro flares so not a huge gain. The RC flares would certainly cover more of the poke.
  27. Sep 11, 2023 at 3:27 PM
    #3687
    Ardonsr
    Ardonsr New Member
    Sergio
    From Tampa to Massachusetts
    2023 Magnetic Gray Metallic 1794 TRD Off Road 4X4
    Has anybody done KO2 35x12.5x20 on the stock 2023 1794 TRD off-road rims or do you know if the tire would fit the stock rims?
  28. Sep 11, 2023 at 4:01 PM
    #3688
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    wayy too much for me. I was running 12.5's with 12mm offset and decided to add the sport flares, they cover about 80% of my tires now
    Boerseun likes this.
  29. Sep 11, 2023 at 5:25 PM
    #3689
    81trekker
    Just did another science experiment and bolted up a 0mm off set Trail Ready with a 35x12.5 tire… still had a lot of poke. Going to order some +18mm. I ordered the King 3.0 shock set this morning and some Built Right upper control arms from the Truck Shop SD. Can’t wait!
  30. Sep 11, 2023 at 6:19 PM
    #3690
    DexterL
    DexterL New Member
    0 offset is zero offset! Add in Agro tires and you get lots of poke!
