GEN 3 (2022+) Wheels and Tires Photo thread
Discussion in 'Wheels & Tires' started by Tsquare, Jan 16, 2022.
  1. Aug 22, 2023 at 7:26 PM
    #3631
    vomhorizon
    vomhorizon New Member
    Anyone running stock SR5 TRD OR wheels (18") on 34 or 35's? As I understand from reading this thread, stock wheels come with a pretty large + offset so was wondering if there would be issues rubbing or excessive poke. I'm looking to get rid of the stock michelin and upgrade to a bigger size and don't particularly mind the black/silver Toyota stock wheels so want to keep them.
  2. Aug 23, 2023 at 3:41 AM
    #3632
    DMackler
    DMackler New Member
    Dustin
    Burleson, Texas
    2023 Celestial Tundra CM TRD OR
    Lots of us are running that setup. I'm running 295/70/18 (~34") on the OEM 18s. I've ran them both bone stock and now with a 1.75" front level and 1" rear spacer.
    No rubbing or issues whatsoever with either setup. The high positive offset keeps the wheel/tire inside of the fender. An offset closer to 0 is when you start to see poke.
    With level
    Stock height
    mayan, BryMan83, Yaboy and 1 other person like this.
  3. Aug 23, 2023 at 5:28 AM
    #3633
    vomhorizon
    Thanks for the pictures and the reply.
    DMackler[QUOTED] likes this.
  4. Aug 23, 2023 at 8:18 AM
    #3634
    Callmedaddy
    Callmedaddy New Member
    23 blue limited 4x4
    Who here is running -10 17” wheels and 35 would love to see pictures for reference looking to order wheels and tires soon.
  5. Aug 24, 2023 at 7:04 PM
    #3635
    Sk8surfer
    Sk8surfer New Member
    22 tundra
    Softopper, running boards, window vents
  6. Aug 24, 2023 at 8:15 PM
    #3636
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    So I got a pair of LT235/75/15 AT3W Falkens today. I got the 10ply ones.
    These are not for the Tundra if you haven’t already figured that out:)
    These are for the Airstream! The Goodyears are 5 years old now so time for some new tires.
    Mitch09 and Black widow TRD like this.
  7. Aug 26, 2023 at 7:07 PM
    #3637
    ToyoWorld786
    ToyoWorld786 New Member
    2023 Black Limited TRD Off Road
    Hi all long time lurker finally made an account and joined. I’ve upgraded to 35x12.5x17 tores and 17x8.5 0 offset wheels. My question for those others with upgraded tires is has anyone stuffed a 35x12.5x18 or 17 in the factory spare location?? Seems it’s very hit or miss. If you do have them could you post a pic of how they sit to see how low they stick down? Don’t want to get caught 1000s of miles from home without a matching spare to get me back. I understand 295/70/18s fit but was trying to go for an exact match.
    Nashtucky, mayan, dan81 and 2 others like this.
  8. Aug 26, 2023 at 8:53 PM
    #3638
    ToyoWorld786
    Nope have to get a BMC for sure along with some trimming. Not particularly difficult to fit but does require some more modification
  9. Aug 26, 2023 at 8:54 PM
    #3639
    vomhorizon
    Posts in the thread below indicate that a true 35 will fit.
    https://www.tundras.com/threads/2022-anyone-stuffed-a-35-in-the-spare-tire-holder.101399/
  10. Aug 26, 2023 at 9:56 PM
    #3640
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    I’ve got a 35x12.5x20 Toyo MT on a stock tundra wheel in my spare location. I cut the rear centering mounts off so it centered up better
    iiawah808 likes this.
  11. Aug 27, 2023 at 9:54 AM
    #3641
    page09
    page09 New Member
    Edward
    My 2023 SR5 TRD OR
    Wheels: Method 305 NV double black 17x8.5 0 offset
    Tires: Nitto Ridge Graplers 35x12.5x17
    Westcott Design 3/1 lift kit.
    TRD PRO grill
    dan81, Yaboy, PBNB and 2 others like this.
  12. Aug 27, 2023 at 12:04 PM
    #3642
    iiawah808
    iiawah808 New Member
    Oahu, HI
    2022 iForce Tundra Limited TRD Offroad
    Currently Searching....
    Dexter, I must have totally missed it if you posted it up. But you were able to mount the 12.5 on the stock spare rim? I’m totally jumping on this if ao.
  13. Aug 27, 2023 at 10:26 PM
    #3643
    ToyoWorld786
    I asked discount tire if they would mount a 35x12.5 on the spare and they said no. The company wouldn’t allow it. I’m sure some private shops would do it though
    iiawah808[QUOTED] likes this.
  14. Aug 28, 2023 at 3:22 AM
    #3644
    DMackler
    DMackler New Member
    Dustin
    Burleson, Texas
    Many people are doing a 295/70/18 as a spare. Discount is willing to mount it up as the width of the factory rim falls within the specs of a 295 tire.
    The height difference from a 35x12.5 vs the 295/70/18 is negligible. Basically, the difference from a worn tire to a new one. There is a video floating around YouTube of a 3rd gen tundra guy doing exactly this and he shows the height difference. Very helpful video.
  15. Aug 28, 2023 at 6:05 AM
    #3645
    vomhorizon
    Would you, in case of a rear tire flat, still need to run the 34" spare in the front to avoid any issues with the vehicle or will the negligible size difference make it work even in rear wheel drive applications?
  16. Aug 28, 2023 at 7:20 AM
    #3646
    Eglitis416
    Eglitis416 New Member
    Justin
    2023 Sr5 Tundra
    Bought the truck last week.
    35” Micky Thompson Baja boss a/t
    17” method 305s
    Swapped the grill out
    Westcot lift
    Yaboy and PBNB like this.
  17. Aug 28, 2023 at 7:54 AM
    #3647
    dangeloc
    dangeloc New Member
    Looking for some advice. I have the 3"TRD lift. I'm looking to go to a 17"or18" rim. (Leaning towards RRW or Methods).I don't want crazy poke, I prefer slightly more than flush. I'm not sure what tires to go with. I want as close to stock weight as I can, and don't want to absolutely ruin my fuel economy. (i'm having a hard time breaking 12.3mpg now)
    What are your thoughts??
    jacquesc, TRD L Power and PBNB like this.
  18. Aug 28, 2023 at 8:25 AM
    #3648
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    Unfortunately as soon as you get to about a 34" tire in the commonly preferred brands (Falken, Toyo, Cooper AT3, BFG KO2 etc.) you will also get into a much heavier LT/E rated tire.
    I love the Cooper AT3 XLT which is heavy, but the AT3 4S is the exact same tread pattern but lighter side wall that comes in bigger sizes before going to LT/E only.
    My wheels are 20" so I can't give you the exact sizes in 17" or 18", but check out the AT3 S4 Coopers.
    Troyboy84 and dangeloc[QUOTED] like this.
  19. Aug 28, 2023 at 8:29 AM
    #3649
    DMackler
    DMackler New Member
    Dustin
    Burleson, Texas
    Personally, I think it's a negligible difference and would simply place it where the flat was. The overall difference is much less than a new vs worn mud tire. Those suckers can lose an inch in overall height, were only talking roughly 1/4" in height.
    An even better option is the 285/75/18. Little more narrow which will fit better under the truck and measures out almost identical to most 35x12.5 options.
    Troyboy84 and vomhorizon[QUOTED] like this.
  20. Aug 28, 2023 at 11:15 AM
    #3650
    DexterL
    DexterL New Member
    I put it on a stock TRD off-road wheel I bought off a member here that had been scratched up, so wider than the stock spare dinner plate
    vomhorizon and iiawah808[QUOTED] like this.
  21. Aug 28, 2023 at 4:41 PM
    #3651
    vomhorizon
    So I finally selected a size and got the new tires fitted this afternoon. I ended up keeping the stock Off Road 18" wheels and chose a 305x70 R18 (34.8) tire size. Wanted to keep tire weight under 70 lbs so went with E rated Micky Thomson Baja Legend EXP's (66 lbs).
    No noticeable rub either on the mud flaps or front liner in the front by the bumper. I don't think I'll need to remove flaps or trim the liner. I backed into multiple tight parking spots and took a couple of u turns to test out the tires at full lock and couldn't hear or feel any rub. They sit extremely close to the UCA's given the wheel offset especially at lock but I don't feel any discernible resistance at full lock (either side) nor hear anything. Is there a better way to test this? I don't think I've ever had rigs where the tires sit so close to the UCA's and I am a bit worried about this. The vehicle is not lifted but I do plan on getting a 1.5-2" lift with Toyota TRD UCA's. if there was rub on the UCA's would it be really noticeable like increased resistance when at lock or do I have to pay attention to this over time to see if there is discoloration on the UCA's?
    Troyboy84 likes this.
  22. Aug 28, 2023 at 6:58 PM
    #3652
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    I got some 1” Spider tracks spacers that would complement your setup. Get you further away from the UCA, but you’d have a small rub on the front mud flaps.
    vomhorizon likes this.
  23. Aug 28, 2023 at 7:03 PM
    #3653
    vomhorizon
    Thanks! I will definitely consider spacers but want to first determine whether this is a problem. I didn't have a passenger with me who could have hopped onto the drivers seat and moved the vehicle on full lock so I didn't have a great way to tell whether there was any contact. I certainly didn't feel or hear anything so am thinking that they clear since some significant contact at lock would have been felt and heard while making the turn. I would much rather let this be as is and deal with the spacer issue when I install the lift.
  24. Aug 28, 2023 at 7:30 PM
    #3654
    TRD L Power
    TRD L Power New Member
    2023 SR5 XP TRD Off-Road Army Green
    Just curious… what size tire do you have in these pics? Also, is this with the 3” TRD lift?
    (looks great)
  25. Aug 28, 2023 at 8:32 PM
    #3655
    vomhorizon
    Drove around some more including roundabouts, more u turns, and backing into parking lot. I do not feel any vibration, tire on metal contact or any different sound coming from the tires than normal. There's about a finger width between the edge of my tire and the closest point on the UCA. I'll continue to monitor it. Would welcome some advise on what else I can do to test out the clearance under various conditions.
  26. Aug 29, 2023 at 8:27 AM
    #3656
    Adventurer
    Adventurer New Member
    2023 1794 TRD 6.5 Celestial Siver
    I'm doing an overland cross country trip around April, so put a lot of thought into tire choice and size. Will be camping remotely at times, so wanted a durable tire with solid traction. I know 18's wheels are better, but I have the 20" TRD wheels and I'm cheap, plus I like the look and am not a fan of altering offset and scrub radius with aftermarket. I chose Yokohama Geolander M/T in 275/65/20. Basically a 34" tire, 1/2" wider. I considered roll resistance and want to keep good mileage. Don't care about 4% error on speedo, Escort radar detector displays gps speed anyway. I'll just add 4% to trip comp mpg. Also should raise top speed 5mph. Already ran an F150 with my stock tires up a grade in AZ and got him by a couple mph. F you Ford LOL
    Original06 likes this.
  27. Aug 29, 2023 at 9:14 AM
    #3657
    dangeloc
    dangeloc New Member
    it is a 285 65r20, Yes with the TRD3" lift from the dealer.
    TRD L Power[QUOTED] likes this.
  28. Aug 31, 2023 at 8:13 AM
    #3658
    Callmedaddy
    23 blue limited 4x4
    Can I see some pics of some trucks with aggressive offset 17 like some -10 or more trying to order wheels soon want some poke about 2” or so. Also would like to know what trimming you had to do. I’m going with a 3” lift with 17x9 and 35 but not sure if I want to do 35x12.5 or 35x10.5. So far I’m looking at -10,-12,-38 offset wheels
  29. Aug 31, 2023 at 9:13 AM
    #3659
    Morning_Rock
    Morning_Rock New Member
    Should be able to find a white TRD pro with 17" TE37 with -10 few pages back
  30. Aug 31, 2023 at 12:18 PM
    #3660
    frostymeds
    frostymeds New Member
    Just got the truck back Monday and I’m in love!
    Westcott 3/1 lift kit
    17x8.5 -0 offset black rhino rapid wheels
    35x12.5r17 nitto ridge grapplers
