GEN 3 (2022+) Wheels and Tires Photo thread
Discussion in 'Wheels & Tires' started by Tsquare, Jan 16, 2022.
  1. Jun 26, 2023 at 6:26 PM
    #3421
    Jinkx
    Jinkx New Member
    Keith
    2022 Tundra SR5 with TRD package
    Air filters//Exhaust//Level kit//Tires and visual accessories
    Nick_S94 likes this.
  2. Jun 26, 2023 at 6:28 PM
    #3422
    Nick_S94
    Nick_S94 New Member
    Nick
    2010 pyrite Tundra SR5
    Both of those offsets look good to me! I know the -12 would be about a half inch more poke than the 0 offset.
  3. Jun 26, 2023 at 6:35 PM
    #3423
    Jinkx
    Jinkx New Member
    Keith
    Yes he makes some good points but you’re talking -12 no way your tire a 35 tire will fit inside the wheel well with full articulation. Your gonna rub with a neg -12. Will rub in turns also.
    BMP likes this.
  4. Jun 26, 2023 at 6:38 PM
    #3424
    Jinkx
    Jinkx New Member
    Keith
    A lot of people get confused. They think the tire is farther out from the body so less rub and just the opposite happens especially when turning!
    BMP likes this.
  5. Jun 26, 2023 at 9:03 PM
    #3425
    ncart
    ncart New Member
    2022 Lunar Rock TRD Pro
    There is also a SL option for the Nitto Recon in 295/70r18. I went with the 305/70 myself because they were available at the time I was buying, but seriously considered waiting.
  6. Jun 26, 2023 at 10:47 PM
    #3426
    Jinkx
    Jinkx New Member
    Keith
    YF19 beautiful set up. The perfect setup for stock wheel IMO.
    Swaine 80 lookin good brother.
    I’ve heard from Toyota that there 3 inch kit actually raises the front 2 1/4 to 2 1/2…
    It looks like your truck still has a little rake still in the rear.
    So for the guys towing but still wanting a lift this may be an option.
    I know Sparks Toyota knocks about 1000 off retail price if anyone is looking.
    I was worried when I had the 4 inch lift installed on mine that the rear wouldn’t be level because I wanted that and don’t tow.
    Once it was finished I was happy!!
    NCart yes yiur right. It’s the best overall size 295/70/18 for no rubbing but still a nice size tire. I saw that too when I bought my 315/60/20.
    If I didn’t have to use a 20 inch wheel I would have gone that size.
    But very happy as the 315s. They are super light for that size tire 57 lbs and there a little taller and wider then a 35x12.5
    That’s what makes this fun! Different Setups
    Kepaniamekolea, ncart and iiawah808 like this.
  7. Jun 27, 2023 at 6:44 AM
    #3427
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    @Jinkx I am looking for info on what your rear poke is on both sides of the truck. I am wondering how the rear lift affects the tracking. My guess is that the lift will pull the rear axle towards the drivers side.
    How much lift did you do to the rear to keep some rake?
    I ask because I did a simple 1" Westcott spacer lift and noticed that my drivers side rear tire was sticking out more and my flares no longer covered the treads. On the passenger side the tire was pulled in further and well covered. That got my started to figure out what was going on with the rigid panhard bar and alignment of the rear wheels.
  8. Jun 27, 2023 at 7:18 AM
    #3428
    nodak67
    nodak67 New Member
    JR
    had p-rated duratracs on the 2018, after 5 yrs and getting down to about 1/4 tread, they get louder as the tread gets to 1/4 life and lower. before that they were not much louder than the oem tires we had originally, but that was our opinion.
    DMackler[QUOTED] likes this.
  9. Jun 27, 2023 at 7:21 AM
    #3429
    nodak67
    nodak67 New Member
    JR
    but its been noted by a lot of people and other forums that duratracs start howling as you reach 1/4 tread life, so that is nothing new and its inherent to that model for years.
  10. Jun 27, 2023 at 7:43 AM
    #3430
    Jinkx
    Jinkx New Member
    Keith
    PBNB I’ll get you that pic
    I really have no rake my truck is pretty much level and is within 1/2 inch front to back height measured
    You really can’t see a difference.
    My 4 inch lift came with a rear track bar bracket that keeps the track bar in the factory location so whatever poke difference I have is basically how it was from the factory…
    looks even to me brother…
  11. Jun 27, 2023 at 7:47 AM
    #3431
    Jinkx
    Jinkx New Member
    Keith
    Sun light kinda makes it look diff but they look about the same.
    My rear lift is 2 inch. Front 4 inch..
    Rough Country 4 inch lift. They don’t list how much the rear comes up only that the truck will be level.
    I had a ready lift 3/1 and truck was level so after the 4 was installed it’s still level so thoughts would tell you that it has to be a 2 inch lift in the rear…
    To add to this all leveling kits are 1.75 to 2 inch.
    So basically from Toyota are trucks are 2 inches higher in the rear then the front!
    Hope that helps!
  12. Jun 27, 2023 at 9:50 AM
    #3432
    ncart
    ncart New Member
    For those that are curious about the 305/70r18 Nitto Recon Grappler. They are slightly taller and slightly thinner than the 35’s, but load range D.
    163EAEC1-DC6A-498A-B14E-4FEC6EA87E4E.jpg FB5CCFC7-E7BF-465D-BF98-D298E3BCB0C8.jpg C04A20F7-BEA4-42E0-91C6-CA9696876944.jpg
    FFFvamos, ytank1, Hank Hill and 7 others like this.
  13. Jun 27, 2023 at 9:52 AM
    #3433
    ReCKzX
    ReCKzX New Member
    2023 Tundra TRD Pro Ice Cap
    Looks really good. Stock suspension?
  14. Jun 27, 2023 at 9:54 AM
    #3434
    ncart
    ncart New Member
    Yes, stock all around. And Thanks!
    ReCKzX[QUOTED] likes this.
  15. Jun 27, 2023 at 10:13 AM
    #3435
    AwesmeChic
    AwesmeChic New Member
    Kara
    2023 Tundra Capstone IForce Max 4x4
    Softopper
    Is your truck lifted?
  16. Jun 27, 2023 at 2:36 PM
    #3436
    SpclOprtv15
    SpclOprtv15 New Member
    Carl
    2023 MGM Tundra Plat
    295/60/20 Ridge Grappler
    Fuel Rebel 6 20x9, +20 offset.
  17. Jun 27, 2023 at 3:42 PM
    #3437
    Jinkx
    Jinkx New Member
    Keith
    Special oops good looking truck brother!!!! Nice tire size!
  18. Jun 27, 2023 at 3:48 PM
    #3438
    Wood-Dro
    Wood-Dro New Member
    That is sweet. Any suspension kits? Rubbing? This is very close to what I want to do with mine.
  19. Jun 27, 2023 at 4:23 PM
    #3439
    SpclOprtv15
    Carl
    No rubbing that I have noticed. 2” front leveling kit.
    Wood-Dro[QUOTED] likes this.
  20. Jun 28, 2023 at 7:49 AM
    #3440
    Benji31
    Benji31 New Member
    Ontario, Canada
    2023 TRD off road
    285/75R18 toyo open country RT
    American racing AR931 +30 wheels
    Henry1jg and mayan like this.
  21. Jun 28, 2023 at 7:52 AM
    #3441
    Wood-Dro
    Wood-Dro New Member
    Had a question for you, sent a private message. Thanks.
  22. Jun 28, 2023 at 10:47 AM
    #3442
    Jinkx
    Jinkx New Member
    Keith
    Love that color Benji
  23. Jun 28, 2023 at 1:35 PM
    #3443
    TRDProTJ
    TRDProTJ New Member
    2023 Ice Cap Tundra TRD PRO
    Joined the TE gang! Finally got around to mounting the wheels. Truck rides great so far. I was scared about the poke on the -10 offset but it isn't that bad in person, actually like it more now. Rear is a tad lower in the pics since the weight of the old wheels are in the bed.
    - Westcott TRD Pro Lift
    - Volk TE37XT Bronze 17x8.5 - 10
    - Toyo Open Country R/T Trails 35/12.5/17
    dan81, mayan, Yaboy and 9 others like this.
  24. Jun 28, 2023 at 6:34 PM
    #3444
    iiawah808
    iiawah808 New Member
    Oahu, HI
    2022 iForce Tundra Limited TRD Offroad
    Currently Searching....
    Beautiful Pro! TE37’s just can’t be beat. Strength, weight and bragging rights. Wish I could afford them.
    TRDProTJ[QUOTED] likes this.
  25. Jun 28, 2023 at 8:20 PM
    #3445
    cvd2312
    cvd2312 New Member
    2023 CrewMax SR5 TRD OR
    Where’d you buy the wheels? They’re hard to find in that size
  26. Jun 29, 2023 at 3:15 AM
    #3446
    Benji31
    Benji31 New Member
    Ontario, Canada
    2023 TRD off road
    I bought 3 from tire rack and the the 4th from wheelwiz. I’m not sure if they make them in this size anymore.
    ARCOVT23 likes this.
  27. Jun 29, 2023 at 4:04 AM
    #3447
    ARCOVT23
    ARCOVT23 New Member
    Vermont
    2023 Tundra SR5
    TRD Lift, TRD skid.
    What is the report on the R/T trails!? They look sick
  28. Jun 29, 2023 at 6:18 AM
    #3448
    ReCKzX
    ReCKzX New Member
    That is sick! I too am worried about the -10 offset.
  29. Jun 29, 2023 at 7:06 AM
    #3449
    charrito
    charrito New Member
    2023 Magnetic Gray Metallic 1794 Edition
    Great thread to follow. I'm going to wait to burn up the OEM tires. I mostly commute so those are OK for now, but I am a huge fan of the Michelin Defender LTX M/S, as I don't need anything too aggressive.
  30. Jun 29, 2023 at 7:33 AM
    #3450
    Breathing Borla
    Northern Illinois
    also check out the Cooper AT3 4S when the time comes, great all around tire, light and Made in USA and cheaper than the Michelin
