Gen 2 DRL
Discussion in 'Lighting' started by jfrd30, Apr 14, 2019.
  1. Apr 14, 2019 at 11:22 AM
    jfrd30
    jfrd30 [OP] Lead, Follow, or Get the Hell Out of My Way
    2013 TRD Tundra
    Hey all,
    Just recently my Gen 2 LED Daytime Running Lights (the LED strip under the headlights) went out. I've tested them and they are not getting power. I've searched the ole interweb and can't find anything about fuses or other people having similar problems. Anyone have any life saving hints or tips or directions on getting these things up and running again??? Thanks in advance....asking for a friend!!
  2. Apr 22, 2019 at 5:40 AM
    jfrd30
    2013 TRD Tundra
  3. May 22, 2019 at 11:57 AM
    DesertRoads
    DesertRoads Telecom Guy
    Utah's West Desert
    2005 DC SR5 V8 4WD LSD & TOW PKG
    LED Lights Galore. Mostly Stock
    LED strip under the headlights on the Gen 2? I haven't seen that on a Gen 2. Gen 3 though.
  4. May 22, 2019 at 2:35 PM
    jfrd30
    2013 TRD Tundra
    Underneath each headlight
  5. May 22, 2019 at 2:57 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Did they come with truck, or did you install them?
  6. May 22, 2019 at 2:59 PM
    jfrd30
    2013 TRD Tundra
    Not 100% sure, I purchased the truck 1 year used, but they are an option from the dealer. I pulled the lights and checked the wiring. No power to either side. Nothing else appears to be off/not functioning.
  7. May 22, 2019 at 3:06 PM
    rons23
    Ron
    Kill Devil Hills
    How did you turn them on? Are they on the same circuit as your amber running lights?
  8. May 22, 2019 at 3:08 PM
    jfrd30
    2013 TRD Tundra
    They come on with the ignition. They are completely separate from the amber DRL's
  9. May 22, 2019 at 3:14 PM
    rons23
    Ron
    Kill Devil Hills
    Damn, wish I could help, normally it's a fuse, ground, or loose wire.
    @NewImprovedRon ?
    NewImprovedRon likes this.
  10. May 22, 2019 at 3:40 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
  11. May 22, 2019 at 4:40 PM
    rons23
    Ron
    Kill Devil Hills
    @jfrd30, here's a suggestion. As Ron mentioned above trace the wire out for cuts or breaks in line. You could just cap off line and rewire lights to your ignition fuse via fuse tap and ground it. That's the way I did mine. Worse case scenario as @Trooper2 said above, they have them kits on Ebay for around $100 or so. You get the panel's plus led lights. Panels could be back up in case you break the male tips trying to pull them out like I did:eek:. Just a thought.
  12. May 24, 2019 at 8:44 AM
    DesertRoads
    Utah's West Desert
    Those are cool. I've never seen them on the 07-13's before.
