Gen 1 Hitch / Receiver Lift / Replace - Rear Bumper Build
Discussion in '1st Gen Tundras (2000-2006)' started by alb1k, Oct 5, 2021.
  1. Oct 10, 2021 at 2:13 PM
    alb1k
    alb1k [OP] Always Coming From Take Me Down
    Left Coast
    05 2WD DC w/ attitude
    It's good
  2. Oct 10, 2021 at 2:31 PM
    alb1k
    Left Coast
    It's good
    30 sec a side to round off 1/4” square angles.
    Darkness likes this.
  3. Oct 10, 2021 at 3:30 PM
    alb1k
    Left Coast
    It's good
    I think this will work.
    Darkness and Casper421 like this.
  4. Oct 10, 2021 at 6:32 PM
    alb1k
    Left Coast
    It's good
    Now that it's in (not welded yet), I'm going with it's a legit mod. I cut and drilled the side plates for the height and extension I wanted. I have 2 factory bolts on and will add weld. I can probably cut the stock brackets (off now) and use stock holes, welds for more strength, The cross tube is directly under the frame and adjusted for extension and side plates trimmed for the coming bumper. I'll post pics from my phone. If you went with a 4" tall bumper, it could sit on top of this and clear the tailgate when down. A 7" tall bumper would clear the tailgate and line up around the bottom of the receiver. Nothing bolt on will work at all, only customs. Kinda makes me want to chop the rear bed. We will see.
  5. Oct 10, 2021 at 6:43 PM
    alb1k
    Left Coast
    It's good
    ***Some pics progress, some final***
    Pic dump…. 4” to the bottom of the spare tire access slot from the cross support. Top of the side plates is closer to 2" after a cut out.
    This one is the right height, but later I cut the side plates lower.
    Every pic below here is final plate cuts and placement:
    You can see the bare metal on the side plates - this is after I cut them out 1/2"
    Darkness and des2mtn like this.
  6. Oct 11, 2021 at 10:31 AM
    alb1k
    Left Coast
    It's good
    A few welds on board before wind picks up here and so I can drive it.
  7. Oct 11, 2021 at 6:44 PM
    alb1k
    Left Coast
    It's good
    Here’s the long flat brick. I imagine this is the hardest part. It’s fairly rough now, but I think it will start taking shape.
  8. Oct 12, 2021 at 2:12 PM
    alb1k
    Left Coast
    It's good
    Aligned and cleaned up the rectangle tube. Added some bolt mounts. Lots of measuring and centering.
  9. Nov 1, 2021 at 5:50 PM
    alb1k
    Left Coast
    It's good
    Finally got some rear bumper time. I'll add pics from my phone after this text. Needed to cut some cardboard to see where I needed angles and if I was happy with the plan. Looked good so dealt with the bigger sections which takes forever. The foundation is in place so smaller cuts tomorrow and some more design thought. I was generous with that lic plate area, it's hard to put metal back. But I will likely end up chopping some of the bottom off.
    oscardog86, Kimosabe, shifty` and 4 others like this.
  10. Nov 2, 2021 at 10:26 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    W.I.P - FOX 2.5 with DSC, SCS F5 wheels with MT Baja ATZ 285s
    Looking good.
    alb1k[OP] likes this.
  11. Nov 2, 2021 at 1:21 PM
    alb1k
    Left Coast
    It's good
    Starting to look less like a brick and more like a bumper.
    FrenchToasty and Darkness like this.
  12. Nov 2, 2021 at 2:05 PM
    oscardog86
    oscardog86 New Member
    Southern California
    2001 Toyota Tundra 4x4 V6 5VZ-FE MT
    That looks really good man. Any plans on cutting your tail pipe a bit shorter? When I had a tube bumper built it made the tail pipe stick out like a sore thumb. I just cut it back several inches at an angle and I think it looks much more tucked away now.
    Darkness and alb1k[OP] like this.
  13. Nov 2, 2021 at 2:13 PM
    alb1k
    Left Coast
    It's good
    Cut a little relief, vise it up and give it a bend.
    FrenchToasty likes this.
  14. Nov 2, 2021 at 2:15 PM
    alb1k
    Left Coast
    It's good
    For sure. I think mine is worse because I put it into a tall curb long ago. But that thing is getting cut, redirected, something. Thanks brother. @oscardog86
  15. Nov 2, 2021 at 5:00 PM
    Casper421
    In the woods
    06 DC
    Lookin good!! Im actually diggin the patina look to be honest! Keep up the good work Erik!
  16. Nov 2, 2021 at 6:00 PM
    alb1k
    Left Coast
    It's good
    @Casper421 - thank you, Chris!
  17. Nov 2, 2021 at 6:11 PM
    alb1k
    Left Coast
    It's good
    Here's where it is at quitting time today. I'll probably clean this up more than I did the front bumper, I've got more energy to grind, fill, sand. Party up front, business in the rear. I would have just gone the Coastal route and been done by now, but I wanted that integrated receiver, and less body chop for now at least. There are a few more courtesy pieces to add, and I may extend the ends forward to follow the bed lines closer, but so far so good.
  18. Nov 2, 2021 at 6:18 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    It’s your bumper and to late now, but I would have mounted the license plate to the top tube and not even messed around with making the cove for the plate.
    Also chop off the bottom of the plate bracket flush with the rest of the bumper.
    My 2.2 cents
    oscardog86 likes this.
  19. Nov 2, 2021 at 7:02 PM
    #49
    alb1k
    Left Coast
    It's good
    Good points @FrenchToasty. I recessed it so I can better light it, and I like the look. I was generous with the height of that plate, but it's going to get trimmed. Not flush, lic plate is 6" tall and the other plate below the tube is 5", but closer than now.
  20. Nov 2, 2021 at 7:33 PM
    #50
    alb1k
    Left Coast
    It's good
    @FrenchToasty got me back in the garage to grab a tape. I can lose 13/16" of that lic plate-plate. It's a 35% or so reduction below the bottom bumper line. I'll still have 1.5" below, probably right about where the hitch plate lies. I'll be good with that....or I offset the lic plate with rubber bushings and lose another 1/4" by passing the weld...:)
    oscardog86 and FrenchToasty like this.
  21. Nov 2, 2021 at 7:39 PM
    #51
    FrenchToasty
    Mo
    Bone stock
    Can you trim your license plate;)?
    Your bumper is coming along nicely, good job!
  22. Nov 2, 2021 at 7:42 PM
    #52
    alb1k
    Left Coast
    It's good
    Thank you as always, truly. I love your posts and learn a lot Thumb up emoji.
    I got a guy at the DMV, I'm thinking motorcycle plate.
  23. Nov 3, 2021 at 6:47 PM
    #53
    alb1k
    Left Coast
    It's good
    On that note....Cut it and dump down? New angle and aim higher and out? I don't know shi# about exhaust except that, if you pull everything behind the cat on a Ford 460, the HP gain is cray, and with a manual, you can jump-scare pedestrians on the sidewalk on demand.
    oscardog86[QUOTED] likes this.
  24. Nov 4, 2021 at 6:09 AM
    #54
    oscardog86
    Southern California
    I cut mine at an angle so it just dumps down but kinda outward still cuz its at an angle. Cant even see it anymore as it is the same height as my spare under the truck now and disappears in the shadows.
    alb1k[QUOTED][OP] likes this.
  25. Nov 7, 2021 at 11:19 AM
    #55
    alb1k
    Left Coast
    It's good
    Getting closer. Still have some small pieces to fit, but welded the inside, trimmed the license plate backing, tapped some holes and test fit some LEDs.
    Casper421 and FrenchToasty like this.
  26. Nov 7, 2021 at 6:06 PM
    #56
    alb1k
    Left Coast
    It's good
  27. Nov 8, 2021 at 5:44 AM
    #57
    Man I hate working with that stuff, but it sure is satisfying to see the end result once it's done. Like candy-glazing.
  28. Nov 8, 2021 at 7:00 AM
    #58
    alb1k
    Left Coast
    It's good
    For sure. I learned and stayed clean this time…
  29. Nov 8, 2021 at 8:43 AM
    #59
    alb1k
    Left Coast
    It's good
    I would say this thing is cooperating with the plan.
  30. Nov 8, 2021 at 10:48 AM
    #60
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    Looks sharp! Great work.
    KNABORES and alb1k[OP] like this.
