Gearing
Discussion in 'New Member Introductions' started by Parbo517, Jun 3, 2021.
  1. Jun 3, 2021 at 4:57 PM
    Parbo517
    Parbo517 [OP] New Member
    Louie
    2012 5.7 2wd crewmax
    6” lift 35x12.50x20
    Hello I’m new to this forum. 2012 2wd 5.7. Getting re-geared. I don’t go on dirt but might do a little pre-running in the future. 6” lift with 35”x12.50x20. Mainly heya and a lot of city driving. should I get 4.88 or 5.29. My buddy owns a gear shop and he recommended 5.29. Not sure what to do.
  2. Jun 3, 2021 at 5:19 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Can't help with the gearing questions but welcome from LA (Lower Alabama)!
  3. Jun 4, 2021 at 12:33 PM
    Dr Doobie
    Dr Doobie Growing member
    Talkeetna,Alaska
    '07 RCSB 5.7 SC'd 4x4 SSM
    Welcome from Alaska
  4. Jun 4, 2021 at 2:03 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  5. Jun 4, 2021 at 2:59 PM
    Sunnier
    Sunny
    San Diego, CA
    If you do a search you’ll find a lot of threads in this. Basically, if you’ll stay at 35’s 4.88 should be fine. If you’ll 37’s you’ll want 5.29. From all I’ve read, the divide is right between 35 and 37....
    But it also depends a on how you’ll use your truck... towing, what tires, even offset. Definitely worth a search to learn more before you commit.
    Darkness and 15whtrd like this.
  6. Jun 4, 2021 at 3:02 PM
    15whtrd
    15whtrd Mr. Blonde
    Have them put a locker in there while you’re at it. If you’re going to be in the dirt, you at least want both back wheels fully locked since you’re not 4 x 4.
    Sunnier and snivilous like this.
  7. Jun 4, 2021 at 3:03 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    5.29s, rpm is at 2650 @ 80mph in 6th gear and the truck will make massive amounts of torque and just be idling most of the time. I get the same mpg or better with 5.29s compared to stock, even though the engine is spinning 25% faster. Lots of threads on gearing though in the Performance & Tuning section, but imo there is zero loss with 5.29s unless you want to go 130mph, otherwise you get more torque, same mpg, and the engine doesn't have to work as hard.
    Sunnier, Darkness, TravisJr and 2 others like this.
  8. Jun 4, 2021 at 8:26 PM
  9. Jun 4, 2021 at 9:25 PM
    TravisJr
    TravisJr New Member
    2001 AC SR5 4WD, 2010 DC SR5 4WD
    Lots o’ mods
    I’m also on 6” and 35s. I have 5.29s - wouldn’t change anything.
  10. Jun 4, 2021 at 11:41 PM
    AZ Red Nek
    AZ Red Nek Native of the Valley, Bowl, Basin, ETC...
    Chuck
    2016 White SR5 Crew 4x4
    Hidden 1200# Waren winch, Baja Desgins lights, Switch Pro switch and controller, S&B air box and in bed tool box.
    Welcome from Phoenix
  11. Jun 5, 2021 at 3:03 AM
    Welcome from Ohio
  12. Jun 5, 2021 at 4:07 AM
    TXTundra2722
    2015 Black Tundra
    Welcome from TX
  13. Jun 5, 2021 at 6:54 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Welcome from So Cal
  14. Jun 5, 2021 at 8:02 AM
    Cfincke
    San Antonio
    I have had 5.29s since early 2020. For over a year I was on 295/70/18s (34.3x11.5). I went 529 over 488 because I tow a travel trailer and I never wanted that "what if". My plan was to only move up to 35s, but ended up moving up to 37s. I was very happy with the trucks performance on 34s with the 529 and even on 37s.
    34s with stock gears - 13.4MPG
    34s with 529s - 12.8-13.0MPG
    37s with 529 - 12.5-12.8MPG
    My towing MPG is +/- 0.3mgp across all 3 variations 7.7-8.0
    The engine rpms are a little higher but the engine load is less
    Sunnier and Hightide like this.
