Gear swap mechanic in Portland/Vancouver
Discussion in 'North West U.S.' started by Ry24000, Jun 8, 2021.
  1. Jun 8, 2021 at 12:30 PM
    Ry24000
    Ry24000 [OP] New Member
    Ryan
    Carson, WA
    2019 Tundra SR5 TRD offroad Quicksand
    Debadge, ARE z series top, Ironman Foam cell pro 3" lift, SPC UCA's, ICON vector 5 & Toyo ATIII 285 75R 17, Warn 9.5XP mounted in a Victory Blitz bumper. GTR 1000LM+XTR LP Reverse Light System
    Who should I use in the Portland/ Vancouver area for my ring and pinion swap.? I can't let just anyone work on my baby! I would like someone experienced with Toyota and lockers.
  2. Jun 8, 2021 at 1:28 PM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    Subd
    Woody's in St. Johns area is probably the best option.
  3. Jun 8, 2021 at 1:44 PM
    Ry24000
    Ryan
    Carson, WA
  4. Jun 8, 2021 at 1:58 PM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    I had Gresham 4x4 install my lift and they said that they can do a gear swap as well. I was told that they have one guy there that does them. Honestly, I would feel more comfortable with a shop that only deals with drivetrains but it does not look like there are any around.
  5. Jun 8, 2021 at 3:03 PM
    Rodtheviking
    Vancouver, WA
    Sequoia
    That's the place.
    Friend has been using them for years for his race truck (Toyota) and told me about them.
    Ry24000[QUOTED][OP] likes this.
  6. Jun 17, 2021 at 10:37 AM
    crewmaxlmt
    scott
    Well, it looks like I will be the guinea pig for this one. I am having Woody's quote me Yukon 4.88's, and Auburn Pro LSD, and an Eaton E-locker for the front.
    Ry24000[OP] and Rodtheviking like this.
  7. Jun 17, 2021 at 4:51 PM
    Ry24000
    Ryan
    Carson, WA
  8. Jun 17, 2021 at 5:43 PM
    crewmaxlmt
    scott
    Will do. I will tell you that they will not install Nitro gears due to the quality.
  9. Jun 21, 2021 at 7:16 PM
    Ry24000
    Ryan
    Carson, WA
    How much is the swap going to cost you?
  10. Jun 21, 2021 at 7:17 PM
    crewmaxlmt
    scott
    Still waiting on the quote. I am going to give them a call tomorrow.
  11. Jun 21, 2021 at 8:34 PM
    Pmac
    Pmac New Member
    South of Portland, OR
    2019 CrewMax TRD Off-road
    I’ve not used him, but my buddy has used and recommends Dan’s Gears in Sherwood. One man show, a little salty, only works on gears. May be worth a call to see if he does Tundra’s. 503-692-1547.
  12. Jun 22, 2021 at 4:03 PM
    crewmaxlmt
    scott
    Dan's is out of business. I talked to R&P FWD in Oregon City and he suggested Holbrook Specialties in Gladstone. I texted him so now we wait for a date.
    Ry24000[OP] likes this.
  13. Jun 29, 2021 at 1:31 PM
    crewmaxlmt
    scott
    I just found out that the Auburn LSD is backordered and most likely discontinued. So it looks like I will be going with the Powertrax unit.
  14. Jun 29, 2021 at 4:26 PM
    Ry24000
    Ryan
    Carson, WA
    I was leaning tword the Powertrax anyway. Any luck on pricing? I need to get this done sooner rather than later. I have an Antelope hunt in August. It would be nice to have some gears broke in by then.
  15. Jun 29, 2021 at 4:47 PM
    crewmaxlmt
    scott
    Summit racing
  16. Jul 13, 2021 at 1:22 PM
    crewmaxlmt
    scott
    So I finally have all of the gear except for the front install kit that was supposed to be instock, it wasn't. After many calls and searches I found a kit through Motiv Gear. In another week My truck should be at the shop for the install.
    If you are thinking about regearing, start looking for the parts. The hardest end for parts is the front end.
  17. Jul 13, 2021 at 2:06 PM
    Ry24000
    Ryan
    Carson, WA
    My gears are on backorder. I have the Power Trax Though
  18. Jul 13, 2021 at 2:24 PM
    crewmaxlmt
    scott
    I received the Motiv rings and pinions, Yukon rear install kit, and Powertrax through Summit and the E-Locker through Justdifferentials. I ordered the front Motiv install kit from Jaws gear and axle.
    I also need to figure out where I am going to mount the E-Locker switch. The limited has every location filled up.
  19. Jul 13, 2021 at 3:13 PM
    Ry24000
    Ryan
    Carson, WA
    You have "Limited" space in the Limited!
  20. Aug 13, 2021 at 11:33 AM
    crewmaxlmt
    scott
    So I just got my truck back from the 4.88 swap and it is very loud. They wanted to try a different pattern but I told them that I would break the gears in to see if it gets quieter. The guy that did the gears has been doing them for 25 years.
  21. Aug 13, 2021 at 11:36 AM
    Kratos
    Kratos Woof
    2021 MGM Limited Nightshade
    I've done two swaps with the last being 4.56 gears in my Jeep, and neither were louder than stock. Is this something typical for Tundra's?
  22. Aug 13, 2021 at 11:42 AM
    blackoutt
    blackoutt YEAH BUDDY!
    Indy
    07 DC Long Bed - Old Man Tan
    OEM+
    Easier to try a new pattern before they are broken in. Patterns are said to become useless on worn gears. Take it back. You paid the big bucks for the right setup, give them an opportunity to get it right.
    Black Wolf likes this.
  23. Aug 13, 2021 at 12:56 PM
    crewmaxlmt
    scott
    They wanted to pull the rear back out today but we all agreed that the might quiet down after break in. They also said that they don't have a problem getting a pattern after they are broke in.
  24. Aug 13, 2021 at 12:59 PM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
  25. Aug 13, 2021 at 1:58 PM
    crewmaxlmt
    scott
    Yeah I'm interested to see as well. They have been doing gears for so long that if they can't get them quieter than they will call Motiv.
    Kratos likes this.
  26. Aug 13, 2021 at 5:13 PM
    Ry24000
    Ryan
    Carson, WA
    What is a "Pattern"?
  27. Aug 13, 2021 at 5:38 PM
    crewmaxlmt
    scott
    After the gears are installed, they are painted with a paste so that they can see where the contact is. There have been posts on here about gears with a near perfect pattern having noise. Most of the time it’s when coasting. Mine is both coasting and driving.
  28. Aug 13, 2021 at 6:02 PM
    Ry24000
    Ryan
    Carson, WA
    Oh the contact pattern...The installer should have done this already?
    How much noise are we talking about?
  29. Aug 13, 2021 at 6:16 PM
    crewmaxlmt
    scott
    The shop said that the pattern was perfect. The noise sounds like you are riding on an airport shuttle bus. Noise when on the throttle and also when coasting. It is not terribly loud but loud enough to be annoying. If it does not go away, then they will pull the pumpkin in two weeks to try another pattern.
    I really did not want them pulling it again on a Friday with 100 degree heat as he was already frustrated about the noise. If they can’t get rid of the noise then I will be getting another gear set. It appears that these 10.5” rears can be a bitch sometimes.
  30. Aug 13, 2021 at 6:19 PM
    Ry24000
    Ryan
    Carson, WA
    Yeah I several people have posted about noise. Not sure if brand has anything to do with it? What brand did you go with? I went with Nitro, but they have been on back order. Waiting!
