gear alloys
Discussion in 'Wheels & Tires' started by sledstar4, Feb 22, 2016.
  1. Feb 22, 2016 at 6:00 PM
    sledstar4
    sledstar4 [OP] New Member
    ' 16 BLAZIN BLUE PEARL CM
    leveled-flares-wheels
    I just ordered a set of gear alloys, and just wonderin if my stock tpms will fit, sorry if this topic has benn beat to hell, just don't have time to read every post and response, btw they're 18x9 +18mm offset
  2. Feb 22, 2016 at 6:02 PM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    I'm pretty sure you'll be ok since your staying with an 18 inch wheel. If you changed to a 20 inch wheel, you would have to buy new TPM's. I learned this the hard way.
  3. Feb 22, 2016 at 6:19 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    What? How does wheel diameter determine if your pressure sensors will continue to work or not?
    The issue that you will have is from going to/from steel/alloy. The sensors have one valve stem angle for steel wheels (45) and another for alloy (20).
  4. Feb 22, 2016 at 6:21 PM
    mdavis
    Michael
    Rock Hill, SC
    Yeah that's what I meant. I had the 18 inch steel wheels on mine and swapped them to a 20 inch alloy. Had to buy new sensors.
    Wynnded[QUOTED] likes this.
  5. Feb 25, 2016 at 4:02 PM
    sledstar4
    The place I orderd them from said the same, steel-to-steel, alloy to alloy, so is there anyway to tell definitely which wheel is which, I'm positive I have alloys, window sticker says steel, but the sticker also says its a ffv, but I have the black cap and nothing anywhere about E85
  6. Feb 25, 2016 at 4:36 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Take a pic and we can tell you
  7. Feb 25, 2016 at 5:11 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    The wheels in your avatar look to be alloys.
    There might be a sticker on the underside of the hood or somewhere in the engine compartment that tells you that your engine is either 3URFE (non-FFV) or 3URFBE (FFV). I think that you're able to tell from the VIN, but I can't recall off the top on my head what that information is.
  8. Feb 25, 2016 at 6:06 PM
    sledstar4
    They're alloys, thanks best forum on the interwebs!
  9. Feb 25, 2016 at 6:12 PM
    mdavis
    Michael
    Rock Hill, SC
    You can tell if your engine is a flex fuel by looking at the VIN. If the fifth letter is a "W" it is a flex fuel. Also your gas cap will be yellow and say E85 on it.
  10. Feb 25, 2016 at 6:16 PM
    sledstar4
    5th letter 7n vin is W but I have no yellow cap, whatever I wouldn't run that shit anyway
  11. Feb 25, 2016 at 6:21 PM
    mdavis
    Michael
    Rock Hill, SC
    Yep, if it's W, it is a flex. If it's a "Y" it is a non flex. I have a flex myself, I would never put that shit in there either.
  12. Feb 26, 2016 at 10:22 AM
    csuviper
    Broomfield, CO
    Heck yea it is!
