Gauging Interest for a Possible 17" FN Wheels GB
Discussion in 'Wheels & Tires' started by Elduder, Aug 5, 2020.
Which 17" FN would you rather purchase (if you could)
  1. FN 17" Six Shooter
    66 vote(s)
    75.9%
  2. FN 17" Five Star
    21 vote(s)
    24.1%
  1. Aug 17, 2020 at 9:24 PM
    TheBeast The Beach
    17"s six shooter 5x150, bronze color, +18/25 offset and hub centric (110.5(?)mm) would be nice
  2. Aug 18, 2020 at 4:16 AM
    Hurricane
    Hurricane Default: Aggressive
    NC
    2017 White 1794
    None
    Stupid question: I get the offsets, but what does “Hub Centric” mean?
  3. Aug 18, 2020 at 6:17 AM
    chugs
    chugs New Member
    Ciao
    Central Cali
    2007 Tundra Blue Streaker
    Googles says
    Hurricane[QUOTED] likes this.
  4. Aug 18, 2020 at 6:44 AM
    Hurricane
    NC
    2017 White 1794
    None
    So it fits over the hub and leaves the hub exposed?
  5. Aug 18, 2020 at 9:47 AM
    TheBeast The Beach
  6. Aug 18, 2020 at 9:48 AM
    TheBeast The Beach
    would you rather have your wheel rest on the whole hub or 5 tiny lugs ? ;)
  7. Aug 18, 2020 at 10:17 AM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Would u need extended lugs like methods?? Or regular lugs like icons?
    TheBeast likes this.
  8. Aug 21, 2020 at 9:55 AM
    Elduder
    Elduder [OP] New Member
    Both I assume, but I typically run extended if I can for the extra threads and piece of mind.
    Update:
    So this may get a small delay here and there. Unfortunately I was on my way out to vacation yesterday and got rear ended in stop and go traffic. Other driver appears to have been doing about 40 to 50 at the time of impact. My truck will be out of commission for a bit, rear bumper and hitch are gone, rear bedside on one side is folded. Cab got smacked and dented from the bed moving. Frame has a small 2-3" roller bend in it, etc...
    I will be a little busy with insurance and body work and such, but will still reach out to Dustin. Just wanted to explain why I might not reply as much over the next week or so.
    Thanks guys.
  9. Aug 21, 2020 at 10:16 AM
    Hurricane
    NC
    2017 White 1794
    None
    Damn dude. Hopefully you aren’t too dinged up. That’s a pretty good impact.
    Elduder[QUOTED][OP] likes this.
  10. Aug 21, 2020 at 4:25 PM
    YYCDCLTD
    YYCDCLTD New Member
    '07 DC LTD Tundra
    Bone stock
    I'm curious about what the overall weight of the wheel/tire packages will be with these wheel options vs. 18's or even 20's. On my current "summer" set-up, using a factory 20x8" wheel and Nokian Rotiiva AT's in 275/55/20 I'm at 75lbs with wheel weights and center cap. I recently bought a set of monoblock forged WEDS Kneeler Force's in 18x8 +52mm which are around 24lbs or so. Coupled with the same Nokian's but in 275/65/18 the package will be at 61lbs. I'm looking forward to the weight reduction!
    Tundyfundy likes this.
  11. Aug 21, 2020 at 4:38 PM
    Elduder
    The 18" FX pros are ~23-24lbs. The 17" Six Shooters are 21lbs. That's just about the lightest you can get for a set <$1000. The fact that they look good is like a bonus.
    Voyagermike and Hurricane like this.
  12. Aug 21, 2020 at 4:45 PM
    YYCDCLTD
    YYCDCLTD New Member
    '07 DC LTD Tundra
    Bone stock
    Elduder - Thanks for the reply. I understand that these are lighter in the 17", my question though is looking at the entire equation. When downsizing to a 17" wheel, that means also more sidewall, which moves the more rotational mass further out from the center, which amplifies the effect of the weight.
    In any case, I'm all for maximum overall weight reduction to help with handling, acceleration and fuel economy. :bananadance:
    And yes, for something under $1k is awesome. My set of WEDS Keeler Force wheels was equivalent to $580USD/each + shipping from Japan.
  13. Aug 21, 2020 at 5:21 PM
    Burdturger
    Burdturger New Member
    Country of origin?
  14. Aug 21, 2020 at 6:00 PM
    wiretwister
    wiretwister Sorta new guy
    NJ
    '22 SR5 CM
    Aren't they more like ~26-27lbs?
  15. Aug 21, 2020 at 6:53 PM
    chugs
    chugs New Member
    Ciao
    Central Cali
    U got any math for your rotational mass assessment?
  16. Aug 21, 2020 at 7:34 PM
    YYCDCLTD
    YYCDCLTD New Member
    '07 DC LTD Tundra
    Bone stock
    Chugs - it's been a while since I've sat down and crunched the numbers. However, if you watch video below, it'll give you the same idea. The intent is to minimize overall mass, the further the distance the mass is from the hub, the more power your vehicle needs to accelerate (ie. to overcome inertia). That is for acceleration and fuel economy. When it comes to suspension responsiveness, it's not the distribution of the mass that matters so much as the actual mass that's reduced. Your suspension requires less effort to keep your wheel/tire in contact with the ground the lighter the entire wheel/tire is.
    https://www.youtube.com/watch?v=CHQOctEvtTY
    Like with everything though, there's a point of diminishing returns when it comes to chasing weight savings for the sake of efficiency, as the $/lb rises exponentially the more the weight you try to save.
    In my case specifically, the "sweet" spot seems to be an 18" wheel and tire combo. To get similar weights to a forged 18" wheel from a 20" wheel, you're looking at Volk TE37's which are well over $1k USD/wheel. Assuming you're using the same brand and model of tire for comparisons, the higher the aspect ratio, the thicker the sidewall, and therefore more mass is being rotated further away from the center.
    Empirical testing:
    https://www.youtube.com/watch?v=QrLjYelwVIs
    WFD473 and Hurricane like this.
  17. Sep 9, 2020 at 4:03 PM
    Elduder
    Getting back on track here:
    Good news, spoke with Dustin today and confirmed both the 5 star and Six Shooter are coming back. Currently with an ETA of early spring 2021. I know its a bit of a wait, but they will be worth it.
    I should be in touch with him in another few weeks or a month or so, as it gets closer to their re-release I will either create a new thread for a formal group buy or will put all the pertinent info for purchase here in this thread. Thanks for the interest guys, Dustin has heard you and is excited to be giving you another 17" option that will exceed the current markets quality standard in load rating and weight savings.
  18. Sep 9, 2020 at 5:37 PM
    Redcon41318
    Redcon41318 New Member
    Yay!!!
    Elduder[OP] likes this.
  19. Sep 9, 2020 at 5:39 PM
    #49
    Redcon41318
    Is it going to be a 17x8.5”, hub centric?
  20. Sep 9, 2020 at 6:25 PM
    #50
    Elduder
    FNs are hub and lug centric. The lugs have a tapered hole to center the wheel to the lugs, the center bore on all the current 6x139.7 FN wheels is 106mm which would be hub centric for the 4Runner and Tacoma. FN would make the 5x150s with the correct hub bore for the Tundra. There will be no need to worry about mounting them.
    Voyagermike likes this.
  21. Sep 9, 2020 at 6:46 PM
    #51
    chugs
    chugs New Member
    Ciao
    Central Cali
    Awesome sauce!
  22. Sep 9, 2020 at 7:11 PM
    #52
    Hurricane
    NC
    2017 White 1794
    None
    That’s awesome news.
  23. Sep 12, 2020 at 8:44 AM
    #53
    RVU01
    RVU01 New Member
    Raul
    Central California
    2018 Tundra
    I'm interested in either style. Thanks
  24. Sep 12, 2020 at 9:09 AM
    #54
    Elduder
    There will be either an organized group buy or an initial run list that will allow you to secure either wheel early next year. Thanks for the interest.
    Hurricane likes this.
  25. Oct 29, 2020 at 7:32 PM
    #55
    Redcon41318
    Any update?
  26. Oct 29, 2020 at 8:01 PM
    #56
    Elduder
    Spoke with Dustin a couple days ago because I was buying a set of 17" FX Pros for our 4Runner. Basically right now he is working on getting a factory selected, its a delicate balance. Dustin is very picky about quality so the options become limited. That coupled with the recent (last couple years) increase in raw metal costs and shipping costs can make things difficult. Regardless of that, it seems that price and quality will remain the same as they have been but timing is still being worked out. He still targeted either late Q1 or early Q2 of 2021.
    Ill post anything else that comes up.
    pvmike, Hurricane, chugs and 2 others like this.
  27. Oct 29, 2020 at 8:50 PM
    #57
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Thanks for staying on it!
    Elduder[QUOTED][OP] and chugs like this.
  28. Oct 29, 2020 at 9:15 PM
    #58
    chugs
    chugs New Member
    Ciao
    Central Cali
    @Elduder
  29. Oct 29, 2020 at 9:34 PM
    #59
    iyaman
    iyaman New Member
    2016 platinum
    +1 on being interested either style.
  30. Oct 30, 2020 at 5:49 AM
    #60
    DUKFVR
    DUKFVR New Member
    Houston & Young County TX
    2020 Cement Tundra DC SR5, Stage 1 Icon kit, LT75/60/20 Toyo AT III, Ranch Hand Midnight Bumper Replacement
    Thanks for the update!
