Gasoline
Discussion in '2.5 Gen Tundras (2014-2021)' started by Topside42, Jun 8, 2018.
  1. Jun 8, 2018 at 6:42 PM
    HecticEnergy
    HecticEnergy New Member
    TJ
    SE Texas
    2017 MGM Tundra SR5
    Winjet Rear brake lights, leather seats, BackFlip tonneau cover, Spyder headlights, Pro Grille, pop&lock
    The octane booster you throw in to clean out carbon buildup from running low quality gas (octain booster +detergents)... what kind of octane boost are we talking? I’m inclined to side with the previous commenter that said difference between 87 and 91 isn’t really enough to make a ton of difference.
  2. Jun 8, 2018 at 6:50 PM
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    87 at Costco
    UNTMatt likes this.
  3. Jun 8, 2018 at 7:24 PM
    HecticEnergy
    TJ
    SE Texas
    2017 MGM Tundra SR5
    That desiel has been coming out in the “near future” for like 10,years lol
  4. Jun 8, 2018 at 7:29 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    87 is mid grade in co
    Ike74 and 15whtrd[QUOTED] like this.
  5. Jun 8, 2018 at 7:49 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    And you want all the problems that come with the GM AFMs? I use 87. Anything else is a waste of money.
    UNTMatt and sprtbkr like this.
  6. Jun 8, 2018 at 7:51 PM
    15whtrd
    15whtrd Mr. Blonde
    So they mix 91 or 93 with 85 to give you 87?
    Im fairly certain that we get a mix of 91 and 87 to give us 89 octane.
    Luckily for me costco premium 91 is cheaper than or close to the cost of arco 91. And about the price of 87 at a top tier gas station like Shell.
    Ike74 likes this.
  7. Jun 8, 2018 at 7:54 PM
    GWalker
    GWalker New Member
    North Carolina
    2014 White Tundra Double Cab Limited
    Exxon non-ethanol 90 octane
  8. Jun 8, 2018 at 8:30 PM
    Ike74
    Ike74 New Member
    Anthony
    Sugar Land, TX
    2020 Kia Forte
    Yep, mid grade is mixed at the pump with 85 and 91 here in CO. Costco doesn't sell mid grade or else I would run 87
    15whtrd[QUOTED] likes this.
  9. Jun 8, 2018 at 8:37 PM
    15whtrd
    15whtrd Mr. Blonde
    I came from two previous vehicles that required premium. My dodge was tuned so I had to and my TBSS was high compression. It felt like a sin putting 87 in my tundra but I did. Often I ran 89 as well. Now I have the BDX, so I have to run premium.
    Ike74[QUOTED] likes this.
  10. Jun 8, 2018 at 9:38 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    LED interior lights, Baja Designs foglights, Baja Designs S8 hood bulge light bar, LED bed lights, Baja Designs S8 amber bar in bumper on Rago Fab mounts, AMP Research bedstep, Switch Pros sp-9100, tinted door windows
    A lot of it.
    Usually in the form of the low octane cheap stuff.
    But in Baja, Premium PEMEX.
  11. Jun 8, 2018 at 10:09 PM
    trdprobped17
    trdprobped17 New Member
    Mine is 2017 flex fuel and the gas cap is also black.
  12. Jun 8, 2018 at 10:25 PM
    Rica25
    Ricardo
    Tulare
    89 from shell or chevron for the last 10 yrs
  13. Jun 9, 2018 at 6:51 AM
    Max Power
    Max Power Groovy Member
    2018 SR5 TRD Off Road
    TRD Dual Exhaust TRD Rear Sway Bar
    I usually fill up with 87 from the local Mobil station. There is also another Mom and Pop place nearby, I also fill up there with 87. I was unsure about the top tier gas thing with the Mom and Pop, but on their pumps there are stickers claiming it is Gulf fuel with additives. Truck has always run fine.
  14. Jun 9, 2018 at 7:46 AM
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    Costco regular. Never heard it knock.
    UNTMatt likes this.
  15. Jun 9, 2018 at 8:26 AM
    Max Power
    The arguments I've heard against is that cylinder deactivation causes uneven wear on the engine. But that's just what I've read, I don't personally have any knowledge of engines other than I like V8's cause they're powerful and sound awesome when you step on it.
    HecticEnergy[QUOTED] likes this.
  16. Jun 10, 2018 at 11:34 PM
    Devcom
    Devcom Miles per Gallon? More like Smiles per Gallon!!
    2018 Blazing Blue Tundra Double Cab SR5 5.7L 4x4
    Just recently did my first fill up and I put 87 in from a Top Tier station. Runs awesome and has tons of power. :) Three weeks ago when I took delivery of my truck the dealer filled it up with 87 at a nearby Quick Trip which I think is still a top tier station.
    EDIT: My Tundra is a FFV however I do not plan on putting E85 in it.
    HecticEnergy likes this.
  17. Jun 11, 2018 at 12:14 AM
    HecticEnergy
    TJ
    SE Texas
    2017 MGM Tundra SR5
    I’d use it if it was way cheaper than gas I think... like half price. I’d still run some regular fuel in it every couple of fill ups though just to clean the crap out a little better... but I’d have to do more research and try it before I committed for or against lol
    Devcom[QUOTED] likes this.
  18. Jun 11, 2018 at 1:08 AM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    I had a slight she'll also a my gas cap is black and it just says that I can use E85 in my trucks a 2014
  19. Jun 11, 2018 at 3:07 AM
    #49
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    It's usually .75-1.00/gallon cheaper here in PA. Every once in awhile we'll run a tank in my wife's Durango to save some cash but the mileage drops from a consistent 22-23mpg to 15-16.
  20. Jun 11, 2018 at 5:04 AM
    #50
    HecticEnergy
    TJ
    SE Texas
    2017 MGM Tundra SR5
    Yeah, I heard it’s like 20-30% reduction in efficiency. Also gunks up the engine quicker.
    I haven’t seen any e85 pumps out here, but I havent really been looking for it either lol GasBuddy.com says regular (at Costco) is 2.49, e95 is 2.40... I’d burn through more faster and it’d end up costing me 15-25% more or so...
  21. Jun 11, 2018 at 2:25 PM
    #51
    DustinP5
    DustinP5 New Member
    Austin, TX
    2015 Magnetic Grey SR5 Crewcab
    Retrofit Headlights, Heated/Cooled leather seats, Leveled, Pro Grille, Wireless counsel charger, TRD Shif Knob
    Shell, then Valero
    anthonygan likes this.
  22. Jun 14, 2018 at 7:24 AM
    #52
    UNTMatt
    UNTMatt New Member
    2015 Attitude Black 4x4 Limited
    TRD Pro grille, TRD Pro black badging, TRD Pro shift knob, LED under dash lights, GBS, Llumar ceramic tint, BackFlip HD.
    Usually Costco regular grade (iirc, 87 octane) since there is a Costco three minutes from our house. That being said, on road trips, I usually try for top tier fuel in regular. My personal opinion is that mid grade and premium in the Tundra is a waste of money (unless it's supercharged).
    --Matt
    WAtundra4x4 likes this.
  23. Jun 14, 2018 at 7:28 AM
    #53
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
  24. Jun 15, 2018 at 9:40 PM
    #54
    TundraNoCo
    TundraNoCo New Member
    Northern Colorado, FoCo
    2018 Toyota Tundra Platinum
    Bed lined, tinted all 5 windows, hose clamped tailgate, toolbox, steps, ESP rear seat storage bins, dash cam, anytime camera switch, console safe, pop a lock for tailgate and wheels/flares, sway bar. I have Techstream if anyone local needs it.
    I sell gas for a living. Never, never use E85. 33% reduction in BTU content, unregulated for the most part, and it's VERY corrosive on the entire fuel system. Stick to top tier fuel as previously mentioned. A good website for reference to good fuel is toptiergas.com. Stay away from anything that isn't listed, as they typically buy whatever is left on the spot market. Retailers such as grocery stores, etc., (not including Costco) are not top tier. It does make a difference, and if you spend 30k-50k on a vehicle, a few cents per gallon savings is likely not worth it. As always, you get what you pay for. IMHO, stick to the majors. They are regulated and have regular marker testing at the dispenser, to assure they are selling the real deal. Shell, ConocoPhillips, etc. Just my 2 cents.
    15whtrd, WAtundra4x4 and HecticEnergy like this.
