gas tank
Discussion in '2.5 Gen Tundras (2014-2021)' started by Jasejaven, Sep 6, 2016.
  1. Sep 6, 2016 at 4:21 PM
    Jasejaven
    Jasejaven [OP] New Member
    is there a way to tell what size gas tank you have other than the sticker on the vehicle or what the dealer says? For example does it say it on the vehicle somewhere?
  2. Sep 6, 2016 at 4:24 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    When you're near empty and fill up, if you only pump about 20 gallons, you have a 26 gallon tank. If you pump over 30, you have a 38 gallon tank.
  3. Sep 6, 2016 at 4:25 PM
    ToyotaTundraMike
    2015 Tundra
    When its on empty and you fill up how much can you put in?
    If its around 18-20 then you have the 26 gal tank.
    If its around 29-31 then you have the 38 gal tank.
    joonbug likes this.
  4. Sep 6, 2016 at 4:25 PM
    Jasejaven
    That's the only way?
  5. Sep 6, 2016 at 4:26 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    That will definitely tell you since there's only 2 choices. What are you trying to figure out?
  6. Sep 6, 2016 at 4:27 PM
    ToyotaTundraMike
    2015 Tundra
    How many miles til empty does it say after you fill up?
  7. Sep 6, 2016 at 5:01 PM
    Jasejaven
    usually it says like 450. I just wanna make sure I have a 38 gallon tank since I paid for it.
  8. Sep 6, 2016 at 5:14 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    2016? I think they're standard on all models except maybe the SR & SR5. Limited, platinum, pros, 1794... All have 38 gallon.
    Edit:
    SR5 gets it with the SR5 upgrade option.
  9. Sep 6, 2016 at 6:18 PM
    Jasejaven
  10. Sep 6, 2016 at 6:26 PM
    Sarcastic 3rd choice.... Fill it up, drill a hole in the gas tank, drain, see how many gallons come out or....... use old school geometry. Measure Length X Width X Height =Volume. Works every time. Our tank is not a perfect cube but you can get pretty close with LxWxH.
    http://www.wikihow.com/Calculate-Volume
  11. Sep 6, 2016 at 6:28 PM
    Jasejaven
    ha... that's funny.. I never liked math.
    Black Wolf likes this.
  12. Sep 6, 2016 at 6:31 PM
    ytank1
    ytank1 New Member
    MD
    I had to replace my gas tank as soon as I got my truck and when I filled it up from empty it took a little over 28 gallons. That being said it also read 600 miles till empty so I know there is a 38 gallon tank. From what other members are saying Toyota does that on purpose so people don't drive on fumes. Hope that helps
    BlueFalconActual likes this.
  13. Sep 6, 2016 at 6:33 PM
    Math sucks, unfortunately I have to use it evey day at work. I'm pretty sure I still have about 6 gallons left when the low fuel light comes on. I rarely get to that point. I think most here with the 26 gallon will agree that you have about 6 gallons left. 60 to 70 miles for me. I'd like to have the larger tank. I'm pretty sure you have the larger tank. Light on?? Maybe still 6 gallons left? 8?? Don't know for sure.
    aperezsh likes this.
  14. Sep 6, 2016 at 6:42 PM
    Jasejaven
    ok Im going to see what my miles say tonight after I fill up.
  15. Sep 6, 2016 at 7:38 PM
    Sierra_Nevada
    Sierra_Nevada New Member
    Kansas City
    2020 Magnetic Gray Platinum
    TRD Pro Fox Suspension, SCS Ray 10 Wheels, BFG KO2 275/70 R18
    For comparison purposes, I filled up my truck tonight. The computer was showing 58 miles to empty and I put 28.3 gallons in it. I filled it to the first click of the gas pump, since I've read that topping it off is bad for the emissions system or charcoal canister. When full, the computer showed 451 miles to empty. I'm not sure what timeframe or MPG calculation the computer uses to determine miles to empty, but the last hour of driving was normal around town, during which I usually average about 15.5 MPG. The five hours before that were towing a trailer, during which I average 11-12 MPG.
    Jasejaven[OP] and Black Wolf like this.
