Gas tank supposed to hold 38 gallons?
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Dlg_69, May 12, 2017.
  1. May 12, 2017 at 6:39 PM
    Dlg_69
    Dlg_69 [OP] New Member
    Louis
    Orange County, CA
    2017 Super White TRD Pro
    So my window sticker says 38 gallon tank, but I have never put more than 30 gallons, even when I have ran it down to 20 miles left in the tank.
    Has anyone else noticed this? Should I take my TRD Pro back to the dealerahip?
  2. May 12, 2017 at 7:31 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Yeah. You'll never pump more than 30 gallons on a fill up. For someone like me that likes to do the math, it drives me nuts. But understand why it's like that and it is what it is.
    SouthBoundSteve likes this.
  3. May 12, 2017 at 7:33 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Yes it holds 38 gallons.. I did the real test and drove it till it was damn near empty when I first got it. Once the light comes on and says like 30 miles left. I drove it around for another day and half.. it took 36 gallons that time. So I still could have drove a few more miles.. it's 38 for sure.. cheers
  4. May 12, 2017 at 7:40 PM
    Dlg_69
    Louis
    Orange County, CA
    Thanks for the responses. I tried a few searches before but didn't yield any results, hence my post.
    Not certain if I feel better, but I am not alone.
    TXMiamiFan likes this.
  5. May 13, 2017 at 6:30 AM
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    2017 White DC TRD PRO
    So I wanted to double check this as I have run into the same thing. Last take I ran it past 0 miles until empty. I got to the point where it would not longer calculate, it just said low fuel. When I filled up I still couldn't fit any more than 30 gallons in the tank. I guess it requires 8 gallons to submerge the pump. That or Toyota is lying to all of us haha
    Dlg_69[OP] likes this.
  6. May 13, 2017 at 6:59 AM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    If you were to totally run it out of fuel it would be 38 gallons. This is Toyota protecting their reputation on reliability by keeping that pump nice and cool. You'd be surprised how many morons there are that keep their tank under 1/4 full at all times.
    07DCLimited, tomsinamerica and JH5370 like this.
  7. May 13, 2017 at 7:07 AM
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    I totally agree. I am usually a fill up at 1/2-1/4 kind of guy but wanted to calculate my mileage so figured I would see how accurate the computer was. 30 gallons calculated out to 14.88 mpg and the truck computer said 15.0. This was only the trucks second tank of gas mostly city. So I'm a assuming I will get a little more but stay in the 15 mpg range.
  8. Apr 30, 2022 at 2:16 PM
    2017_Tundra_AZ
    2017_Tundra_AZ New Member
    Yea, one time I went 80 miles past my display said "0 miles tell empty" and I only filled up 36.5 gallons. I get 13.5 mpg, so I should have been able to go about 20 miles more. I totally agree that this is to keep the pump nice and cool. I believe as long as you have fuel running through your pump you will be fine, but I still fill up when I'm at 1/4 of a tank.
