Gas tank roll-over valve stuck causes hard fuelling - anyone else?
Discussion in '2.5 Gen Tundras (2014-2021)' started by baguafan, Mar 20, 2019.
  1. Oct 12, 2021 at 6:53 PM
    #91
    Drainbung
    Drainbung Some days you are the show...
    Bob
    Oasis of NV
    2019 Cement DCLB 4X4
    TRD Fleshlight
    eccracer104 likes this.
  2. Oct 12, 2021 at 7:49 PM
    #92
    eccracer104
    eccracer104 Dirty Paws Off-Road
    San Diego, CA
    2011 Tundra 5.7 4x4 CM
    Yup sure did. It was covered under the emissions warranty.
    Same year, trim and all that as OP.
    SAGE63, 831Tun and Drainbung[QUOTED] like this.
  3. Oct 12, 2021 at 8:37 PM
    #93
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Depends what dealer you go to. Glad you chose one with more integrity than most.
    eccracer104[QUOTED] likes this.
  4. Oct 12, 2021 at 8:41 PM
    #94
    SAGE63
    San Diego County
    @eccracer104 Where did you go for your repair?
  5. Oct 12, 2021 at 11:23 PM
    #95
    bensky
    bensky PlatinumPro
    Ben
    Utah
    2018 Red Platinum Tundra
    I agree with the emissions warranty coverage. Especially if your in California. Also, call Toyota and let them know it overflows every time you fill up. So you’re putting a dash cam on the side window to record when it catches fire. That way it can be a $100 million from Toyota.
    DeesCrewMax and eccracer104 like this.
  6. Oct 12, 2021 at 11:43 PM
    #96
    eccracer104
    San Diego, CA
    Yup! Very glad. This dealer has been good to us.
    Poway Toyota. Just told them what was wrong and they handled the rest. I didn’t even have to mention warranty.
  7. Oct 13, 2021 at 5:23 AM
    #97
    Hostage81
    Hostage81 New Member
    SMJ
    Planet Earth
    2021 Trd Off Road
    Stock
    I use to have the same problem on a few Mustang Gt's I owned. I put the nozzle in upside down when refueling and it worked for me and never had a problem again. I don't know why that worked but it always did.
  8. Oct 13, 2021 at 7:13 AM
    #98
    Kfrog
    Kfrog New Member
    2016 Tundra SR-5
    Typo, it's was a 6/32" that I used purchased from Home Depot.
  9. Oct 13, 2021 at 7:34 AM
    #99
    Kfrog
    Kfrog New Member
    2016 Tundra SR-5
    If the valve is sticking and you dislodge it without doing anything to prevent it from reoccurring again, it will continue to be a problem and you can't keep removing tank each time you fill up or sticking something down tank to open valve. Another thing that occurs is the line to carbon canister will fill with gas because of overfilling tank. that is sitting there and clicking fuel pump to get that extra half gallon of gas in it that will fill line and vapor canister with liquid preventing displaced air from escaping that will back up the fuel tube.
  10. Oct 13, 2021 at 7:57 AM
    #100
    GodlessPro
    GodlessPro Bougie BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
    Interesting, so in California the fuel tank is covered for 7 years or 70,000 miles. Now I have to decide if it's worth my time to deal with a bunch of idiots or work around it myself.
    joonbug and 831Tun like this.
  11. Oct 13, 2021 at 8:05 AM
    #101
    eccracer104
    San Diego, CA
    The idiots broke the clips on my truck and it took a day longer than quoted to get new clips. Thankfully zero issues since. I’d recommend it. I think they had my truck for 3-4 days in total.
    joonbug, 831Tun and Drainbung like this.
  12. Oct 13, 2021 at 8:14 AM
    #102
    GodlessPro
    Matthew
    NorCal
    They told me me that my aftermarket skid plate was dented which caused the valve to stick and they wanted $2600 to replace it, I told them the tech was lazy and incompetent and not to touch it. I should probably go to a different dealership.
  13. Oct 13, 2021 at 8:43 AM
    #103
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Take the damn skid off first
  14. Oct 13, 2021 at 8:47 AM
    #104
    GodlessPro
    Matthew
    NorCal
    If I'm going to take it to a different dealership I'll try to take it off, I'm not sure it'll ever come off without cutting something
  15. Oct 29, 2021 at 1:42 PM
    #105
    GodlessPro
    Matthew
    NorCal
    So I took my truck to a different dealership and they wouldn't do anything because the first dealership made a note in the service record about the skid plate causing the problem. I had even removed the skid plate, so that they could get a clear view of the fuel tank. What's the best way to escalate to Toyota Corporate?
    831Tun and joonbug like this.
  16. Nov 23, 2021 at 11:15 AM
    #106
    Mwray8909
    Mwray8909 New Member
    Chino Valley
    18 TRD offroad cement CM
    I went for a drive from Prescott to Jerome in AZ all on dirt and now we can't fill our tank. I'll be diving into fixing this myself today.
  17. Nov 23, 2021 at 11:22 AM
    #107
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    It was just before Jerome where I learned my valve was stuck. Must be something in the air there.
    Mwray8909[QUOTED] and GodlessPro like this.
  18. Jan 4, 2022 at 11:17 AM
    #108
    jessenavarro
    jessenavarro New Member
    Jesse
    Oak Glen, CA
    2018 White Tundra TRD Off-Road 4x4
    Front Fox 2.5 Coil-over shock with adjustable reservoir -- DSC Rear Fox 2.5 shock with adjustable reservoir -- DSC Total Chaos Fabrication UCA -- tubular Method Race Wheels MR701 18x9 + 25mm -- Matte Black BFG KO2s - 35x12.5x18 Demello Sliders RetraxPro XR bed cover Yakima Roof Rack setup Baja Designs S8 40" light bars x2 (amber and white LED) Baja Designs Squadron Pro ditch lights Baja Designs Squadron Sport fog lights Switch Pros SP-9100 Midland MXT400 GMRS radio
    I fixed mine this week. Local Toyota wanted $2600 to replace tank. I ended up buying a flex endoscopic diagnostic camera and saw the problem was the roll over valve. I didn’t want to pay $2600, so I dropped the back end of the tank’s straps and lowered the tank about 8 inches. Then took a 9 3/4 pick I bought on Amazon and opened the valve. It closed back up, so I took a slightly curved pick and put a small dent on the corner of the valve cover and now it doesn’t close all the way. Has been working for the last 4 tank fills and no problems!
    eccracer104, Drainbung and 831Tun like this.
  19. Jan 4, 2022 at 1:20 PM
    #109
    Kfrog
    Kfrog New Member
    2016 Tundra SR-5
    Many people have had an issue with valve, you're calling roll over valve but it's purpose is to prevent vapors from escaping while fueling. The spring loaded flop valve is set to weight of fuel forces it into a column as you fuel with the displaced air going out the carbon filter to be cleaned of gas vapors. The gas sloshing around in tank hits this valve and due to poor seating it will get lodged into the fill pipe as you have seen. So off road or rough road compounds this issue. If a truck was to roll over fuel would leak out the carbon filter because of it being lower than the flow valve in this position. So unaware why the name roll over but many of us have fixed similar to your method. Thanks for the memo, glad all is good.
    831Tun likes this.
  20. Jan 4, 2022 at 2:21 PM
    #110
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    So, we call it the anti-vapor valve? :) Maybe something catchier like Fart Stopper?:rofl:
    Retired Blue and joonbug like this.
  21. Jan 8, 2022 at 6:37 AM
    #111
    cran2
    cran2 New Member
    Folly Beach, SC
    07 Crewmax 4x4 and 03 Sequoia 4x4
    05F3CC27-215F-4E70-995B-284CC4D7FBB7.jpg @jessenavarro thanks for this post. I have an 07 with the 26 gal tank that has been hard/slow to refuel since at least 2010! Your scope and pick idea was great. I bought both and took this pic which looks like yours except I don’t have that “cage”.
    Is the photo showing the valve in the stuck position? Or is the photo showing the valve in its natural position but it is sticking in that position when trying to fuel the truck?
    I haven’t attempted any bending etc yet, but just making sure I have a clear understanding of what I’m seeing. I also thought about adding fuel while the camera was in there but don’t know if that’s safe haha!
    Many thanks!
    831Tun likes this.
  22. Jan 8, 2022 at 8:11 AM
    #112
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Yep, that's stuck closed.
    joonbug and cran2[QUOTED] like this.
  23. Jan 8, 2022 at 9:00 AM
    #113
    Vizsla
    Vizsla pretend2send
    The default position for the valve is closed, but not stuck closed.
  24. Jan 8, 2022 at 9:59 AM
    #114
    cran2
    cran2 New Member
    Folly Beach, SC
    Ok. So as pictured it is in its default position? That makes sense to me, that way it diverts the fumes.
    @831Tun You say its struck closed. Is there a way to determine if it is struck by just looking at it?
    Just trying to figure out how to best diagnosis the cause, since I’m aware it could also be the evap canister.
    Thanks for the help!
    831Tun[QUOTED] likes this.
  25. Jan 8, 2022 at 10:07 AM
    #115
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I think @Vizsla is right and it'd look like that even if it's operating correctly. But, when I repaired mine, it sprang open with force which has always had me believing it's normally open. All I can suggest is physically poking it with a long, thin tool.
    GodlessPro, joonbug and cran2[QUOTED] like this.
  26. Jan 8, 2022 at 7:35 PM
    #116
    Kfrog
    Kfrog New Member
    2016 Tundra SR-5
    This valve has a spring that closes valve and is normal position so you don't have a lot of vapors escaping forcing venting thru carbon canaster. If you're off-roading or on rough roads with gas sloshing around in tank it could cause gas to wedge valve into fill tube again. The weight of gas filling the input line is what opens the EVAP that forces gas into a column not allowing escaping or displaced air up fill pipe but forcing it thru carbon filter. For info, this is also part of your emission controls that was started in 80's, I think.
    cran2 and 831Tun like this.
  27. Jan 10, 2022 at 11:12 AM
    #117
    GodlessPro
    Matthew
    NorCal
    This is what confuses me, if you touch it with minimal force it will "spring" open. I understand what people are saying about the normal position being closed, it makes sense if it is a vapor valve, but that doesn't match up with my interactions with it.
    cran2 and 831Tun[QUOTED] like this.
  28. Jan 11, 2022 at 3:16 PM
    #118
    zeekevin
    zeekevin New Member
    I am starting think it’s an issue with the evap canister for my truck. Even forcing the flap to stay open, I can not fuel up normally at a California gas station. I have to slowly let fuel in and hold the vent gasket on the nozzle open so there isn’t pressure build up to stop the pump.
  29. Jan 11, 2022 at 5:45 PM
    #119
    Kfrog
    Kfrog New Member
    2016 Tundra SR-5
    It could be the canister filled with gas not allowing displaced air to escape and vent. The carbon canister on my 2016 is located behind and above fuel tank that has a large line about 1" dia. connecting the tank and canister. You can test carbon filter for blockage by disconnecting this line and try filling, if filling remains difficult you can feel for escaping air on line coming from tank and assume something is wrong with valve not opening properly when filling. I would not think this line is blocked. Should all work well and you can fill as normal you can assume assume the carbon filter is blocked, this is the reason for not overfilling tank by continually trying to get that last half gallon. I hope this helps you,
    zeekevin and cran2 like this.
  30. Jan 27, 2022 at 6:26 PM
    #120
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    I have the 38 gallon tank and am debating just upgrading to the 46 gallon tank. I dont want to replace the 38 gallon tank and get the same problem. Anyone done this?
