Gas saving mode at 25mph
Discussion in '2.5 Gen Tundras (2014-2021)' started by Coffee*8), Oct 2, 2020.
  1. Oct 3, 2020 at 12:30 AM
    18" TRD Off Road Wheels
    I read up on it. I stand corrected that the injectors are turned off for brief periods of time. However, combustion continues with what fuel remains, and if it decreases too far to where there would be too much air going into the catalytic converters it will pulse the injectors to maintain combustion. The truck doesn't ever deactivate cylinders, and combustion never ceases.
    Enough of the thread jacking, for the OP, here's a link. It is a little older, but the engine is the same, and Mike Sweers talks about the knock on deceleration. It has absolutely nothing to do with fuel being shut off.
    https://www.autonews.com/article/20...-engineer-defends-choice-of-carryover-engines
    Blue Thunder, Jtundra81 and TTund16 like this.
  2. Oct 3, 2020 at 12:33 AM
    Kelvin
    Kelvin New Member
    Even my old 3uzfe has fuel cut. 2uzfe also has it I believe.
    No clunking though. My moms GX460 is the clunkiest drivetrain I’ve ever had the pleasure of driving. She’s had two GX460’s and both did it so I always just assumed it was because of the full time 4WD.
    Wynnded and ViktorG[QUOTED] like this.
  3. Oct 3, 2020 at 12:38 AM
    ViktorG
    ViktorG Lexus/Toyota Master Tech
    Viktor
    Calgary, Canada
    2010 RCSB and 2008 DCLB
    World's fastest supercharged Tundra - 2010 RCSB - 10.8 @122 - All wheel drive conversion, lowered, supercharged 2008 DCLB - All wheel drive conversion, 13" lift on 37's
    Yeah, the GX is notorious for the rear driveshaft slip yoke clunk. Make sure it gets greased every service. (Some places don’t ever grease it)
    Kelvin[QUOTED] likes this.
  4. Oct 3, 2020 at 12:44 AM
    Kelvin
    Kelvin New Member
    I don’t hate a lot of things but keeping a leaking grease gun around is one of them. All the ones I’ve ever bought leaked before I could even get through half the tube of grease.
    GODZILLA likes this.
  5. Oct 3, 2020 at 12:45 AM
    Coffee*8)
    Coffee*8) [OP] New Member
    Pennsylvania
    2020 Tundra Crew Max
    + Trans cooler
    it happens when I accelerate, is very reproduceable, happens every time. Not sure if fuel shutoff has anything to do with it. It is late now but tomorrow I will try using S mode while the 'choke' is still on (so fuel does not shut off) and seeing if I coast in reduced gear at 30 mph and accelerate if I get the same noise. Will point to slack in the drivetrain if still does it.
    ViktorG likes this.
  6. Oct 3, 2020 at 1:00 AM
    TTund16
    TTund16 New Member
    you are not old just following the speed limit. lol
    You can even get a ticket doing 29 in 25 :monocle:
    10TundraSR5 likes this.
  7. Oct 3, 2020 at 4:38 AM
    1970CST/10
    1970CST/10 New Member
    Shea
    Van Buren, AR
    2020 Black SR5 CrewMax
    I have actually felt this numerous times myself in the first 800 miles truck has now. Only at low speed like you’re saying. Scared the hell out of me the first couple times lol. I’ve been trying to figure out how to replicate it so I could show dealer. Searched on here and couldn’t find anything so figured it must not be a common tundra thing.
  8. Oct 3, 2020 at 6:16 AM
    Clemsonman14
    Clemsonman14 New Member
    2020 SR5 Crewmax 4x2
    thank sweet baby Jesus it doesn't. That shit is nothing more than a gimmick
  9. Oct 3, 2020 at 7:05 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Yep, I don't know about the automatics, but the manuals would cut fuel above a specific RPM when the throttle was closed.
  10. Oct 3, 2020 at 8:21 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I was under the impression the torque converter was pushing things at that point but I'm not sure where I got that idea or how exactly it's supposed to work.
  11. Oct 3, 2020 at 8:39 AM
    I believe that is correct, but combustion is still occurring.
  12. Oct 3, 2020 at 8:41 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    How is combustion happening without fuel?
    Darkness likes this.
  13. Oct 3, 2020 at 8:49 AM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    Gear backlash combined with axle rotation and motor mount deflection. When the pcm cuts fuel the torque is applied to the axle/driveshaft/transmission in the opposite direction and the whole system moves a bit.
    If the driveshaft slip joint is a tiny bit stuck that will make the clunk bigger
  14. Oct 3, 2020 at 8:54 AM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    If you watch in live time the dfco on the Tundra is very inconsistent. If you touch the throttle for just a second it will cancel it most of the time and it usually won't cut fuel when canceling cruise unless the brake pedal is pushed.
    If you want to be sure for it to dfco, be >35mph with foot depresssing the accelerator pedal at least 5 seconds and release. Do not touch again
    I wish it was like my old Honda: over 25 mph and in gear and foot off the pedal = always dfco, no other variables
  15. Oct 3, 2020 at 8:56 AM
    How is there still the same exhaust and engine sound without combustion? Also, read the info that Viktor posted a pic of in the last post on page 1. The whole thing. It pulses the injectors if the air content would get high enough to cause issues at the cats.
    My best guess is that the fuel pulse happens frequently enough to maintain combustion. Think about how rapidly and often combustion happens in an engine. It could cut fuel repeatedly throughout the process in small amounts to decrease fuel usage, and still pulse it often enough that our human senses couldn't detect it. It would sound like continuous combustion.
    Kinda like the LED DRLs. Look at it with your naked eye and its constant, but point your phones camera at it and the pulses appear. How does it shine light when it clearly turns off? Same thing here for fuel cut off?
  16. Oct 3, 2020 at 10:19 AM
    Coffee*8)
    Pennsylvania
    + Trans cooler
    That is what I am trying to figure out as well. Does this happen on all trucks or just some.
    I tested today in s3,s4,s5 modes while engine was still cold. Got to 30 let it coast to 25 then applied the throttle. No slack or clunking at all.
    I will need to take it to Toyota service and see what they say.
  17. Oct 3, 2020 at 10:25 AM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    ( My wife tells me to just drive faster and problem solved.)
    WaLaa...
    Your Wife’s got some wisdom.
    :boink:.
    Welcome aboard from NorCal.
    ToyoMafia likes this.
  18. Oct 3, 2020 at 11:10 AM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    It's not combustion you're hearing. If you really want to find out, decelerate in a low gear down a hill or something and kill the engine. The sound doesn't change. I don't recommend it because you lose power brakes and power steering, but maybe then you'd be able to wrap your head around it.
    From a technical standpoint you don't want any sort of meaningful combustion taking place under deceleration. Cylinder compression is too low and manifold vacuum is too high which is a recipe for unspent fuels and misfires. I'm aware that the injectors will pulse if needed, but it's not a constant cycle, if at all in most real world cases. I use engine braking when coming down mountain passes, and I can tell when they kick on because you can feel the speed pick up, then slow down again. I think it opens the throttle blade a little to let some air in. Maybe @ViktorG can enlighten me a little on that.
    Darkness, Sundown5oh and Sunnier like this.
  19. Oct 3, 2020 at 11:11 PM
    #49
    TTund16
    TTund16 New Member
    Op,
    Fyi
    I tried what you did and didn't hear any noise. Mine is a '16.
    Going to read your post again and try again ...
    ccrews and Coffee*8)[OP] like this.
  20. Oct 4, 2020 at 5:25 AM
    #50
    Zero One Actual
    Oh. Your inception game is strong sir. I salute you.
    Tundyfundy and Darkness like this.
  21. Oct 4, 2020 at 5:36 AM
    #51
    Dragracer_Art
    Dragracer_Art New Member
    Dawsonville, GA
    2020 Crewmax 4x4
    5100's/+2.5" Eibachs, 18x9 +25 Methods,37x12.5 BFG KM3's
    Thats basically a fancy vacuum guage.
    Less pedal = more vacuum = better economy
    More pedal =less vacuum = more fuel used.
    It really is that simple.
  22. Oct 4, 2020 at 5:46 AM
    #52
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Some? :rofl::rofl:
    Cpl_Punishment likes this.
  23. Oct 4, 2020 at 7:20 AM
    #53
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    And you can see this in realtime with an afr gauge. Use engine braking and afr goes max lean.
  24. Oct 4, 2020 at 7:36 AM
    #54
    Coffee*8)
    Pennsylvania
    + Trans cooler
    what speed does engine braking turn off at on the 2016? I know my 2015 would engine brake at 45 mph but never figured out at what speed it turns off. On my 2020 it turns off at 22mph.
    To figure out what speed it turns off at bring it to 45 and release the throttle. Engine pitch will change (rpms increase slightly) as the torque converter locks and fuel is shut off. Will feel the truck slowly but very slightly.
    At some speed the engine braking will turn off. Torque converter will unlock (rpms will drop slightly), gas will be injected again and truck will cost easer.
  25. Oct 4, 2020 at 7:58 AM
    #55
    DIYDad
    DIYDad New Member
    2020 Tundra 1794
    My '00 tundra would clunk when the driveshaft needed grease too. the 2020 doesn't do that yet, but that's the first thing I'd check when/if it does.
  26. Oct 4, 2020 at 8:10 AM
    #56
    Sunnier
    Sunny
    San Diego, CA
    That indicator isn’t exact. It kind of represents your mpg, but it takes a second to register and reflect changes, so that’s why it shows 0 when you take your foot off the gas pedal, then gives a reading again a second or so later (which happens to coincide with the 20mph in your example).
    You can reassure yourself this is true by doing the opposite: cruise along at any old man speed you like then, when you check your mirrors and see @hagrid coming up behind you, punch and hold the gas pedal. The truck will do what V8’s do, but that mpg indicator will lag a bit in showing you a fully-pegged (ALL the gas) mpg reading.
    Try it. It’s fun!
    :burnrubber:
  27. Oct 4, 2020 at 6:06 PM
    #57
    Coffee*8)
    Pennsylvania
    + Trans cooler
    My other car is a 2002 Honda Civic si(manual transmission). When I take my foot off the gas and coast to a stop it makes some beautiful sounds that can be heard indoors in houses I am passing by. But those sounds only happen when no fuel is being injected. Once it slows down enough where the gas starts flowing again the beautiful noise goes away.
  28. Oct 4, 2020 at 8:25 PM
    #58
    Redrider29
    Redrider29 HARDTRD
    Mitch
    2019 SR5 Crewmax TRD Offroad 4x4 Cement
    Paint matched mirror caps, grill surround, hood bulge, and Bumper Shellz Wireless phone charger in center consule TRD rear sway bar Black painted TRD off road wheels with TRD center caps Black emblems TRD air filter Tyger roll up tonneau cover Extra USB plugs in cab TRD Pro grill Paint matched Bumper Shellz 1.25" Spider Trax spacers Lamin-x fog light covers yellow-removed Diode Dynamics SS3 amber fogs Bilstein 5160 rear shocks DIY bed rail system AJT TSS relocation bracket AJT interior chrome delete bits and pieces Caliraised LED 32" light bar bracket GG Lighting 32" light bar
    Coasting
    YardBird likes this.
  29. Oct 4, 2020 at 8:34 PM
    #59
    Kanobi13
    Kanobi13 New Member
    What kind of old man goes 5 over the limit!!!!!
    Tundyfundy and TTund16 like this.
  30. Oct 5, 2020 at 3:45 AM
    #60
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    Is that also called the propeller shaft? I believe that's what they call it in the manual?
    Tundyfundy and ViktorG[QUOTED] like this.
