Gas Mileage
Discussion in '2.5 Gen Tundras (2014-2021)' started by meansj, Dec 14, 2015.
  1. Dec 14, 2015 at 6:04 AM
    meansj
    meansj [OP] New Member
    jovan
    2015 tundra flex fuel 5.7
    I have a 2015 Tundra 4x4 5.7 flex fuel with 4,500 mileage. Purchased in July 2015 Houston Texas
    I'm only getting 297 for full tank. krogers fuel highest grade.
    Is something wrong or the wrong gas?
  2. Dec 14, 2015 at 6:09 AM
    Armyretired25
    Armyretired25 New Member
    Northern Alabama
    2016 Plat 4x4 CM
    Dual Exhaust - Black Grill - Back Seat Storage -
    Size of your tank?
  3. Dec 14, 2015 at 6:12 AM
    meansj
    jovan
  4. Dec 14, 2015 at 6:13 AM
    I fuel up at around 1/4 quarter tank at 237 miles.
    My fuel ups usually display around 300 miles...this is calculated based on your driving patterns.
  5. Dec 14, 2015 at 6:29 AM
    meansj
    jovan
    Thanks
  6. Dec 14, 2015 at 8:59 AM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    That calculates out to about 11.25 MPG, which does seem a bit on the low side. I averaged right around 14 before my lift and big tires (now around 13.5). First the obvious, are you using 4WD very often if at all? lots of short trips?
    I should also mention that if you are using premium on an otherwise stock truck, you are effectively throwing away the monetary equivalent of 2-3 MPG. The factory tune does not take advantage of the additional octane.
  7. Dec 14, 2015 at 12:20 PM
    meansj
    jovan
    No 4wd. I will start using lower grade of gas.
  8. Dec 14, 2015 at 12:20 PM
    meansj
    jovan
    Thanks
  9. Dec 14, 2015 at 1:01 PM
    mdavis likes this.
