Gas mileage when towing?
Discussion in 'Towing & Hauling' started by Dice211, Nov 10, 2018.
  1. Mar 1, 2020 at 7:42 AM
    AZBoatHauler
    So.Arizona
    Good point here. This will make a significant difference in fuel consumption.
  2. Mar 1, 2020 at 1:11 PM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    2017 Tundra 5.7L 4WD DC TRD
    2020 GD 2670MK Travel Trailer
    I tow a TT that is 8,000 lbs or so. I average around 9.2 mpg when running in S4 which is what I usually use. If I drove in Automatic (which I would only use on very flat terrain), it would increase 1-1.5mpg.
    Buckaroo
  3. Mar 1, 2020 at 1:14 PM
    Bassn429
    Bassn429 New Member
    Sucks. But we buy them to look pretty....lol and reliability
    r1-superstar likes this.
  4. Mar 1, 2020 at 2:08 PM
    timsp8
    NY
    Yep. 8-10. Worse if you have a lift and bigger tires.
  5. Mar 1, 2020 at 3:21 PM
    KMG
    KMG New Member
    Kevin
    Yacolt, WA
    2018 White Tundra Limited DC 4x4 TRD
    BFG KO2s, TRD Rear Sway Bar, Firestone RideRite Air Bags, B&W Gooseneck Hitch, Trail Ridge Extendable Towing Mirrors
    Pulling my 5th wheel I get as low as 5.5 going through the rockies and as much as 9.5 through Kansas with a tailwind. I travel 65-75mph.
    TTund16 likes this.
  6. Mar 1, 2020 at 8:31 PM
    TTund16
    TTund16 New Member
    5.5 :eek:
    how much does your 5th weigh?
  7. Mar 1, 2020 at 8:33 PM
    shellshock
    shellshock Guy who drives a lot
    Iowa
    2019 TRD PRO
    It’s not all that surprising when you are towing up the mountains. That’ll suck fuel in a hurry
    AZBoatHauler likes this.
  8. Mar 1, 2020 at 8:34 PM
    DCB500
    DCB500 New Member
    David
    Oklahoma City
    2019 Tundra SR5 TSS Double Cab
    Wheels, sound system, antenna, tailgate letter inserts, Grill/Hood Bulge, Exhaust, Leather
    About 11 when towing our boat, probably around 3500 lbs.
  9. Mar 1, 2020 at 8:47 PM
    KMG
    KMG New Member
    Kevin
    Yacolt, WA
    6,000 loaded w/o holding tanks filled (1,100 pin weight). It's the aerodynamics not weight that drags my mileage down. That plus I'd rather buy fuel than drive slower.
    TTund16[QUOTED] likes this.
  10. Mar 2, 2020 at 3:25 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I towed boat from LaFayette to Dallas all interstate at 70 to 75 mph with Tacoma. Filled up 3 times. 6 hour trip. I bought a Tundra mainly because some lakes I go to would probably require a gas station stop with Tacoma. 21 gallon tank does not last long at 10 mpg. MPGs towing are same with both trucks.
    Bigboitundra likes this.
  11. Mar 2, 2020 at 3:59 AM
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    12.1 towing a bassboat from Dallas to Houston and back. Had cruise control set at 75 for most of the trip. Was surprised that I lost about a mpg when I left the shallow water anchors (Talons) in the upright position versus tiled down on the deck of the boat...wind resistance is the killer.
  12. Mar 2, 2020 at 2:49 PM
    sprede
    sprede New Member
    Wow. Thank you all for your input. It has scared me on the MPG but also helped me make my decision to go with the Tundra. I think in the long run (if reputation holds up) it will last me longer and hold the value better.
  13. Mar 30, 2020 at 9:48 AM
    lonelydriver
    lonelydriver New Member
    lesson learned, slow down for better mpg
    ezdog likes this.
  14. Mar 30, 2020 at 10:09 AM
    ezdog
    ezdog New Member
    Gateway To The West
    This is the key I have found!
    I drove a brand new Sequoia 1500 miles before XMas pulling a dinky U-Haul from the Midwest to Montana and was astonished by the depth of crappy mileage that it could deliver.
    It turned out that if I went 75-85 just to keep up with the other traffic that I was averaging around 8 mpg but if I slowed it down to 65 I could get close to 15 mpg pretty often!
    Trouble was the constant getting honked at and almost blown off the road in Wyoming and Montana by everyone else!
    That trip was an education for sure but I still wonder exactly what I learned too?
    On the way home in a rented Grand Caravan loaded to the hilt I was seeing 23 or so the whole way home on XMas eve.
    Those Stow and Go seats are pretty amazing for sure!
  15. Mar 30, 2020 at 10:10 AM
    07KingTundra
    07KingTundra New Member
    Scott
    07 Tundra Limited
    King, Icon, General
    i just towed a travel trailer that is 23' fully loaded with water, supplies, dogs, and about 1/2 bed of firewood, tools, etc. I towed from Flagstaff to Phoenix (basically all down hill) and got 9.5mpg. On the way back to Flagstaff (all uphill) I got 8 mpg with no water and not as much food but pretty much everything I took. Not too good but not horrible. I also stayed right at about 60-65mph.
  16. Feb 11, 2021 at 4:27 PM
    Steplift20
    Steplift20 New Member
    2018 Tundra
    Towing my boat ,it's a 20,6 wellcraft total weight about 3200 lbs I was getting about 10 mpg the tundra pulled with no problems and there were hills ,not all flat roads but mostly flat , nj parkway and going up my street very steep hill but what ever you do don't get a ford 2500 or 3500 Death wobble steering check it out online Tundra is what you want for towing gas mileage with the summer blend gas I get about 20 mpg if your from nj than you will know what I am talking about winter blend summer bend
  17. Feb 11, 2021 at 9:44 PM
    usaf.2012
    usaf.2012 New Member
    AK
    2010 Black CM Tundra RW
    10" BAMuffler // Bilstein 5100s all around & front on Mid setting // Toytec shackles // BHLM
    :monocle: Dude throwing a "." in here and there will go a long way in making your post make a little more coherent.
  18. Feb 12, 2021 at 4:49 AM
    Steplift20
    2018 Tundra
  19. Feb 12, 2021 at 4:50 AM
    #49
    Steplift20
    2018 Tundra
    Dude, what are you talking about?
  20. Feb 12, 2021 at 4:51 AM
    #50
    Steplift20
    2018 Tundra
    Anyone ever tow a boat without putting it in tow mode? What would happen?
  21. Feb 12, 2021 at 6:26 AM
    #51
    Maxtor
    Maxtor New Member
    Mark
    It doesn't seem to matter how much weight I pull, 8.5-10 is where it likes to run when you hook something to the hitch. I pulled 8-9k lbs in a 20' cargo trailer 700 miles including driving through the smoky mountains, averaged 9 for the trip running 70mph. Pulled a single axle open trailer totaling probably 2k lbs the same path and got 10...
    A larger fuel tank becomes your best friend especially when towing with a Tundra, why I installed the TF 47. Having to start looking for a gas station every 150 or so miles sucks.
  22. Feb 12, 2021 at 6:47 AM
    #52
    Skierdad
    Skierdad New Member
    Skierdad
    2019 Tundra from 2010 Tundra
    Pulling 20' Yamaha jetboat 60-70 mph= 10-11 mpg
    Pulling motorcycle trailer 60-70 mph= 11-12 mpg
    Pulling 16' Vnose enclosed trailer 60-70 mph= 10-12 mpg
    I guess I should have just put 10-12 mpg pulling just about anything. lol
  23. Feb 12, 2021 at 7:01 AM
    #53
    Steplift20
    2018 Tundra
    What is a tf47 ?
  24. Feb 12, 2021 at 7:08 AM
    #54
    Lake.Life24
    Lake.Life24 New Member
    Shawn
    Upstate, NY
    2021 GMC Sierra 3500HD Gasser
    Transferflow 47 gallon aftermarket gas tank. A common upgrade for people that tow or go overlanding a lot.
  25. Feb 12, 2021 at 8:08 AM
    #55
    AZBoatHauler
    So.Arizona
    You have to press the accelerator down farther and it shifts more often - not holding gears as long. I don’t recommend it.
  26. Feb 12, 2021 at 9:05 AM
    #56
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    If you want good gas mileage when towing then get a 3/4 ton with a diesel. And new kidneys.
  27. Feb 12, 2021 at 9:51 AM
    #57
    Steplift20
    2018 Tundra
    What is a tf47 ?
  28. Feb 12, 2021 at 9:55 AM
    #58
    Steplift20
    2018 Tundra
    What is a tf47 ?i ok thanks I didn't and never heard of that, but I can't say that anymore. I get about 10 mpg towing my boat and I see that is normal. I had a 1994 Chevy p/u with a 5/0 engine and got about the same maybe even a little better, it was a stick shift but the clutch master cylinder kept failing so I had to junk it. It was a very nice truck but my tundra is better for sure. Very dependable.
  29. Feb 14, 2021 at 7:05 PM
    #59
    The Dude
    The Dude New Member
    Chandler, AZ, not anymore :(
    7-9 mpg, towing 8000lbs
  30. Feb 14, 2021 at 7:11 PM
    #60
    Nomoredomestics
    Nomoredomestics New Member
    GA
    2023 TRD Sport 4x4
    About 12 pulling my 21" bay boat. 62, 63 mph in s4. Boat weighs somewhere between 4,000 and 4,500 as she sits.
