Gas filling problem
Discussion in '2.5 Gen Tundras (2014-2021)' started by KiltedWolf1, Jan 21, 2019.
  1. Jan 21, 2019 at 8:06 AM
    KiltedWolf1
    KiltedWolf1 [OP] New Member
    ‘16 Platinum Crewmax White
    Good morning all,
    I have this problem, started yesterday. While trying to fill up before I drive 225 home. Can’t fill up, and went to 3 different stations. I finally jammed it in and held it tight and it worked for a few seconds and then gas poured back out. Can’t see any blockage. I saw another post but it was May 2018 and not sure I’ll get a response. Have a 2016 Platinum, scheduled service tomorrow since no appointments open today and missing 2 days of work. But since I see others have had this happen, looking for an answer or what your outcome was. Thanks for any help.
  2. Jan 21, 2019 at 8:16 AM
    15whtrd
    15whtrd Mr. Blonde
    Maybe the vent tube is kinked? Will it fill if you pull the handle on the gas nozzle partially?
  3. Jan 21, 2019 at 8:19 AM
    KiltedWolf1
    Checked the vent tube, filler tube this morning, both look okay and no matter how little or tightly I pull he handle it shuts off in 1-2 seconds. Thanks.
    15whtrd likes this.
  4. Jan 21, 2019 at 8:24 AM
    15whtrd
    15whtrd Mr. Blonde
    Sounds like you’ll just have to let the dealer sort it out.
    IsaiahCanada and NewImprovedRon like this.
  5. Jan 21, 2019 at 8:27 AM
    KiltedWolf1
    Exactly what I’m thinking. I’ll wait and see if the other poster from last year responds, I’ll update once it’s handled. Thanks brother, appreciate the response.
    15whtrd likes this.
  6. Aug 9, 2019 at 6:58 PM
    Breakaway11
    Breakaway11 New Member
    2016 Tundra Platinum
    3M & Bakflip HD
    Having the same issue with my 2016 platinum. Dealership diagnosed to replace charcoal filter for evap system. Beyond warranty (of course). They told me $1600 and they would pay half. Got the truck back couple days ago and went straight to the gas station. Same problem. WTF. Bringing it back to dealer next week. Any updates from you?
  7. Aug 9, 2019 at 7:07 PM
    Geezer
    Geezer New Member
    Heart of the Catskills
    2019 Tundra Limited
    There was a similar thread a while back on this forum or another Tundra forum I read. In that case it turned out that there is an anti-backflow valve (some sort of flapper I think) in the gas tank and it was stuck. The bottom line is that the gas tank had to be replaced.
    15whtrd and NewImprovedRon like this.
  8. Aug 9, 2019 at 7:16 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
  9. Aug 9, 2019 at 7:27 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    My '16 developed this problem as did @TRON. The problem both of us had was a stuck roll over/ inertia valve. My local dealer quoted me $1,200 for a new tank and said it isn't a repairable item. I hate my local dealer, but that's another story. Honestly it should fall under warranty. My solution was to drop the tank and poke the valve with a screw driver. It worked and opened the valve. But, I didn't wanna have the issue again so I "reworked" the valve into a non-operational status.
  10. Aug 10, 2019 at 12:27 AM
    TTund16
    TTund16 New Member
    How many gallons of gas short of full when you had this problem?
  11. Aug 10, 2019 at 4:29 AM
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
    The vent may be kinked or blocked. If you know someone with a scope look down the fill tube. All the best..
    Black Wolf, 831Tun and NewImprovedRon like this.
  12. Aug 10, 2019 at 5:36 AM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    Sounds like a classic backflow/rollover valve issue.
    SAGE63 likes this.
  13. Aug 10, 2019 at 7:15 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I had roughly half a tank when I discovered the valve was stuck in the closed position.
    GodlessPro and joonbug like this.
  14. Aug 10, 2019 at 7:18 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    One more reason for me to HATE my local dealer. $200 to stick that scope down there and tell me they couldn't see anything, it was too short and, because I've modified my truck, no warranty.
  15. Aug 10, 2019 at 7:42 AM
    timsp8
    NY
    What modifications do you have? Thee is a law that puts the burden of proof on them to prove your mods caused the issue. So if you have new suspension, they can’t deny a claim on the gas tank.
    GODZILLA and 831Tun like this.
  16. Aug 10, 2019 at 7:53 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I'm familiar with Magnuson Moss but they can, and do, make it such a PITA that it's not worth it to me to fight 'em and have the truck down for an extended period. Couple hours work and I'll never have the problem again.
    joonbug and 15whtrd like this.
  17. Aug 10, 2019 at 8:12 AM
    15whtrd
    15whtrd Mr. Blonde
    So now that you’ve worked on it and figured out the problem, do you think it would be possible to fix that issue with a longer borescope? Maybe not having to remove the tank? Maybe be able to jab that flap open with the end of the scope. Just curious
    831Tun[QUOTED] likes this.
  18. Aug 10, 2019 at 8:28 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Possible? Yes. But it would require a great deal of luck too. There are a lot of bends to negotiate and a bulls eye anti siphon ring just above the valve. A common #2 flat screwdriver wont fit past the bulls eye, so it's got to be something very small that will pass through all the required bends w/o snagging, needs to be greater than 3' in length, fit through the bulls eye and yet be rigid enough to pop open the valve. I also tried compressed air w/o success.
  19. Aug 10, 2019 at 11:32 PM
    TTund16
    TTund16 New Member
    I didn't ask my question Correctly.
    was wondering for example if you have a 38 gallon tank with this problem then how much has can you put in there? 30 gal?
    Thanks
  20. Aug 11, 2019 at 12:39 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Yeah, I have the 38. I was able to fill it, a teaspoon at a time. From 1/4 tank to full took roughly half an hour. Luckily, coming home from T2S in Sedona, all the Bastrds would help out, taking turns pumping the gas. All the guys now, if they didn't already, sport a kung fu grip. LOL
    I ran the tank down to about 3 gal. before dropping it to repair.
  21. Aug 11, 2019 at 9:39 PM
    TTund16
    TTund16 New Member
    Is this problem covered under 3 years or 5 years warranty? Since its not a powertrain, I'm thinking maybe 3?
  22. Aug 11, 2019 at 9:53 PM
    Sunnier
    Sunny
    San Diego, CA
    I don’t know if anyone getting a standard Toyota warrantee with 3 years. Mine was 2 on anything other than drivetrain.
    831Tun and TTund16[QUOTED] like this.
  23. Aug 12, 2019 at 5:50 AM
    sstoddard
    sstoddard New Member
    Shawn
    2019 Crewmax Sport
    Alarm/start (Compustar Ft7000,Rf2wl1b 2-way remotes and Drone Mobile) Tailgate inserts NSV Lightbar Tailgate actuator Blacked out decals
    Warranty is 3 years 36000 miles. Toyota care is 2 years 25000 miles.
    TTund16 likes this.
  24. Aug 12, 2019 at 6:06 AM
    ou77kg
    ou77kg New Member
    Erik
    2016 Tundra CM Platinum 4x4
    What mileage did this occur to y’all at?
  25. Aug 12, 2019 at 6:19 AM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    it's been 8 months, has this issue not been handled yet?
  26. Dec 15, 2021 at 3:23 PM
    2016tundrathunda
    2016tundrathunda New Member
    Came here to say I had this issue. 87k miles. Rode it out for a month with 30 min gas fills. Problem has since gone away. So maybe try riding it out for a bit before biting the bullet
    evanhauer likes this.
  27. Dec 15, 2021 at 3:25 PM
    Old ass thread but I think it has something to do with an anti-rollover valve or something to that effect.
    Spyker likes this.
  28. Dec 15, 2021 at 3:42 PM
    Spyker
    Spyker I’m a dude,playin a dude,disguised as another dude
    what he said ^
  29. Dec 16, 2021 at 10:25 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    check this
    https://www.tundras.com/threads/gas...stuck-causes-hard-fuelling-anyone-else.42535/
  30. Dec 18, 2021 at 8:08 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    I've had this before and the fix was replacing the evaporative emissions charcoal cannister and purge valve. Was told that topping tank to the very top after the gas pump shuts off causes fuel to get into the cannister which eventually deteriorates it.
    Black Wolf and 831Tun like this.
