Gardens? Anyone got them?
Discussion in 'Sports, Hobbies & Interests' started by TokerJoker, Mar 26, 2019.
  1. Jul 10, 2019 at 7:28 PM
    #151
    Here's what controller I use.IMG_20190710_213029.jpgI drive 4 steel T post with insulators on the corners then use fiberglass poles in-between to support the cable. I use the poly stranded cable so I can roll it up after harvest so it can be reused. I set the Cable at 6" off the ground then around 12" then 24" 36" and around 48" this takes care of the coon and deer. Since I have been doing this nothing gets in.:D
    Here is what I use.
    TokerJoker[OP] and SOB[QUOTED] like this.
  2. Jul 10, 2019 at 7:30 PM
    #152
    Double post.
  3. Jul 11, 2019 at 4:05 AM
    #153
    SOB
    SOB Big Member
    Ohio
    2013 Red Crew Max Platinum
    Thanks for posting the info! How hard is it to setup/take down? Reason being - If I keep mine up all year I'll need to open up sections to get into the garden almost daily and then open up larger sections for tilling.
    TokerJoker[OP] and Prostar 190 like this.
  4. Jul 11, 2019 at 4:26 AM
    #154
    It's not to bad I use either the 3 point on my tractor or the front end loader to pull the T post because they can be a little rough to pull. You can also buy stuff that will let you make openings easily. they make insulators with hooks that you can just hook to the t-post to remove the wire so you can have an opening to get in.
  5. Jul 14, 2019 at 5:58 AM
    #155
    SOB
    SOB Big Member
    Ohio
    The garlic harvest was decent this year. Our wet spring rotted a few heads in the ground but it wasn’t as bad as I thought it would be.
  6. Jul 14, 2019 at 12:37 PM
    #156
    TokerJoker
    TokerJoker [OP] ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
    Hate when critters of all types plague our efforts!!
    Pudge[QUOTED] likes this.
  7. Jul 14, 2019 at 12:37 PM
    #157
    TokerJoker
    Travis
    Nowhere, Specific
    None.....yet
    Sweet spread:thumbsup:
  8. Jul 14, 2019 at 12:40 PM
    #158
    TokerJoker
    Travis
    Nowhere, Specific
    None.....yet
    We may be trying garlic next year. Good looking harvest:thumbsup:
  9. Jul 20, 2019 at 5:02 PM
    #159
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Time to make a BLT.
    TokerJoker[OP], Pudge and Prostar 190 like this.
  10. Jul 20, 2019 at 5:46 PM
    #160
    Rex Kramer
    Georgia
  11. Jul 20, 2019 at 7:34 PM
    #161
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Beautiful tomatoes! I have some green ones. Not ready but I'm keeping an eye on them. Cant wait
  12. Jul 21, 2019 at 7:01 AM
    #162
    TokerJoker
    Travis
    Nowhere, Specific
    None.....yet
    Looking good @Rex Kramer, salads are a must this time of year! Have had about 4-5 per week so far.
    Rex Kramer likes this.
  13. Jul 31, 2019 at 6:48 PM
    #163
    Well picked and snapped around 5 gallons of green beans tonight. And picked some bell peppers.IMG_20190731_213720.jpg IMG_20190731_214108.jpg
  14. Jul 31, 2019 at 6:53 PM
    #164
    Pudge
    CT
    I had a micro burst storm come thru today and do some damage to a few plants. Ripped some branches off my tomato plants and nearly uprooted my zucchini. I did pick 3 or 4 cucumbers, 2 jalapeno, and a handful of cherry tomatoes today though
  15. Jul 31, 2019 at 8:10 PM
    #165
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Anybody know about roses? I'm trying to save mine. I just bought this house and I'm not good with plants. Along the side of my house there are about 8 tall, mature rose bushes in a row. Need some advice.
    I've noticed:
    Two on one end seemed most affected at first, getting holes in leaves and Rose's quickly wilting, within the same day as they open.
    After a week they were all affected, the smaller ones more than the larger.
    I've inspected them closely and found a number of critters in there. Some look like aphids, but not in big numbers and they're hard to find. Some look similar to beetles, very small and hanging out in the rose buds, picture below. Some look like ladybugs but small and black. I know I had a snail problem because there was a colony of them in nearby ferns, I ripped all those ferns out 3 weeks ago and haven't seen a snail trail since.
    Also noted on two bushes there has been some white fungus under the buds, usually just an inch or so down the stalk.
    It has been 90 degrees and up lately so I'm afraid to use any pesticides, all the ones I looked at say not to use in hot weather.
    The lil bastards look like this
    While I'm in here, anybody know what the hell this is? I ripped out a lot of ivy and this shark egg looking shit is everywhere.
    TokerJoker[OP] likes this.
  16. Jul 31, 2019 at 8:35 PM
    #166
    Pudge
    CT
    I use Bayer spray and also pellets on my roses. The pellets also have fertilizer in them. The spray is nice to use because it works right away, the pellets have to be watered in and eventually offer systemic protection against bugs and fungus. They also make a concentrated solution you dilute and water in instead of the pellets/granules, I used that too with good luck, I got a deal on the granules this time so I got those instead. I have had better luck with bayer than any other brand
    https://www.walmart.com/ip/Bayer-2-...mTPY9hYxaABIuN1VsADkE9dc4UdIMxGhoCLaIQAvD_BwE
    https://www.walmart.com/ip/Bayer-Ad...nd-Flower-Insect-Killer-Ready-To-Use/16778339
    That root almost looks like a bunch of acorns started sprouting roots. I have no clue what it could be otherwise.
  17. Jul 31, 2019 at 9:16 PM
    #167
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    You can buy a tub of 1,000 ladybugs at most nursery’s, they’ll eat the shit outta aphids and cure that problem. You’ll wanna mist em daily to provide water so they stick around. May want multiple tubs of them...
    TokerJoker[OP] and Pudge like this.
  18. Jul 31, 2019 at 9:48 PM
    #168
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Thanks @Pudge I'll try that stuff out. Pellets are probably better in this weather than the tropical solutions I kept looking at.
    @Jrharvey02 I've read about people getting lady bugs but they don't seem to stay around. If they're as cheap as crickets maybe I'll try, thanks.
    TokerJoker[OP] and Jrharvey02 like this.
  19. Aug 1, 2019 at 8:11 AM
    #169
    Jrharvey02
    If you mist them everyday with water they’ll stick around. Bugs just need food and water, aphids will supply food, you supply them water and problem solved. I had a huge infestation of aphids in a giant bush last year. Bought a few thousand lady bugs and a couple months later, aphids are gone. I still have a ton of ladybugs hanging around my garden too. It’s like $10 for 1000 of em, they’ll control tons of pests.
  20. Aug 5, 2019 at 11:41 AM
    #170
    Rex Kramer
    Georgia
    Cardinals were ripping me off, so I responded with bird netting.
    Now I have Blueberries... the cat happens to ignore birds, but he likes Chipmunks.
    Prostar 190 and TokerJoker[OP] like this.
  21. Aug 5, 2019 at 5:38 PM
    #171
    Fishman57
    Fishman57 New Member
    Wayne
    Bucks County, PA
    Anybody know any good ways to keep ground hogs out of my garden? The bastards keep eating the blooms off of our bean plants. :mad:
  22. Aug 5, 2019 at 5:51 PM
    #172
    :infantry:
  23. Aug 5, 2019 at 5:52 PM
    #173
    I canned 18 more pints of and 10 quarts of green beans tonight.
  24. Aug 6, 2019 at 4:00 AM
    #174
    SOB
    SOB Big Member
    Ohio
    The blueberries look great and the bird netting is a must! The one downfall to netting is that IF birds do get in they typically can't get out. I found a dead mourning dove wrapped up in my netting the other day.
  25. Aug 6, 2019 at 4:06 AM
    #175
    SOB
    SOB Big Member
    Ohio
    After letting the onions dry in the garden for a few days I had to get them under cover since rain was moving in. They'll sit here for about a week to let the tops dry up. They a couple more weeks once the tops are removed. I then store them in mesh bags in the basement. Should last us all year! They are a little on the small side this year but I was happy given the rain and flooding the garden has dealt with this year.
    sask3m, MS22, deepblu89 and 3 others like this.
  26. Aug 6, 2019 at 4:08 AM
    #176
    poheller
    poheller 2018 Platinum
    Scot
    The great state Ohio
    2018 platinum
    Looks great love onions..
  27. Aug 6, 2019 at 4:49 AM
    #177
    8MINT8
    8MINT8 #NotBetty
    Lost
    2018 Unicorn TRD
    1/2 in. chicken wire and line bottom and sides.
  28. Aug 6, 2019 at 6:13 AM
    #178
    Rex Kramer
    Georgia
    Netting is a death trap for many things.
    I draped it over the bushes like an umbrella - the bottom is wide open for easy escape.
  29. Aug 6, 2019 at 6:27 AM
    #179
    Fishman57
    Wayne
    Bucks County, PA
    I tried that. They just dig under it.
    TokerJoker[OP] and Rex Kramer like this.
  30. Aug 6, 2019 at 6:55 AM
    #180
    Rex Kramer
    Georgia
    Lay a section of chicken wire flat on the ground in front of, and flush against the upright wire you have.
    They usually give up trying to dig down through the wire.
