Garage solutions (when Tundra won't fit)
Discussion in '2.5 Gen Tundras (2014-2021)' started by TundraLuv, Jul 6, 2018.
  1. Jul 11, 2018 at 11:06 AM
    #151
    Nike21
    Nike21 New Member
    2018 SR5 CrewMax TSS 4X4 Black Beast
    I knew my Tundra was either gonna be a few inches too big, or a few inches just right. So happy that it was just right!! :thumbsup::bananadance::bananadance::cheers:
  2. Jul 11, 2018 at 11:40 AM
    #152
    Ike74
    Ike74 New Member
    Anthony
    Sugar Land, TX
    2020 Kia Forte
    I'm still thinking the best option would be a flush mount rear bumper. It would look nice and give a few inches in clearance
  3. Jul 11, 2018 at 12:42 PM
    #153
    daylorb
    daylorb New Member
    Austin, TX
    2016 Limited 4X4
    Go Pack!
    Sawsall...
    Seriously though, the sheetrock is way easier to deal with. You should have enough room with that. I put one of these on my floor then: https://www.amazon.com/Guardian-Ind...=UTF8&qid=1531338071&sr=8-7&keywords=car+stop
    I drilled out the floor and mounted it permanently so I could not do further damage to the car or the wall. Works perfectly.
  4. Jul 11, 2018 at 3:10 PM
    #154
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Holy shit Gino that is freaking awesome. My truck told me to say hi to Gino. And that it's sick of parking outside in the heat. And if you can lend it 24k?
    GNTundra and Pudge like this.
  5. Jul 11, 2018 at 3:13 PM
    #155
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Altering the garage door or front of the garage won't go too well with the HOA. You already put a hole in the back wall, just cut it out now and put up new sheet rock a few inches deeper.
  6. Jul 13, 2018 at 3:58 AM
    #156
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    Some might also not like truck parked outside, why I live in the country. Gonna build a 40x44 metal building for Tundra and camper to move into.
    joonbug[QUOTED] likes this.
  7. Jul 13, 2018 at 5:38 AM
    #157
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    It depends on the HOA bylaws and the current board members' attitude. In my neighborhood they used to be very strict, but then after the economy downturn they got three different builders in there to finish the open lots and everyone brought their own plans, so the houses are not so much cookie-cutter anymore. That opened it up for modifications, as long as it still matches the general feel of the neighborhood.
    If you build the front wall out a couple feet but keep the same type of stucco/siding/paint as the rest of the house, it might be doable.
    It will be more expensive than the drywall idea though.
  8. Jul 13, 2018 at 9:24 AM
    #158
    TundraLuv
    TundraLuv [OP] New Member
    Kent
    IA
    2018 Midnight Black Metallic Limited Crewmax
    I've cut open the wall a bit. I'm not sure if the baseboard shown at the bottom will be tough to cut out but I need to buy a sawzall this weekend and anything else I might need. I plan to order one of those backup stops that somebody recommended from Amazon to keep from running into the kitchen with my truck. For clarification, I am not 100% sure it was load bearing. I don't pretend to be the most inclined for DIY projects so this might take longer than most people who are familiar with it. Any recommendations on sawzalls or anything else that might make the job easier?
  9. Jul 13, 2018 at 9:27 AM
    #159
    The painters tape not being straight is driving my OCD nuts.
  10. Jul 13, 2018 at 9:28 AM
    #160
    TundraLuv
    Kent
    IA
    Yeah, I saw that after I took the picture. It's hot today and was just trying to establish an area to cut out.
    T-Rex266[QUOTED] likes this.
  11. Jul 13, 2018 at 9:29 AM
    #161
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    2017 White DC TRD PRO
    Cut out the whole piece of drywall you taped off. I would like to see what all is going on there. Measure how high your bumper comes up as well. I wouldn’t cut more than I have to.
  12. Jul 13, 2018 at 9:29 AM
    #162
    Until you get the bump, just get a tennis ball and string for the time being.
    Silv333, aRabidLunatic and JH5370 like this.
  13. Jul 13, 2018 at 9:33 AM
    #163
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    I would be very careful with a sawzall so not to cut through the other side into the kitchen. I would use a skilsaw or something with a depth stop to cut the studs. An oscillating multi tool is also invaluable when flush cutting anything.
    mdavis likes this.
  14. Jul 13, 2018 at 10:16 AM
    #164
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Is that tape placed where the bumper will go?
    If so I see a few problems if you plan to cut anything more than the sheetrock.
    1. there's power running up or down a stud in that wall, DO NOT get close with a sawzall. Cut away all drywall first.
    2. That baseboard, as you called it, is the rim joist / sill plate, and likely floor joists. I assume you go up some steps into your house? You can not cut any of that out. You can only cut the 2x4/6 wall studs and you'll need to put in a header over them with some jack studs because that is very likely load bearing. And that's figuring somehow you work your way around the wiring for that outlet.
    3. From these pics, you really can't gain much here if you need to remove the entire area inside the tape, other than the thickness of the drywall that is.
    I hate to say it but it looks like you need plan C. Check with HOA on extending garage forward a bit. Or get some kind of flush mount garage door that installs as close to the face of the house as possible.
    Or plan D and get a rear bumper that tucks in really close, or plan E.... park outside. Which I know sucks.
    JH5370 likes this.
  15. Jul 13, 2018 at 10:29 AM
    #165
    TundraLuv
    Kent
    IA
    Ugh, cutting the drywall is out I guess. Back to the drawing board I guess.
    Order of cost:
    1. Plan E, park outside (free) (least desirable in the midwest winters)
    2. Plan D $1600 (flush mount bumper)
    3. Plan C $XXX (very expensive?) extending garage forward a bit. 3. Plan C(b) $XXX ( less expensive than extending garage door?) Flush mount garage door.
  16. Jul 13, 2018 at 10:29 AM
    #166
    TXDrifter
    TXDrifter BlueGrass Crew
    Jeff
    Louisville, KY
    2017 Tundra MGM DC
    Relocate your L.P. to above your bumper or get one of those L.P. holders that you unpin and remove like in the car shows?
  17. Jul 13, 2018 at 10:31 AM
    #167
    TXDrifter
    Jeff
    Louisville, KY
    2017 Tundra MGM DC
    Get a remote start and have your truck nice and toasty when you get in?
  18. Jul 13, 2018 at 10:46 AM
    #168
    TundraLuv
    Kent
    IA
  19. Jul 13, 2018 at 11:09 AM
    #169
    aRabidLunatic
    aRabidLunatic Professional Hobo
    Central Texas
    2015 Tundra SR5 Black
    Harbor freights
  20. Jul 13, 2018 at 11:11 AM
    #170
    aRabidLunatic
    Central Texas
    Or a 2x4
  21. Jul 13, 2018 at 5:34 PM
    #171
    sprtbkr
    sprtbkr Average Member
    Scott
    Denver, CO
    2018 Tundra SR5 4x4 Double Cab - Inferno
    TRD Wheels & Tires, Double Cab Fold-down Back Seat mod, LED Interior Lighting, Turned Off Seat Belt Chime, Franken-key (Flip Key), Duraliner Bed Liner, Bed Rails, Hood Wind Deflector, Console Gun Safe, iBoard 5" Running Boards, TRD Sport Bed Vinyl, Fortin Evo One Remote Start with Mycar Cellular Module, Plasti-dipped Badges and Bumper End Caps, Tinted front windows, Extang Solid Fold 2.0, Pop-N-Lock, TUNDRA tailgate inserts, RCI Powder Coated Skid Plate - coming soon - 12” android radio, oemaudio+ Reference 500Q, under dash/seat lighting.
  22. Jul 13, 2018 at 5:49 PM
    #172
    TundraLuv
    Kent
    IA
    Have a suggestion? That's what I could find on Amazon.
  23. Jul 13, 2018 at 7:30 PM
    #173
    lionix
    lionix The Grey Moose!
    Cape May, New Jersey
    2017 Tundra TRD Pro CM Cement
    BD Lights, Any Time Fog, Coachbuilder, Pelfreybilt, Bakflip, Custom Bed Rack w/ Tent
    You fixed your half inch problem with your hitch. Whats there to fix?
  24. Jul 13, 2018 at 9:13 PM
    #174
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    With the bumper keep in mind that your hitch is also bolted to the frame of your truck and sticks out further than anything else. You will need to find a bumper that replaces your hitch too.
  25. Jul 14, 2018 at 12:23 AM
    #175
    TundraLuv
    Kent
    IA
    The truck has a tow package. Easy way to move the hitch receiver back?
  26. Jul 14, 2018 at 4:53 AM
    #176
    1BadTundra
    1BadTundra New Member
    Clinton
    2010 TRD Rock Warrior Crewmax
    Too Much to List
    I HAD this problem... had to pull the mirrors in, then move a ton of shit just to get the doors to close. I got the green light to build this back in April. 24x36, 3 9x10 doors. I'm just finishing the electrical work (100a sub-service), HVAC is next. I don't mean to gloat, but I waited patiently for 14 years for this. We just got the asphalt done 2 days ago.
  27. Jul 14, 2018 at 5:00 AM
    #177
    Trooper2
    JR
    Houston, TX (Suburban South)
    So Jealous! Looks like LED interior lighting which is nice too!
    1BadTundra likes this.
  28. Jul 14, 2018 at 5:56 AM
    #178
    1BadTundra
    Clinton
    Too Much to List
    It is... 32 4' fixtures. 5000k I bought a bulk deal, they weren't bad. I love these things.
    Trooper2[QUOTED] likes this.
  29. Jul 14, 2018 at 7:20 AM
    #179
    Professional Hand Model
    Hand Protectors
  30. Jul 14, 2018 at 7:21 AM
    #180
    Hand Protectors
