Garage solutions (when Tundra won't fit)
Discussion in '2.5 Gen Tundras (2014-2021)' started by TundraLuv, Jul 6, 2018.
  1. Jul 9, 2018 at 2:26 PM
    #121
    ardnutoz
    ardnutoz
    OZ
    SE-PA
    2018 Black TRD OR CM Limited
    there goes that idea :frusty:
    1UPPER likes this.
  2. Jul 9, 2018 at 5:55 PM
    #122
    TundraLuv
    TundraLuv [OP] New Member
    Kent
    IA
    2018 Midnight Black Metallic Limited Crewmax
    Maybe Roman has one
  3. Jul 9, 2018 at 5:56 PM
    #123
    TundraLuv
    Kent
    IA
    Can't quit now. Will keep trying
    T-Rex266 and ColoradoTJ[QUOTED] like this.
  4. Jul 9, 2018 at 6:21 PM
    #124
    I’m hoping moving the header out flush with the bricks works for you.
    Feel your pain. We had a house we really liked and wanted to purchase, but the garage was not going to work. We finally had our Realtor call ahead and ensure a home we would look at was a minimum of 23’ deep and 24’ width without the third bay.
  5. Jul 9, 2018 at 6:30 PM
    #125
    NCinCO
    NCinCO Is it Friday yet?
    Gary
    Thornton, CO
    2018 Smoked Mesquite Limited CM TRD
    Maybe a last resort but it would work as long as you have the door width. Take down the garage door and install a barn style door. If you want it to open on a remote system that can be added. The hindges would mount on the outside of the door frame. Either style in the pics would work.
    Mountun Goat, 4x4_Angel and GNTundra like this.
  6. Jul 9, 2018 at 7:11 PM
    #126
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Has someone said automatic exterior roll up doors?
    ColoradoTJ likes this.
  7. Jul 9, 2018 at 8:05 PM
    #127
    My shed has that style door, except the roll is inside. Works well.
    NCinCO likes this.
  8. Jul 9, 2018 at 8:43 PM
    #128
    What did that run you? Asking for a friend.
    PM me if you want.
    GNTundra and 4x4_Angel like this.
  9. Jul 9, 2018 at 8:50 PM
    #129
    Damn!!! Right in my price range! Gracias Amigo. The GN looks lonely all by itself, needs company!
    4x4_Angel, GNTundra and Pudge like this.
  10. Jul 9, 2018 at 9:25 PM
    #130
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    I vote shorter rear bumper or roll pan- do they even make these anymore haha
    Or
    The outside hanging slide barn doors would be your cheapest shop mod imo. These would work great and sliding door hardware isn’t too expensive. Can just build wooden doors and paint to suit.
    4x4_Angel likes this.
  11. Jul 9, 2018 at 9:58 PM
    #131
    Aron9000
    Aron9000 New Member
    Aaron
    The 2007-2013 trucks had some sort of sport package option that gave you a flusher mounted rear bumper. It was painted the same color as the rest of the truck, along with every single piece of trim that was normally chrome. Personally I didn't like the look, it was very easy to damage as well.
  12. Jul 9, 2018 at 10:19 PM
    #132
    aRabidLunatic
    aRabidLunatic Professional Hobo
    Central Texas
    2015 Tundra SR5 Black
    How about making a pocket where the bumper would go in the wall? You would need a beam to support the 2x4s already in the wall. Would need to check with a carpenter if it would work. In my mind it does. That would give you a couple of inches.
    TundraLuv[QUOTED][OP] likes this.
  13. Jul 9, 2018 at 10:31 PM
    #133
    aRabidLunatic
    Central Texas
    Just saw your quote. Same idea I had
  14. Jul 10, 2018 at 3:54 AM
    #134
    Professional Hand Model
    Hand Protectors
    Lots of Holiday Inn sleepers around here. Denial isn’t just a river in Egypt.
    1UPPER likes this.
  15. Jul 10, 2018 at 8:01 AM
    #135
    RickC
    RickC NOT a new member
    Rick
    Knoxville TN
    2017 CrewMax Platinum 4x4 5.7
    SCS Wheels, Line-X, WeatherTech, UnderCover Flex bed cover
    That's not bad at all!
  16. Jul 10, 2018 at 8:06 AM
    #136
    RickC
    Rick
    Knoxville TN
    I have been looking at this pic closer and I think I see the impression on the floor where the door actually hits. It looks like it clears. If you move the truck out of the way and close the door and take a pencil and mark where the door hits the concrete, then back the truck back in and take a plumb bob and check for clearance. You can make a plumb bob using a piece of string and anything with weight and a point.
    Use this to see exactly where the front of the truck meets the door (not the track that we've been looking at to judge). Also, check that there is no hinge or door handle on the garage door that can scrape the truck bumper/license plate.
    This is a plumb bob, btw: https://www.homedepot.com/p/Johnson-8-oz-Steel-Plumb-Bob-08/100184170?cm_mmc=Shopping|G|Base|D25T|25-1_HAND+TOOLS|NA|PLA|71700000034127224|58700003933021546|92700031755124826&gclid=CjwKCAjwspHaBRBFEiwA0eM3kfRZ4bu_yso0LrAw3FdThS7gQcBXRRJMfQ3u0D-qhqF1xvNqN9HYZBoCdzwQAvD_BwE&dclid=CPGj06_nlNwCFZnG4wcdthoKsw
    TundraLuv[OP] likes this.
  17. Jul 10, 2018 at 9:59 AM
    #137
    daylorb
    daylorb New Member
    Austin, TX
    2016 Limited 4X4
    Go Pack!
    I had a similar issue - I removed the reinforcement struts. You could potentially remove the lower reinforcement struts on the door which gives you another inch or two. Do you need them? Take a look here: http://www.environmentaldoor.com/blog/do-i-need-reinforcement-struts-on-my-garage-door/. This cleared up almost 2 inches on my door. By the looks of things it could be the same on yours. With a lightweight door I'm pretty confident you don't need them on all panels.
    I agree on the sheetrock though. I'd pull the sheetrock, you could even use a router or chisel out out another inch+ from the studs, should have a negligible impact on the structure. You could easily gain 1.5 inches that way. If you are worried about fire protection, the sheetrock gives you somewhere around 1hr protection, you could close up the hole using tin, cover with flex-seal which is fire retardant and paint...
    Two simple fixes that would give you at least 3".
  18. Jul 10, 2018 at 10:36 AM
    #138
    TundraLuv
    Kent
    IA
    Here is the updated red line trace. I accidently made a dent in the wall with the trailer hitch receiver.
    ff4life4 and Pudge like this.
  19. Jul 10, 2018 at 10:42 AM
    #139
    TundraLuv
    Kent
    IA
    I removed the middle garage door reinforcement strut. The one on the bottom looks permanent or fixed. The top one I don't need to remove as my truck doesn't sit that high.
  20. Jul 10, 2018 at 10:55 AM
    #140
    RickC
    Rick
    Knoxville TN
    Oops at least that's an easy patch
  21. Jul 10, 2018 at 11:45 AM
    #141
    daylorb
    daylorb New Member
    Austin, TX
    2016 Limited 4X4
    Go Pack!
    I think you are there if you cut out the sheetrock. If you need to replace it, one of the easiest jobs in the world to patch sheetrock. Use a utility knife and cut the sheetrock out in a box where the bumper and hitch need to go into the wall, keep the box you cut out - if you need to patch it just put it in, tape it and float it. Anyone can repair garage sheetrock to an acceptable point.
    With it cutout, see if you have room, if so make it look as nice as you need it to. The only benefit to sheetrock is fire and aesthetics. Both easily dealt with.
  22. Jul 10, 2018 at 12:34 PM
    #142
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    I have done a quick sketch of what I would do if this was my dilemma. Just add about 2 foot extension to the front of the garage. It can have a little sloped roof and the columns that get added can become a nice looking architectural feature. You should be able to do it within HOA guidelines. It might cost a little bit but in the long run will be worth it.
    Keeping the existing door opening header beam (lintel) if it is too much of a structural issue for the rest of the wall above it, you can get a roll-up door that fits in the cove between the existing wall and the new wall.
    The roof can be something like this:
    1UPPER, nk1794, Newm and 1 other person like this.
  23. Jul 10, 2018 at 6:05 PM
    #143
    RickC
    Rick
    Knoxville TN
  24. Jul 10, 2018 at 7:04 PM
    #144
    RickC
    Rick
    Knoxville TN
  25. Jul 10, 2018 at 7:21 PM
    #145
    RickC
    Rick
    Knoxville TN
  26. Jul 10, 2018 at 8:24 PM
    #146
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    Make sure and get a qualified person for the seal coat on the garage floor. Lots of cheap products out there that won’t last but a few years. Also make sure who ever does the floor etches the concrete so the new product bonds to the concrete. If you go with an epoxy floor the flakes are supposed to cover the floor till refusal (another words 100%). Also make sure that if any of the floor coating or sealer is exposed to UV light it’s not going to fade or yellow. Just a few tips from experience. Garage looks great!
  27. Jul 10, 2018 at 8:28 PM
    #147
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    Nice sketch!
  28. Jul 10, 2018 at 8:30 PM
    #148
    1UPPER
    TEXAS
    Flux capacitor!
    This is the way I was thinking for the best fix for long term. Extend out the front side of the garage and do a small shed roof for an accent feature and retain a good function.
  29. Jul 11, 2018 at 4:54 AM
    #149
    Hand Protectors
    This thread is now morphing into: What could possibly go wrong status?
    OP may end up having to put in a new wall anyways after one wrong move with the gear/accelerator.
    Hey honey, we’re now remodeling the kitchen ‘cause I juiced the gas!
    NCinCO likes this.
  30. Jul 11, 2018 at 10:12 AM
    #150
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    2017 White DC TRD PRO
    I’m tagging along to see how this ends up. It might give me the motivation I need to tear out the storage room wall that keeps me from fitting my truck in my garage.
