Garage solutions (when Tundra won't fit)
Discussion in '2.5 Gen Tundras (2014-2021)' started by TundraLuv, Jul 6, 2018.
  1. Jul 8, 2018 at 7:20 PM
    #91
    TundraLuv
    TundraLuv [OP] New Member
    Kent
    IA
    2018 Midnight Black Metallic Limited Crewmax
    The other side of the wall is my kitchen.
  2. Jul 8, 2018 at 7:28 PM
    #92
    15whtrd
    15whtrd Mr. Blonde
    Put a header in to support the studs in the wall you want to cut out, and then basically treat it like a huge doorway that you leave the drywall on the interior of the house attached. This would be a gain of about 4 inches. Then put a parking curb in so that your truck will go no further.
    Mountun Goat and Coolhardy like this.
  3. Jul 8, 2018 at 7:34 PM
    #93
    TundraLuv
    Kent
    IA
    Possibly, will try ramps first.
  4. Jul 8, 2018 at 7:57 PM
    #94
    Blueknights75
    Ron
    Clayton, NC
  5. Jul 8, 2018 at 8:55 PM
    #95
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    Ok. I thought you had a detached garage. This definitely makes it more challenging then. Can you post a picture of your front garage with the garage door down? I have an idea to extend the garage door opening, track and door out.
    4x4_Angel, 15whtrd and Pudge like this.
  6. Jul 8, 2018 at 9:04 PM
    #96
    Pudge
    CT
    2015 Blue Ribbon Platinum
    This seems like it would be doable and it wouldn't really look much different from the front. I recall the OP saying something about having an HOA where he lives so some alterations are not possible. The framing looks to me 2x6 and then there's the brick facade. Moving the track to the outside of the garage neatly flush with the brick then trimming it out with some matching vinyl will not change the look much at all. Height may become an issue but I'm not sure how much clearance he has. To clear the closing door he may need to bump that header up a few inches but that should be too hard to do.
    15whtrd likes this.
  7. Jul 8, 2018 at 9:06 PM
    #97
    1UPPER
    TEXAS
    Flux capacitor!
    I actually have a few ideas. But I really like to match the exterior features of the garage with the home. There are a few ways to do this.
    Pudge[QUOTED] likes this.
  8. Jul 8, 2018 at 9:12 PM
    #98
    Pudge
    CT
    I'm with ya on that one. Maybe a pic of the whole front of garage. Door opened and closed. And a pic of the house from the front so we can see the trim and different features. Doesn't appear to be any trim around the garage door, just the casing, but the brick goes right to the opening. Maybe the builder can still source some brick. Looks like about a foot of wall thickness to work with a far as bumping the door and tracks out, making it look good will be the tough part.
  9. Jul 8, 2018 at 9:13 PM
    #99
    TundraLuv
    Kent
    IA
    Here is a photo i found off a website of it. Didn't want to walk outside near midnight.
    Pudge likes this.
  10. Jul 8, 2018 at 9:26 PM
    #100
    Pudge
    CT
    Do you have good clearance height wise when you drive in?
    I really think you can have that door moved outward about flush with the brick facade and trim it out, if you have the height clearance. That wall looks to be about a foot thick which is about what you need.
    I have the single door 2 car garage too. I used to fit a Tacoma and venza in there. I really doubt I could do tundra and venza plus I have no shed so all my stuff is in there..so I got divorced to have space for my truck. Lol.
    TundraLuv[OP] and Coolhardy like this.
  11. Jul 8, 2018 at 9:46 PM
    #101
    TundraLuv
    Kent
    IA
    I have good clearance once I pass the garage door.
  12. Jul 8, 2018 at 10:02 PM
    #102
    Pudge
    CT
    I'm talking the highest point of the truck and the lowest point of the door opening? You're gonna need a some decent space to move those tracks out clear the opening still.
  13. Jul 9, 2018 at 10:58 AM
    #103
    TundraLuv
    Kent
    IA
    No go on ramps. Tried six ways of Sunday and nothing worked. Backing it in on the ramps didn't appear to help. Drove it in normally and nothing. Part of the issue is the ramps I have to move back pretty far to get up on them and it basically erases any length gain. The back bumper or the front hood touched the wall before getting up on it.
  14. Jul 9, 2018 at 11:11 AM
    #104
    Trooper2
    JR
    Houston, TX (Suburban South)
    You will have to move the ramps back away from wall. The truck will get shorter when on ramps, maybe not much but a bit (geometry).
    Might have to mark where tires are on ground when all the way in, then place ramps accordingly, where wheels on top.
    TundraLuv[OP] likes this.
  15. Jul 9, 2018 at 11:19 AM
    #105
    TundraLuv
    Kent
    IA
    It's about 12-13 inches from the top of my truck roof to the top of the entryway into the garage.
  16. Jul 9, 2018 at 11:48 AM
    #106
    TundraLuv
    Kent
    IA
    Here it is with the ramps adjusted. I'm damn close, but it still looks like it won't shut. Didn't try to go head first again, worried about running through the wall. Ran out of time today can try tomorrow nothing else.
  17. Jul 9, 2018 at 12:08 PM
    #107
    Trooper2
    JR
    Damn!!! So Close!!!
  18. Jul 9, 2018 at 12:11 PM
    #108
    TundraLuv
    Kent
    IA
    Higher and or longer ramp? Can remove the license plate frame on the front to get a 1/2 inch to a inch at best.
  19. Jul 9, 2018 at 12:16 PM
    #109
    Trooper2
    JR
    Higher ramp for sure, don't think longer helps unless getting higher as well.
    If your state does not require front L.P. I would take it off. You will be really close to getting closed, not sure how feasible on daily basis. Suck in really hard, LOL!
    NCinCO likes this.
  20. Jul 9, 2018 at 12:18 PM
    #110
    1UPPER
    TEXAS
    Flux capacitor!
    If the truck is to long I would strongly consider looking for a flush mount style rear bumper. This would give you the extra room you need to close the garage door.
    Ike74, Mountun Goat, Pudge and 2 others like this.
  21. Jul 9, 2018 at 12:18 PM
    #111
    TundraLuv
    Kent
    IA
    State does require it in the front and rear.
    4x4_Angel likes this.
  22. Jul 9, 2018 at 12:21 PM
    #112
    TundraLuv
    Kent
    IA
    Is this all aftermarket or will it look OEM?
  23. Jul 9, 2018 at 12:24 PM
    #113
    1UPPER
    TEXAS
    Flux capacitor!
    I guess it depends on what bumper you go with.
  24. Jul 9, 2018 at 1:14 PM
    #114
    Bates5450
    Bates5450 Elephantitus
    Jacob Bates
    Dickinson, ND
    2018 SR5 CM Cement 4x4
    You can just make you bumper quick disconnect and remove when you want to garage it. Or make a custom resesed portion in the garage wall so your truck can back up that extra couple inches. Unless it’s concrete that’d be a difficult job.
  25. Jul 9, 2018 at 1:31 PM
    #115
    ardnutoz
    ardnutoz
    OZ
    SE-PA
    2018 Black TRD OR CM Limited
    Screenshot_20180709-163733.jpg Have a garage door company come out and see if they can slide that door out to a point just shy off flush with the brick.
    TXDrifter and Pudge like this.
  26. Jul 9, 2018 at 1:38 PM
    #116
    You have come to the end of the rope OP.
    No matter what you do, this is going to cost you a grip of money.
    Park the truck outside, you’ll be ok. This is the first home in 29 years of driving I’m able to park my truck inside a garage.
    4x4_Angel and Coolhardy like this.
  27. Jul 9, 2018 at 1:46 PM
    #117
    Coolhardy
    Coolhardy New Member
    Harris
    2014 black tundra
    Too many to list
    Cheapest solution would be to cut the drywall and get a few inches that u need from there. U will have to backup so the rear bumper goes inside the reccess area.
    Not easy to park on the ramps. All the other solutions discussed above starts at $1000+
    Or like Chris said, park it outside.
  28. Jul 9, 2018 at 1:54 PM
    #118
    sprtbkr
    sprtbkr Average Member
    Scott
    Denver, CO
    2018 Tundra SR5 4x4 Double Cab - Inferno
    TRD Wheels & Tires, Double Cab Fold-down Back Seat mod, LED Interior Lighting, Turned Off Seat Belt Chime, Franken-key (Flip Key), Duraliner Bed Liner, Bed Rails, Hood Wind Deflector, Console Gun Safe, iBoard 5" Running Boards, TRD Sport Bed Vinyl, Fortin Evo One Remote Start with Mycar Cellular Module, Plasti-dipped Badges and Bumper End Caps, Tinted front windows, Extang Solid Fold 2.0, Pop-N-Lock, TUNDRA tailgate inserts, RCI Powder Coated Skid Plate - coming soon - 12” android radio, oemaudio+ Reference 500Q, under dash/seat lighting.
    even cheaper would be to dent the garage door so it sticks out a few inches. :)
    lionix likes this.
  29. Jul 9, 2018 at 1:57 PM
    #119
    Grumpy Uncle
    Pat
    CO
    My oldest tried that on accident. Tried to back out with his Tacoma when the door was still going up. It worked in two ways, bent the hardy board door and p!ssed me off to high heaven! oh and scratched the topper.
    4x4_Angel and sprtbkr[QUOTED] like this.
  30. Jul 9, 2018 at 2:07 PM
    #120
    1UPPER
    TEXAS
    Flux capacitor!
    You can’t just simply move the tracks out like that. The garage door is typically wider than the opening so it butts against the weather seal strips. I know it looks like an easy fix but unfortunately it’s not. There is a possible fix but it’s not simple nor cheap.
    TomC843, Coolhardy and sprtbkr like this.
