Garage size
Discussion in '2.5 Gen Tundras (2014-2021)' started by PA452, Dec 31, 2021.
  1. Jan 2, 2022 at 12:13 PM
    Tundra2Yak
    Tundra2Yak New Member
    2016 1794 4x4 CM
    Pro Comp 6" Lift Fuel Renegade d263 Nitto Ridge Grappler 35 x 12.5 x 20 Borla cat-back exhaust Volant intake Bakflip MX4
    We have a side entry garage, 18w x 23.5d x 8h. It's slightly oversized with another 6 ft on the house side so that gives some extra room.
    You should be fine with 23 ft depth. I can pull mine in with just enough room to drop the tailgate and still be able to walk around the front. Getting this CM with 5.5 ft bed made me realize a 6.5 ft bed would be too tight.
    Height should also work. I have a 6" lift on 35s and still have some room to spare.
    If I could have more width i would. Backing in is the only option for me and if i give enough room to keep the doors from being able to ding the other vehicle, it's tight getting in and out. Go as wide as you can.
    Comical picture of my truck next to my wifes MDX.
    Elevatormatt likes this.
  2. Jan 2, 2022 at 12:52 PM
    Mr_Ed
    Mr_Ed New Member
    Ed
    2018 Limited 5.7
    None
    My garage measures 22' inside. I hung a piece of small rope about 3" from the front wall, and I pull the Tundra in until I see it move. That puts me about 2" from that wall. I then have roughly 2' of walk space behind it -- enough to walk behind it carrying something if it's not too large. The door height is 7', and I have plenty of room for my 2WD Limited. I'd say you should be fine, but bigger is, indeed, always better. :)
  3. Jan 2, 2022 at 1:04 PM
    Mr_Ed
    Mr_Ed New Member
    Ed
    2018 Limited 5.7
    None
    We have actually entertained a similar idea. We've talked about a large metal building with a 2BR apartment for us. Inside that building would be a motorcycle shop for me and an art studio for her. There would obviously be places to park our car and pickup. The RV would be parked in a manner that would give it water and electric to use as a spare bedroom or guest room. There would be a separate area for all the crap old, married couples acquire and must store -- lawn mowers, log splitters, yada, yada. We currently have 4 buildings housing all that crap that total about 3800 sq ft. I figure a 50' x 80' should be adequate. :D
    Blue By U and Darkness[QUOTED] like this.
  4. Jan 2, 2022 at 6:00 PM
    PA452
    PA452 [OP] New Member
    2021 Tundra SR5 CM TRD O/R
    What's the width on your garage door?
  5. Jan 3, 2022 at 2:17 AM
    Tundra2Yak
    2016 1794 4x4 CM
    18 ft wide.
  6. Jan 3, 2022 at 5:09 AM
    WXman
    WXman New Member
    Kentucky
    2016 Tundra SR5 Crew Max 4x4 5.7L
    My garage is 20.5 ft deep and my truck fits with literally a few inches to spare front and rear. Placement of the tennis ball parking aid is CRITICAL to make sure I don't damage the exterior wall as I pull in.
  7. Jan 3, 2022 at 5:27 AM
    This is terrible advice!! Where will you get your truck mod money from??? Kidding of course, build at least a little bigger than you think you should. You won't regret the space.
  8. Jan 3, 2022 at 5:32 AM
    Dmull1023
    Dmull1023 New Member
    2020 White Tundra Limited TDR OR
    I am starting on a detached garage today at the house. Dims will be 24w x 26d, 16x8 single door with 10' ceiling. wanted to make sure I had ample room for the tundra and wife's Durango with a little room to spare
  9. Jan 3, 2022 at 5:56 AM
    Tundra2Yak
    2016 1794 4x4 CM
    Assuming yours will be front entry vs. side? Side entry would be tight with a 16ft door and full size SUV.
  10. Jan 3, 2022 at 6:00 AM
    Mr_Ed
    Mr_Ed New Member
    Ed
    2018 Limited 5.7
    None
    Good advice. We added 10', and it was very useful. It's also full o_O
  11. Jan 3, 2022 at 6:13 AM
    Dmull1023
    Correct, front entry. Pad is existing at 22w x 24d, so we will just be adding concrete around the sides and rear, then applying a fresh coat to level it all out and make it uniform across.
  12. Jan 9, 2022 at 12:32 PM
    fmscott2
    fmscott2 New Member
    I bought a new construction in SE GA two years ago. Height of the garage is just fine, but the length is way to short for most cars let alone if you store anything else in there. During a hail storm I was JUST barely able to fit my truck inside with probably 3 inches to spare between the front bumper/wall and rear bumper/garage door. Stupidly short in my opinion. My next garage will have to comfortably fit my truck without moving any other junk I have stored in there.
  13. Jan 9, 2022 at 12:52 PM
    Kanobi13
    Kanobi13 New Member
  14. Jan 9, 2022 at 1:26 PM
    Dmull1023
    Just started 3xpanding my pqd before garage goes up. Garage will be 24w X 26d20220105_133129.jpg 20220105_133118.jpg 20220105_133104.jpg
    Tundra14Platinum likes this.
  15. Jan 9, 2022 at 4:51 PM
    DEboater
    DEboater New Member
    2021 DC SR5
    You can ask them to install a 12’ header in the back wall, for a future opening into a future shop space. That will make a future addition out the back easier. Just a thought I have no idea what your layout and room on the backside is like.
  16. Jul 26, 2022 at 4:21 PM
    bayetargeted
    bayetargeted New Member
    Okay, now I know I should always go bigger for such a car. I haven’t got a tundra yet, but I plan to buy it because it’s necessary for my work as a farmer and a forester.
    Also, I have been thinking about the garage door I should get for the new garage I am going to build. Since there will be precious things in the garage, I want the door to be as safe as possible. I know that no door will make it impossible to break in for thieves that are determined to get in. but it will at least give me some more time to react. I think about getting a door from advantagegd.com because they offer many security features and an insulated door option. What do you think?
  17. Jul 26, 2022 at 6:47 PM
    Dmull1023
    That's the reason I expanded my pad, and went with an 8' tall garage door. enough room for my Tundra, the wife's Dirango, and a workbench in the corner.295103169_390213093212969_252061003593499698_n.jpg 294920191_1066886057555979_3660014028995428381_n.jpg 295069989_1108312789763164_3912384755189947726_n.jpg 295127033_1188696175319565_6100381965512091534_n.jpg
    Half Assed, Blue By U and ColoradoTJ like this.
  18. Jul 26, 2022 at 6:54 PM
    French Avocado
    French Avocado Double Entundra
    Utah / Wyo
    No garage is ever large enough!
    BoysandHisToys and mountainpete like this.
  19. Jul 26, 2022 at 7:51 PM
    #49
    Blue By U
    Blue By U New Member
    Did you see post #19?
  20. Jul 26, 2022 at 8:21 PM
    #50
    French Avocado
    Utah / Wyo
    Yes - not applicable. Would your spouse agree to that? Not exactly a family house with a garage. That is a farm shed with a bachelor pad.
  21. Jul 26, 2022 at 8:47 PM
    #51
    Blue By U
    My kids have been on their own for 18 yrs. Wife would be totally fine, her house, my garage. No cabin fever here.
  22. Jul 26, 2022 at 9:12 PM
    #52
    BMET
    BMET New Member
    2018 Tundra Limited
    Get a big garage. This is me parking in my garage.
    GODZILLA likes this.
  23. Jul 27, 2022 at 3:42 AM
    #53
    mverkaik
    mverkaik New Member
    Hamilton, MI
    2021 TRD PRO CrewMax
    WeatherTech Floorliners Toyota Running Boards Reflex Liner Truxedo X15 Pro cover.
    I have a 26' deep by 36' wide garage. I have a 18'x8' and a 9'x8' door.
    I came from a a 24' deep garage and the extra 2' of depth is a Godsend.
    Push for more than 23'. It will probably work but is not optimal. Especially for what you are going to spend on the place.....
  24. Jul 27, 2022 at 11:58 AM
    #54
    joey2018
    joey2018 New Member
    Neighbor said I'd never get 3 cars and a golf cart in my garage... I think it's 20x30? Still not big enough.
  25. Jul 27, 2022 at 2:01 PM
    #55
    sensei
    sensei master and teacher of nothing
    trd boosted, trd bbk, fox stage 4, corsa, amp, jl/kenwood
    id love to have 23' depth. mine is like ~19.5' at our other property i store it at but it fits and is out of the washington state weather. that's all that matters.
  26. Jul 27, 2022 at 2:24 PM
    #56
    Retired...finally
    Do you climb in and out of your back window?
    shawn3210 likes this.
  27. Jul 28, 2022 at 8:04 AM
    #57
    joey2018
    joey2018 New Member
    No LOl! In that configuration the truck is not going anywhere without moving one outside. The benz sits outside most of the time and is our daily driver. I hate having it sit outside in the FL sun but the garage just isn't big enough.
    French Avocado likes this.
