Garage door sensor question
Discussion in 'Off-Topic Discussion' started by Tacogrande, Jul 26, 2019.
  1. Jul 26, 2019 at 9:16 AM
    Tacogrande
    Tacogrande [OP] New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    Is it possible to add a second of safety sensors about waist high on a garage door? I dont see why not as its low voltage and i just want to buy the parts and do it myself. Called two companies and they dont sell parts. Almost had a really bad accident pulling in the garage. My wife and son entered the garage then i started backing in and my son hit the garage door opener, closing the door and luckily my wife hit the button to raise the door back up before it crashed into my windshield! So now i want to add a second sensor to prevent that accident from ever happening.
  2. Jul 26, 2019 at 9:34 AM
    sf319
    sf319 New Member
    Utah
    2014 CM Barcelona Red SR5 5.7
    Dash Cam|PowerStop Z36|DIY bed rails|DIY Pop-n-Lock|LED interior
    They sell the sensors at the big box stores like Lowes and Home Depot. I have been looking at doing the same thing. I have been wondering if wired in series they would work the same.
  3. Jul 26, 2019 at 10:23 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
  4. Jul 26, 2019 at 10:26 AM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    Can you just relocate them higher? Not 100% sure if that would solve you're issue, but I would think so. About 12-18" higher off the floor.
  5. Jul 26, 2019 at 10:28 AM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    I thought that first too but maybe he has pets, I've also seen my kid lie belly down across the threshold and chalk draw on the garage floor.
  6. Jul 26, 2019 at 10:44 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    I thought about that too. Personally...I back in 99% of the time and have my backup camera, but of course there could unfortunately be that 1% time.
  7. Jul 26, 2019 at 10:48 AM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    I would just try it I don’t think the sensors are that expensive and splice into the ran sensor wires already there and test it for workability!! Let us know?? If it doesn’t or it gets out of whack take apart and put back to normal??. :)
  8. Jul 26, 2019 at 11:02 AM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Sold and shipped by Amazon, just return if it doesn't work
  9. Jul 26, 2019 at 11:31 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Some quick googling makes me think this won't work. Others have tried wiring a second set of sensors up in series and parallel and neither seem to work. Something about the voltage drop and the type of pulse used in the optics.
  10. Jul 26, 2019 at 12:45 PM
    sf319
    sf319 New Member
    Utah
    This was my concern too... I wonder if you could put something like mirrors to do something similar.
  11. Jul 26, 2019 at 12:54 PM
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
    It is absolutely possible. Get you a set that are the same voltage and set up as the ones you currently have. You'll want to wire them in series so that if the top sensor brakes but the bottom one does not your door will stop and reverse. If you wire them in parallel you would have to break both of them at the same time in order for the door to stop.
