Garage door opener?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Rski85, Feb 15, 2018.
  1. Feb 15, 2018 at 6:21 PM
    Rski85
    Rski85 [OP] New Member
    Since my 18 cm dose not have a garage opener is there any we can install and program instead of have 3 garage door remotes( 3 different houses?
  2. Feb 15, 2018 at 7:42 PM
    nowayout
    nowayout New Member
    NY
    15 Dbl
    Just double check. Mine is on the auto dim mirror.
    MotoTundra likes this.
  3. Feb 15, 2018 at 7:51 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I believe you can buy and hook up a homelink mirror if you don't have one
  4. Feb 15, 2018 at 8:07 PM
    Rski85
    Yea i don't have one. Just plain rear view mirror
  5. Feb 15, 2018 at 8:11 PM
    TheBeast The Beach
    or phone app. That's what I have. You can add the module to your existing garage door as well if it's an old one.
  6. Feb 15, 2018 at 8:26 PM
    Rski85
    Link on how and where to get the module?
  7. Feb 15, 2018 at 8:29 PM
    TheBeast The Beach
  8. Feb 15, 2018 at 8:31 PM
    TheBeast The Beach
    the GarageMate looks to have good reviews on Amazon. No experience with that particular model but worth a try.
  9. Feb 15, 2018 at 8:36 PM
    My garage remote has three spots for different doors. Would that work?
    I like the idea of using a phone app, until your phone takes a dump.
    Glad my trucks have always had the garage door options.
    NewImprovedRon likes this.
  10. Feb 15, 2018 at 8:38 PM
    I hate garage door openers. (Remotes) thieves break into your vehicle, snap a pic of ur address and take ur remote. You’ll never know until it’s too late.
  11. Feb 15, 2018 at 8:39 PM
    Yep. If using a garage door opener, better take it inside with you.
    T-Rex266[QUOTED] likes this.
  12. Feb 15, 2018 at 8:47 PM
    TheBeast The Beach
    with the app I can monitor status of the door and close it from anywhere or open it for any guests..it is pretty cool I gotta say and no need for remotes where someone could steal it from your car.
    15whtrd, T-Rex266 and ColoradoTJ like this.
  13. Feb 15, 2018 at 8:55 PM
    T-Rex266 likes this.
  14. Feb 15, 2018 at 9:00 PM
    TheBeast The Beach
    pictures of said Tacoma :spy:
  15. Feb 15, 2018 at 9:07 PM
    Ok
    TheBeast[QUOTED] likes this.
  16. Feb 15, 2018 at 9:51 PM
    We’ll do another group hug to make her feel better
  17. Feb 15, 2018 at 10:33 PM
    A sammich
  18. Feb 16, 2018 at 6:03 PM
    MookTastic
    MookTastic Because I was inverted!
    Trice
    Rapid City, SD
    2013 5.7L White D/C TSS Offroad Icon Stage 8
    Icon Stage 8 AlphaRex Headlights
    I'm having trouble getting my homelink on my mirror to work...any tips?
  19. Feb 16, 2018 at 6:24 PM
    8MINT8
    8MINT8 #NotBetty
    Lost
    2018 Unicorn TRD
    Light has to be blinking orange. Press and hold garage door opener close to homelink. Just pressing and releasing did not work for me. Once its saved, long press worked better on homelink.
  20. Feb 16, 2018 at 6:29 PM
    MookTastic
    Trice
    Rapid City, SD
    Will give it a try in the morning. Thanks
  21. Mar 22, 2018 at 9:55 PM
    wes77
    wes77 New Member
    I have success connecting my genie with home link. But it never works the next day. It always loses it connectivity the next day
    Anyone have the same problem? Any tips
  22. Mar 23, 2018 at 2:13 AM
    NoDak
    NoDak New Member
    2017 Tundra TRD Pro CM - Super White
    Any chance you have a new garage door opener? If so, the homelink in your 2013 may not be compatible with the newer security features of the garage door opener. I believe it has to do with the frequency they use now.
  23. Mar 23, 2018 at 5:16 AM
    JeremyGSU
    JeremyGSU New Member
    Jeremy
    2016 Tundra
    That's why I have my ADT alarm setup to the garage as well since I still use the standard remote.
  24. Mar 23, 2018 at 5:28 AM
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    The issue I had was that the signal wasn't reaching the garage opener antenna. I made the antenna longer by attaching speaker wire to the opener's antenna and running it along the ceiling out closer to the door (about 10' additional). Now, the signal reaches easily. With my situation, it was weak reception at the garage door opener.
  25. Mar 23, 2018 at 11:06 AM
    wes77
    wes77 New Member
    I will give it a try....thanks
  26. Mar 24, 2018 at 7:31 AM
    JoeJob
    JoeJob Drummer for Booty and the Hoe Fish
    Joe
    New England
    2018 Tundra Limited CM Silver Sky
    TRD rear sway bar, console organizer, stubby antenna, LEDs for cabin, cargo, license plate, and reverse lights, power-fold mirrors, Westin nerf bars, full stereo upgrade. Future - color-match grill surround/bulge, mirror caps, handles, plasti-dip badges.
    I used to have a '14 Tacoma TRD sport that I traded for my Tundra. My '06 Tacoma had a pocket in the overhead console for the garage door remote, but the '14 had a 2nd sunglasses pocket instead and no home link mirror. I ended up taking the remote apart and found the 2 leads that trigger the opener and wired a momentary button to it. I think I found this in the TacomaWorld forums. When you short out the leads, it mimics the button press and opens the garage. I ended up using a programming button from a remote starter and installed it in a blank under the radio, then hid the remote inside the dash. Works pretty well to avoid the worry of someone breaking in and taking your remote and registration, and much cheaper than an aftermarket home link setup.
