Fuseboard with bluetooth controls?
Discussion in 'Lighting' started by point08, May 24, 2021.
  1. May 24, 2021 at 8:24 AM
    point08
    point08 [OP] New Member
    Kyle
    2014 Toyota Tundra 5.7L SR5 4WD DC
    AirLift LoadLifter 5000 Ultimate Plus, AirLift Wireless One 2nd Gen, TRD Rear Sway Bar, Bakflip G2 Tonneau Cover, Running Boards, Tint, Power Tailgate Lock, Hike-It X9 Throttle Controller, Tekonsha P3 Brake Controller with Custom In-Dash Housing, Method 701 Wheels, Toyo Open Country III Tires, 3WLiner Window Mod, External Fuse Box, Dash Cam, Pioneer DMH-1500NEX
    Hey everyone,
    I can't for the life of me find a reply where someone was showing off their fuseboard/box for wiring things up that also had bluetooth controls. I remember the circuit board being red. I'm looking to add a better way to wire in extra stuff (bed lights, dash cam, etc) and stay out of the OEM fuse box as much as possible without running a ton of wires through the firewall.
    Cheers!
  2. May 24, 2021 at 8:24 AM
    Sunnier
    Sunny
    San Diego, CA
    SwitchPro 9100
    edit: I mis-remembered the model number. Fixed it.
    point08[OP] likes this.
  3. May 24, 2021 at 8:30 AM
    point08
    Kyle
    And just like that, an answer came to me. Thank you!
    Sunnier likes this.
  4. May 24, 2021 at 9:26 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
  5. May 24, 2021 at 10:37 AM
    Sunnier
    Sunny
    San Diego, CA
    We’re doing this in our 4 runner. Blue Sea fuse box but essentially the same set-up. But to add multiple switches in the dash, still gotta run a bunch of wires through the firewall; at least I can’t figure out a way to do it otherwise. Definitely makes me appreciate the SP in the Tundra. Wires through once, between the SP and the one switch panel with 8 buttons.
  6. May 24, 2021 at 11:19 AM
    BlueCrushSC16
    Charleston, SC
    Pop a hole in the firewall and install a BX connector. Then, use some fireblock/ ductseal.
    https://www.amazon.com/Hubbell-Raco...&keywords=bx+connector&qid=1621879980&sr=8-11
    https://www.amazon.com/Ideal-Indust...t=&hvlocphy=9010491&hvtargid=pla-523518281223
    Sunnier[QUOTED] likes this.
