Fuse tap or ?
Discussion in 'General Tundra Discussion' started by Mnorris1206, Feb 5, 2019.
  1. Feb 5, 2019 at 4:20 PM
    Mnorris1206
    Mnorris1206 [OP] Super white is fast as f***
    08 tundra
    Installing these tomorrow. I just want the light when opening the door .should I use a fuse tap or tap into interior light wire
    jeremyd likes this.
  2. Feb 5, 2019 at 5:08 PM
    swede78
    swede78 Not so new member
    Lars
    westminster co
    2019 tundra platinum mgm crew max
    Nothing yet
    Is he have a courtesy light in your door just tap into that
    NewImprovedRon likes this.
  3. Feb 5, 2019 at 5:14 PM
    swede78
    Lars
    westminster co
    Nothing yet
    Text to speech sometimes doesn't work very well meant to say if you have courtesy lights in your door anyway I just did this to my 08 tundra and wired up my puddle lights in my mirrors tap right into the courtesy light,and it will be a short wire run.
  4. Feb 5, 2019 at 5:15 PM
    Mnorris1206
    08 tundra
    Yea I was just wondering another way besides taping into a wire don't really like the idea .Their should be a fuse for the carge lights under the dash also right ?
  5. Feb 5, 2019 at 5:18 PM
    swede78
    Lars
    westminster co
    Nothing yet
    Why not just tap into the positive and negative wires of the courtesy light,why go under the truck
    Mnorris1206[OP] likes this.
  6. Feb 5, 2019 at 5:23 PM
    Mnorris1206
    08 tundra
    Those look alot better then what they sent me .
    040Tundra, NewImprovedRon and 15whtrd like this.
  7. Feb 5, 2019 at 5:27 PM
    Mnorris1206
    08 tundra
    This strip is like 5' they suggest mounting under the truck where the two bodies come together. Sorry idk what that area is called
  8. Feb 5, 2019 at 5:30 PM
    Mnorris1206
    08 tundra
    And I still cant decide of I want the amber part hooked up to the signals or not .That would kinda be nice because cars next to me at night sit right beside me when I'm trying to get over even when I do have signal mirrors.
    jeremyd likes this.
  9. Feb 5, 2019 at 5:30 PM
    15whtrd
    15whtrd Mr. Blonde
    How
    I used these for my pop-n-lock, tapped in the passenger kick. Only thing better in my eye is soldering or a dedicated power.
  10. Feb 5, 2019 at 5:31 PM
    15whtrd
    15whtrd Mr. Blonde
    Pinch weld seam thingy.
  11. Feb 5, 2019 at 5:32 PM
    Mnorris1206
    08 tundra
    Exactly. /\/\/\ roflmao :yes:
    15whtrd[QUOTED] likes this.
  12. Feb 5, 2019 at 5:32 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    Now I’ve gotta do another mod ! Lol
  13. Feb 5, 2019 at 5:35 PM
    Mnorris1206
    08 tundra
  14. Feb 5, 2019 at 5:47 PM
    15whtrd
    15whtrd Mr. Blonde
    I’m actually liking this mod. I think I would want them attached to my cargo light so that I could turn them on without the dome lights coming on. This way you could use them as a cheap rock light when trailing at night.
    Pudge, Mnorris1206[OP] and jeremyd like this.
  15. Feb 5, 2019 at 6:02 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    Or they might speed up ! Lol
  16. Feb 5, 2019 at 6:06 PM
    Mnorris1206
    08 tundra
    Great point ! I would use them alot that way because of camping also when turning on the cargo light I will be able to see where I'm walking also.
  17. Feb 5, 2019 at 6:08 PM
    swede78
    Lars
    westminster co
    Nothing yet
    My badd I thought these were door seal lights not underneath the truck
  18. Feb 5, 2019 at 6:17 PM
    Mnorris1206
    08 tundra
    I will say looking at the quality of these opt7 seems to be a good brand . They make alot of different lighting for trucks .
  19. Feb 5, 2019 at 6:23 PM
    NCTundra18
    NCTundra18 New Member
    Jeff
    Candler, NC
    2018 White Limited Crewmax
    TRD dual exhaust, Rough Country lift kit and too much money spent.
  20. Feb 5, 2019 at 6:28 PM
    Itchyjuffowup85
    Itchyjuffowup85 New Member
    2014 Black TRD 4X4 5.7L V8
    Here some working pictures of the one I did. I dont have pictures of the wire I tapped in to though. Theres a rubber grommet underneath the carpet in all four floor boards (Driver, Driver Rear, Passenger Front, Passenger Rear) I did all of my passenger lights and came up the passenger front grommet. (Drilled a whole just barely big enough for the conduit to pass through) then underneath the carpet and around behind the dash to the driver side kick panel. Driver side was the same through the grommet and then to the scuf plate. I tapped the positive into the cargo wire. And the ground to the trucks ground behind the kickplate. I can take pictures of that tomorrow if you need them.
    Pudge, jeremyd, 15whtrd and 1 other person like this.
  21. Feb 5, 2019 at 6:31 PM
    Mnorris1206
    08 tundra
    Nice yea that will be my hardest part to figure out what wire. But my machanic buddy will be here to help. So I'm sure he can figure that out. Those are bright amd noce install .
  22. Feb 5, 2019 at 6:36 PM
    NCTundra18
    Jeff
    Candler, NC
    I'd like to see some pictures of where you tapped into the wire. If you don't mind.
  23. Feb 5, 2019 at 6:36 PM
    Itchyjuffowup85
    Thanks! I'll see if I can get a picture tomorrow of the wire. If you search the forums here someone has a great picture of the whole harness and they show which wire. It helped me out. I tapped the wrong wire first (still dont know what it was for lol) but they didnt work. Got it right the second time though.
  24. Feb 6, 2019 at 6:25 AM
    Itchyjuffowup85
    Not the greatest picture, but heres one. This wire is by itself, not twisted or braided with any others.
    Pudge likes this.
  25. Feb 6, 2019 at 7:28 AM
    Itchyjuffowup85
    Heres the picture @NewImprovedRon posted of the wiring harness, the cargo light wire is the one on the right. The little 20g ? 22 maybe brownish purple wire.
  26. Feb 6, 2019 at 7:29 AM
    Mnorris1206
    08 tundra
    Brown? Maybe gray lol if so I think I got it !
  27. Feb 6, 2019 at 7:30 AM
    Itchyjuffowup85
    That looks like it. If you have the positaps or even a ttap you can check it. If its not it just make sure to use some electrical tape over the wire where you tapped it.
  28. Feb 6, 2019 at 7:30 AM
    Mnorris1206
    08 tundra
    O one more what is ground the black one or should I take that to somewhere else .
  29. Feb 6, 2019 at 7:32 AM
    Itchyjuffowup85
    I ran the ground to the ground screw behind the kick plate on the drivers side. Its the black wire that comes off the lights. Red is your positive that goes to the cargo wire.
  30. Feb 6, 2019 at 7:32 AM
    Mnorris1206
    08 tundra
    This is what they sent me
