Fuse size for 2nd battery
Discussion in '1st Gen Tundras (2000-2006)' started by dropindeuces, Mar 1, 2021.
  1. Mar 10, 2021 at 11:12 PM
    dropindeuces
    dropindeuces [OP] New Member
    Just got my fridge in, starting the stress testing now;
    Shark Bait and tvpierce like this.
  2. Mar 11, 2021 at 3:18 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    53 or 42 quart?
    I'd be interested to hear your impressions.
    Do you have a multi-meter? I'm curious how many amps it draws, and how frequently is cycles at a given temperature.
  3. Mar 16, 2021 at 12:54 AM
    dropindeuces
    Its the 53. I actually kinda like it, its not too big but large enough to pack some frozen meat and keep vegies or whatever cool. Personally I would have designed it for more room to the "fridge" section but its good enough.
    Yeah I have a multimeter but I wanted to check out what it could actually do and in what kind of time frame if that makes any sense hahaha. The first night when I first fired it up it read ~74 F, I set it to 32 and let it run all night plugged into my house outlet. I recall when I woke up I saw it round 45ish, the bottles were not frozen just cool. I let it settle down for a day or two and decided to set it to 0.0 degrees F. About a day and a half all bottles in the freezer section were completely frozen and the fridge bottles were just cold.
    I understand what your concerned about with the current draw and how many times it cycles. I'll update this as I go.
  4. Mar 16, 2021 at 1:01 AM
    dropindeuces
    Still trying to decide which size/type battery to go with for my second battery lol.
  5. Mar 17, 2021 at 2:58 AM
    tvpierce
    Maine
  6. Mar 17, 2021 at 12:51 PM
    dropindeuces
  7. Mar 17, 2021 at 1:15 PM
    dropindeuces
    Nevermind, some quick googling and I get it now. Guess Im off to my local marine or rv shop to look around.
    des2mtn likes this.
  8. Mar 17, 2021 at 1:53 PM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    Good luck, sailor.
    Tundra2 likes this.
  9. Mar 18, 2021 at 3:26 AM
    tvpierce
    Maine
    You're going to see marine/RV batteries rated on "Reserve Capacity" which is the number of minutes the battery can deliver 25 amps before it drops below 10.5 volts.
    You'll find solar system (and other types of true deep cycle) batteries rated in Ah (amp-hours). A 100Ah battery will deliver 1 amp for 100 hours, 2 amps for 50 hours, 3 amps for 33.3 hours, etc.
    In order to compare the two types of batteries, you need to convert "reserve capacity" to Ah.
    Here's a good site for that: https://sciencing.com/how-8681870-convert-reserve-capacity-amp-hours.html
    Here's another good site to help you calculate your power needs: https://www.caravansplus.com.au/guides/calculating-how-big-your-battery-needs-to-be-a-44.html
    (In fact, if you scroll down the page a bit, it gives a scenario for running a fridge/cooler like the one you just bought.)
    The take-away is that the solar/RV deep cycle batteries are superior to the "marine/RV" batteries.
    Case in point: if you take the scooter/solar battery I linked to above, and compare it to a good "marine/RV" battery like this one, you see the scooter/solar battery is rated for 100 Ah, and the marine/RV battery is rated for 62.5 Ah. They both cost a little over $200 and the scooter/solar battery is truly designed for slow, constant power delivery like we need for the application we're talking about. It's really a no-brainer.
  10. Mar 18, 2021 at 11:31 PM
    dropindeuces
    Ahhh good to know, thanks for that bit of knowledge. Thanks for links too, I took a quick look and theres tons of information I need to read through haha. Is this the battery you were talking about that you sent: https://www.amazon.com/Universal-Po...s=Universal+Power+Group&qid=1616135172&sr=8-1 ? Its cheaper through Amazon, saves you ~30$. I looked around and yeah it looks like you found (if this is the correct one) the most cost effective one.
  11. Mar 19, 2021 at 3:05 AM
    tvpierce
    Maine
    Yeah, it appears to be the same. But to be clear, we don't know who makes these batteries, and to what specifications. We know they're made in China (which doesn't necessarily mean low quality), and that they're "generic" -- meaning there is no name brand. I might be more inclined to trust a brand like Renogy because they're a pretty well-respected solar company. But given the price difference, it may be worth rolling the dice with the cheaper/no-name battery to get started in all this. It's only $180. If it lasts 6-8 years instead of 10 years, it's still given good service at a reasonable price.
  12. Mar 19, 2021 at 12:16 PM
    dropindeuces
    Thats true, they seem to look the same but might not be built to the same specs. I'll have too look at other options just to compare, I'll update as I figure out which one I decide to go with.
