Funky Electrical Issue, Help!
Discussion in '1st Gen Tundras (2000-2006)' started by scooterprint, Nov 12, 2020.
  1. Nov 12, 2020 at 5:27 PM
    scooterprint
    scooterprint [OP] Idiot with a wrench
    Jeremy
    Conway, AR
    ‘04 DC 4x4
    Bone stock
    Greetings guys,
    I've got a bit of a funky electrical issue. Over the last few weeks, I had my DRLs and Tail lights stay lit after blinking when the truck would lock (normal turns, brakes, and hazards worked just fine). That issue magically disappeared with nothing on my part, after letting it sit overnight and driving the truck around some.
    Tonight I went out to go somewhere in my truck, got in and stuck the key in the ignition, and attempted to start the truck. I heard a pop (Almost like a fuse blowing), and everything went dead. No lights of any kind, no ignition beep, no starter when actuating the key, no locking with the remote, as if someone had completely disconnected the battery. I popped the hood and took the negative battery terminal off and back on. Tundy fired up without any issues and everything was working just fine. I checked all the relays and fuses in the engine bay and driver's side kick panel, and none of them are blown or not working.
    Before I take the truck in to toyota so they can empty my wallet and steal a limb or two, does anyone have any ideas?
    04 DC Limited, only electrical modifications to my knowledge is a TBC and LEDs inside and out (PNP replacements, no wiring modification).
  2. Nov 13, 2020 at 6:55 PM
    2000 Limited TRD AC 4X4 Thunder Grey 270k miles. 2019 Limited TRD CM 4x4 Cement Grey 75k miles
    2000: Bilstein 5100's 16x8 589's with 265/75/16 and 1.25" spacers Flowmaster 50 series over the axle dump Pioneer touchscreen with backup camera Full interior and dash LED conversion Trailer brake controller with 7 pin Bedliner coat bumpers & trim ARE topper 2019: ARE topper with full Bedrug kit and Vortex rack TRD shifter 1.25" wheel spacers (I like to live dangerously) Red tow hooks for that +15 grip bonus
    Greetings from Cabot, AR. Strange electrical issue indeed. you've swapped some of the lights in question for aftermarkets. I would start there. I have some LED's in other applications that behave strangely. They glow dimly when turned off, glow dimly when other electrical items are activated etc., but appear to work normal otherwise. Is the issue still occurring?
  3. Nov 13, 2020 at 6:59 PM
    scooterprint
    Jeremy
    Conway, AR
    ‘04 DC 4x4
    Bone stock
    I haven’t had any more issues since they occurred last, but I’ll get a set of normal bulbs and see if the issue comes up again.
    Thanks
    torino69 likes this.
  4. Nov 14, 2020 at 6:58 PM
    scooterprint
    Jeremy
    Conway, AR
    ‘04 DC 4x4
    Bone stock
    Welp, Spoke too soon!
    The issue came back! I tried to start my truck and it made the same popping noise again. I left the key in the run position for a few seconds to see if it would do anything, and it started slowly pulsing the interior lights, as well as a relay inside the dash. Again, disconnecting and reconnecting the battery fixed the issue, at least temporarily. Hmm...
  5. Nov 15, 2020 at 6:45 AM
    Professional Hand Model
    Hand Protectors
    Might be bad alternator. How many miles you have on the odo?
  6. Nov 15, 2020 at 7:39 PM
    scooterprint
    Jeremy
    Conway, AR
    ‘04 DC 4x4
    Bone stock
    214,xxx. I don’t think it’s alternator though. It hasn’t shown signs of sluggish starting or the battery dying. I’ll test it tomorrow though just to be sure.
  7. Nov 15, 2020 at 8:22 PM
    Ry24000
    Ry24000 New Member
    Ryan
    Carson, WA
    2019 Tundra SR5 TRD offroad Quicksand
    Debadge, ARE z series top, Ironman Foam cell pro 3" lift, SPC UCA's, ICON vector 5 & Toyo ATIII 285 75R 17, Warn 9.5XP mounted in a Victory Blitz bumper. GTR 1000LM+XTR LP Reverse Light System
    Wierd! I agree with Knabores start with the lights and check for short circuits and mice damage. can you isolate the popping noise location?
  8. Nov 16, 2020 at 11:12 AM
    bmf4069
    bmf4069 Yup, that's car parts in a dishwasher
    TX
    02 AC sr5 4wd v8
    That sounds like a dead battery to me.
    Stuck in the '00s likes this.
  9. Nov 16, 2020 at 11:32 AM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab, Beta Variant (I call it my Land Yacht)
    I had similar symptoms on a car years ago. It turned out to be a battery problem. The battery had an internal break that popped open (quite noisily) when I tried to start it. Turning on the lights, or other low drain items, didn't open the circuit. Once I tried to start it, everything went almost dead, but hitting the terminal brought it back. A new battery cleared the problem.
  10. Nov 17, 2020 at 10:27 AM
    Stuck in the '00s
    Stuck in the '00s Experienced member
    Mikey
    SE Wisconsin
    2004 Phantom Gray DC 4X4 Limited Tundra
    Western plow, custom bed
    I would lean in this direction and test the battery.
  11. Nov 17, 2020 at 10:33 AM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    05 DC SR5 / 06 SEQUOIA LTD
    Battery posts clean? Use a post cleaner brush with male and female wire brush to clean connections really good. It's never that simple, but worth a shot.
    Tundra2 and 1lowlife like this.
  12. Nov 17, 2020 at 10:33 AM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    X3
  13. Nov 23, 2020 at 9:41 AM
    Ry24000
    Ry24000 New Member
    Ryan
    Carson, WA
    Please share the outcome of this when you figure it out.
  14. Nov 23, 2020 at 9:52 AM
    scooterprint
    Jeremy
    Conway, AR
    ‘04 DC 4x4
    Bone stock
    Will do. Going to take it to the dealer sometime soon.
  15. Dec 24, 2020 at 8:44 AM
    scooterprint
    Jeremy
    Conway, AR
    ‘04 DC 4x4
    Bone stock
    Quick update. Ended up not taking it to the dealer. Issues got worse to the point of not starting.
    Had the battery checked/load tested with no issues. Upon reinstalling I noticed both battery terminals were loose, but no matter how much I tried to tighten em, they wouldn’t budge. Either seized or completely tightened.
    Went and bought new ends for negative and positive connections, as well as a fresh ground wire from neg to chassis.
    The negative terminal was a bear to deal with. I was unable to just use a new connector. I ended up having to use some scrap tin as a spacer to allow me to securely fasten the cable end onto the post.
    Going to keep an eye on things, but so far, so good. A new battery will probably be not far down my list, and hopefully it solves the magical shrinking battery post.
  16. Dec 24, 2020 at 8:47 AM
    Stuck in the '00s
    Mikey
    SE Wisconsin
    Battery, huh?
  17. Dec 24, 2020 at 8:58 PM
    scooterprint
    Jeremy
    Conway, AR
    ‘04 DC 4x4
    Bone stock
    I didn’t even know those were a thing. I’ll pick up a set. Thanks!
