Fumoto Valve
Discussion in 'General Tundra Discussion' started by Rica25, Nov 25, 2018.
  1. Nov 25, 2018 at 8:53 AM
    Rica25
    Rica25 [OP] Got Bam? IG ......@TNDRA08
    Ricardo
    Tulare
    Who has one and do you recommend installing .....any possible issues having it on with RCI skid plate?
  2. Nov 25, 2018 at 8:55 AM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    I've had one installed for a couple years now with no issues. I don't see why it wouldn't work with the skids. I have the TRD pro skid
    Rica25[OP] likes this.
  3. Nov 25, 2018 at 8:56 AM
    El Nope-o
    El Nope-o New Member
    2010 Tundra Double Cab
    Mostly Stock
    I have one. Makes it super easy.
  4. Nov 25, 2018 at 8:56 AM
    Rica25
    Ricardo
    Tulare
    Just doing my first oil change after installing skid plate this month just wondering if I should install the Fumoto valve I ordered
  5. Nov 25, 2018 at 8:59 AM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Do it! Makes changes super easy!
  6. Nov 25, 2018 at 9:00 AM
    Rica25
    Ricardo
    Tulare
    What size of line do u insert to drain oil ?
  7. Nov 25, 2018 at 9:48 AM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    I don't use a line, I just spit it out into a pan. Probably a 1/4" would work
    Rica25[QUOTED][OP] likes this.
  8. Nov 25, 2018 at 9:56 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    I have the fumoto, hose, and clip, all in my toolbox, next oil change they are going on!
    At least I got the RCI skid on quickly.
  9. Nov 25, 2018 at 10:02 AM
    Cfincke
    San Antonio
  10. Nov 25, 2018 at 10:33 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    I believe the valve is on sale right now for Black Friday buy one get one free
  11. Nov 25, 2018 at 10:48 AM
    Outbound
    Aaron
    Northern Alberta
    I ordered a Fumoto valve for my truck this last summer. When I went to install it, it would only screw in 2 threads. I didn't want to force it and strip threads resulting in a leak. I ended up returning it. The factory drain plug threaded in without problem. :der:
    I'm going to re-order one and try it again. I'm wondering if the Fumoto plug's threads were out of spec.
  12. Nov 25, 2018 at 11:00 AM
    Professional Hand Model
    Hand Protectors
    Good move by not forcing the issue. Probs a British Thread vs. standard metric? I know the rear diff breather extension on our models required a britsh thread versus standard metric. Could be the case here. On our models, its pretty easy to change the oil without the Fumoto. I think these newer gens with skid plates being in the way is why these are popular devices.
  13. Nov 25, 2018 at 11:12 AM
  14. Nov 25, 2018 at 11:16 AM
    Outbound
    Aaron
    Northern Alberta
    That could be it. I didn't spend too much time trying to figure out the threading. It was the F103N though, as specified by Fumoto's website. I just checked their website and they use 12mm - 1.25 threads. Any idea what our drain plugs are?
    We're definitely lucky with our 1st Gens being easy to do. I want one since I occasionally have to do an oil change in the dead of the Canadian winter and I don't have a garage. Not much fun messing around with drain plugs at -30C while laying on icy concrete. :(
  15. Nov 25, 2018 at 11:22 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    Mine works perfect. I have a hose attached to it and put it right into a milk jug ..It does drain slowly though.
  16. Nov 25, 2018 at 11:43 AM
    crabbymcnab
    crabbymcnab New Member
    2016 Inferno SR5
    I had one on my 2016. It took forever to drain, a steady but small stream. I wondered why it was taking so long, removed the hose and valve and the oil poured out. It was all the way open and I inspected when it was off, everything looked ok. Maybe the internals aren’t opening enough for a larger flow.
  17. Nov 25, 2018 at 12:11 PM
    Rica25
    Ricardo
    Tulare
    Got it installed now
    boardude[QUOTED] likes this.
  18. Nov 25, 2018 at 1:15 PM
    RCI sells them!
  19. Nov 25, 2018 at 3:22 PM
    Rica25
    Ricardo
    Tulare
    Yeah I purchased when RCI skid was ordered
  20. Nov 25, 2018 at 4:40 PM
    RangerBP
    RangerBP SC Expat. Go gamecocks.
    2017 4x4 DC, Silver Sky
    Works great with the RCI skid. Is tucked away, but is accessible.
    Just did an oil change this afternoon. Quick, easy, no mess.
  21. Nov 25, 2018 at 4:57 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    I've had one on my Tundra since the first oil change . 30,000 miles with no problem. They have over 25 years of manufacturing and "development" on them. Rock solid design and performance.
    Have one also on my Jowett Performance oil filter cap. Mega easy to drain the oil from the oil filter housing.
    https://jowettperformance.com/products/coming-soon-billet-oil-cap-for-filter
    Watt maker and nowayout like this.
