Fuel wheels/balancing issue
Discussion in 'Wheels & Tires' started by BTBAKER, May 1, 2018.
  1. May 2, 2018 at 4:54 PM
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    I Still have vibration even after they turned tires 180. They claim they balance out great. I’m not sure if I should make them swap the tires or the wheels or both? They are going to do something though because 2500 dollars invested and I have a wobble.
    I know tie rods were mentioned but damn, I don’t want to throw money into that if I don’t have to.
    Prostar 190 likes this.
  2. May 2, 2018 at 4:56 PM
    You need to find someone with a Hunter road force balancer it will be able to tell if the tire or wheel or both are bad.
    BTBAKER[OP] likes this.
  3. May 2, 2018 at 5:21 PM
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    They have one. Claimed they used it. How can it tell? They keep telling me they are balanced fine.
  4. May 2, 2018 at 5:29 PM
    Does your tire have little red or green dots on them?
  5. May 2, 2018 at 5:30 PM
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    Not that I’ve seen. Why?
  6. May 2, 2018 at 5:36 PM
    Because when I have mine road force balanced they always have 1/2" dots on them. I believe it tells them where the heavy spot is on the tire so they can put it on the opposite side of the heavy spot on the rim.
    Backslider likes this.
  7. May 2, 2018 at 5:47 PM
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    Interesting. I don’t recall ever seeing dots.
  8. May 11, 2018 at 6:12 PM
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    Alright, I need help and suggestions.
    I now have replaced the tires and have replaced the wheels. The entire setup is new. I STILL get a wobble in my steering wheel that starts around 55 mph. I don’t get it?
    Could alignment specs cause this?
    Someone mentioned he fixed it with tie rods from Coachbuilder I believe.
    I’m looking for any suggestions. I’m thinking if I bring it to Toyota they are just going to blame it on aftermarket wheels/tires or the 6112 shocks. I’m not sure if I should bring it to someone else to road force?
    Truck has 12,000 miles on it.
  9. May 11, 2018 at 6:18 PM
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    Not sure I have it. I’ll look though.
    Watt maker likes this.
  10. May 11, 2018 at 8:12 PM
    Muleycrazy13
    Muleycrazy13 New Member
    Buckeye, AZ
    2024 Chevy Silverado 2500HD Duramax
    Do
    Do you still have your stock wheels and tires? I would throw them back on and drive it and see if wobble still exists .....
  11. May 11, 2018 at 8:21 PM
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    Sold them. Wish I did though. Thanks for the suggestion.
    Muleycrazy13[QUOTED] likes this.
  12. May 11, 2018 at 8:22 PM
    I don’t think it’s the 6112’s. Does it continue up to around 60 and get any better at higher speeds?
    Who balanced them? Mileage on vehicle?
  13. May 11, 2018 at 8:29 PM
    JBSTOY
    JBSTOY Was tired, so I woke up.
    Jack
    Unknown Origen
    2008 Toyota Tundra SR5 4x4 5.7litres of goodness
    Bilstein 6112s Front Bilstein Rear Fuel Rims
    You might want to go to a different shop and have them rebalanced just to make sure.
  14. May 11, 2018 at 8:32 PM
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    I have my stock set of TRD OR wheels and Michelin tires with less than 5K on them if you wanted to use them to rule out the wheel and tire combo. Let me know, I can load them up and bring them to work with me and drop them by your place.
    Newm, Prostar 190, Ely010606 and 2 others like this.
  15. May 11, 2018 at 8:50 PM
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    You da man! Thanks Jeremy! I’ll let you know.
  16. May 11, 2018 at 8:50 PM
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    I’m thinking I’m going to.
  17. May 11, 2018 at 8:53 PM
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    It seems to start around 55-60 and doesn’t really do it at higher speeds. I don’t notice it much at lower speeds. That speed seems to to be the sweet spot.
    Discount tire balanced. They are the only ones who have touched the tires/wheels.
    Truck has 12,000 on it.
    I’m thinking I should find a reputable place to road force to rule their worn out?
    What else should I look for?
  18. May 11, 2018 at 8:55 PM
    From what I’ve seen, if tires are out of balance then the steering wheel can shake. This shaking starts at around 50-55 mph. It gets worse around 60 mph but starts to get better at high speeds. Sometimes brake rotors can be the cause of shaking.
    I would look at another shop.
    mudslinger79 and BTBAKER[OP] like this.
  19. May 11, 2018 at 9:42 PM
    #49
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    I would not put that past them. I’m going to another shop. thanks for the input. I’ll have them look at that.
  20. May 12, 2018 at 5:07 AM
    #50
    SgtNewundies
    SgtNewundies New Member
    Eric
    You need to drive the truck and allow the tires to break in. Typically it will take a few thousand miles for the tires to settle to where you have less "bounce" because of the aggressive tread.
  21. May 12, 2018 at 6:37 AM
    #51
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    Thank you. I think that makes zero sense and makes zero impact with my issue but I appreciate the response.
    I’ve run ATs for more years than I can remember and never had to break them in to get rid of the “bounce”. Haha
    boostedtrdpro and Prostar 190 like this.
  22. May 12, 2018 at 7:22 AM
    #52
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    I made another appointment at a shop with all the Hunter gear and am going to pay for the Road Force. 80 bucks.
    Plus they are mechanics over there so they may do a quick inspection. I climbed around and can’t see anything out of normal.
    My UCA boot at the spindle on both sides has grease build up on the boots. They are stock UCAs but I can’t see a reason UCA would cause it.
    I’ll report back.
    boostedtrdpro likes this.
  23. May 12, 2018 at 7:24 AM
    #53
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    I’m on it bro. I’ll be looking for those dots.
  24. May 12, 2018 at 7:40 AM
    #54
  25. May 13, 2018 at 5:35 AM
    #55
    SgtNewundies
    Eric
    Look you don't seem to understand what I am saying. You are running a "Hybrid" MT/AT tire it is completely different from from a regular AT. The aggressive tread requires a break in.
  26. May 13, 2018 at 8:30 AM
    #56
    JBSTOY
    Jack
    Unknown Origen
    Because I have suffered similar issues in the past, I’m going to say it is a balancing issue. Since it is a specific area of speed too, I think that the next shop will balance them out. If that turns out to be the case, then I would take the receipt back to the original balancer and have them issue a refund. It sucks though when you spend a crap load of money and the shop can’t get it right.
  27. May 13, 2018 at 8:58 AM
    #57
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    Thanks Jack. I’m thinking you’re right. I hope you’re right! If the next shop gets it dialed in I will be bringing that receipt to them. Appreciate the response.
    JBSTOY[QUOTED] likes this.
  28. May 13, 2018 at 9:02 AM
    #58
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    No, BFG AT2 are not a hybrid. But even so no tire needs a “break in” to remove steering wheel vibration. I’m calling BS on that one. Guys on here are running muds and have indicated they have zero vibration. ANY vibration at the wheel is an indication something is off, PERIOD.
    I’m not arguing with you but I don’t agree with your theory in any way.
    Thank you for trying to help.
    Edit.... you are thinking I’m still running RG which probably is a “hybrid” but I can tell you many owners are running these and have zero issue with vibration. They had no break in period!
  29. May 13, 2018 at 9:10 AM
    #59
    mudslinger79
    mudslinger79 New Member
    Christopher
    Williamsburg, Va
    2006 Double Cab, Phantom Grey Pearl
    Leveled. 16x8 Pacer 164 wrapped in 295-75-16 General AT2. Flowmaster exhaust. K&N Cold air intake.
    I have REALLY aggressive mud terrains on my Xterra. 0 vibration at any speed. I have General AT2 tires on my Tundra. They were a pain to balance. Ended up just static balancing them. Was hesitant at first, but when I put them on the truck and test drove, no vibrations. None. Rides great. Sometimes with the really big tires static balancing is the way to go. What that is is weight is put into one spot on the inside of the rim using sticky weights. It can be a lot of weight, but don't stack the stickies. Evenly distribute them in the area it calls for. I'm on 2500 miles, 0 issues.
  30. May 13, 2018 at 9:14 AM
    #60
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    They have sticky weight stacked. I need to find a reputable shop
