Fuel Tank Capacity
Discussion in '2.5 Gen Tundras (2014-2021)' started by travelertoo2, Mar 19, 2023.
  1. Mar 20, 2023 at 10:40 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    To add to the mix:
    I once read on the TIS the the gas gauge will only update and move position when vehicle speed is 0. So if you are on the highway at cruise it won’t move until you slow down and stop at a stop sign or traffic signal.
    I have never watched my gauge close enough to verify this but I can believe it as road bumps and noise cause the gas to slosh around and make the float be all over the place.
  2. Mar 20, 2023 at 11:03 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    With this trucks stellar gas mileage I can confirm that you can definitely see the gage move down if you drive longer than 30 minutes lol
    Mike59, GODZILLA, T500 and 1 other person like this.
  3. Mar 20, 2023 at 11:27 AM
    2mchfun
    X2 guage moves while in motion regardless of speed or terrain. Have had mine wound up pretty tight for 2-3 hours per stretch between fuel and piss stops.
    GODZILLA likes this.
  4. Mar 20, 2023 at 1:02 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    I've never heard of issues caused by filling up. I HAVE heard of issues caused by topping off, so I stop when the gas pump clicks off. Maybe those issues are related to how many steep hills you have to climb? I have none of those.
  5. Mar 20, 2023 at 1:44 PM
    2mchfun
    The issues associated with topping off, on Tundras exclusively or have you seen it happen with another vehicle? Genuinely curious.
  6. Mar 20, 2023 at 2:03 PM
    Again, type it in a search engine and you'll see plenty.
  7. Mar 20, 2023 at 7:41 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    I have never experienced any fuel system issues on any of my vehicles. I read something that I felt was reliable several years ago about topping off that made me start finishing with the first click off. My mild OCD wanted each fillup to end right on the dollar. Now I consider it full the first time the gas fill is triggered to stop the feed.
    2mchfun[QUOTED] likes this.
  8. Mar 20, 2023 at 10:04 PM
    SD Surfer
    Bruce
    So Cal
    Oh trust me, it updates!
    Hook a big sail to the back of it... you can actually watch the needle move as you drive down the road! :(
    JDR76, 2mchfun and Occidentalis like this.
  9. Mar 21, 2023 at 3:03 AM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    I have plenty of anxiety as it is. I try not to overthink the gas situation.
    I looked under the truck,......there's no 2nd reserve fuel tank.
    While in the city and commuting to work during the week, there's a gas station on every other corner. I drive until I hit roughly a quarter tank, or until the idiot light comes on. Then I plan on getting gas on the way home.
    On road trips, I plan on getting fuel roughly every 300 mi or so. Once the idiot light comes on, I know I have a good 80 mi left, if I want to push on to the next stop. Google maps will help you preplan and find where all your stops are along the way.
    When I fill up, I wait for the click and then slowly top off to the nearest dollar. It's partly OCD and partly a little mini challenge/game. Half the time I go over by a penny.
  10. Mar 21, 2023 at 7:39 AM
    SD Surfer
    Bruce
    So Cal
    I'd be lying if I said I'd never played this game, albeit a bit differently.
    I let it run at full speed, then try to stop it on 77.77, or 88.88, or 51.50, etc. :p
    Mike59 and RichterScale[QUOTED] like this.
  11. Mar 25, 2023 at 7:45 PM
    travelertoo2
    travelertoo2 [OP] New Member
    2020 SR Double Cab
    OK then, this newbie learned I actually do have a 26 gallon tank, but the system is telling me "empty" when there are 6 gals reserve to spare (I don't recall seeing that nugget in the Owners Manual). Sorry for rehashing an old topic, but I do appreciate the responses.
  12. May 8, 2023 at 7:12 AM
    Dragracer_Art
    Dragracer_Art New Member
    Dawsonville, GA
    2020 Crewmax 4x4
    5100's/+2.5" Eibachs, 18x9 +25 Methods,37x12.5 BFG KM3's
    I just filled up this morning. Gas gage showed almost E and 27 miles until empty. It took a little over 31 gallons to fill it and I have a 38 gallon tank.
  13. May 8, 2023 at 11:17 AM
    Scorpion006
    Scorpion006 I'm athletic - I’m known to surf the web for hours
    Austin, TX
    2017 White Tundra 1794
    I don't think it's an option - it's the standard on all crewmax trucks. (Larger 38 Gallon Tank)
  14. May 8, 2023 at 12:52 PM
    Scorpion006
    Austin, TX
    You can drive 50+ miles after it shows 0 (because there is a 6+ gallon reserve)
    Dragracer_Art[QUOTED] likes this.
  15. May 8, 2023 at 2:10 PM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    Add a big headwind into the mix! I have to stop for gas so often with a trailer and wind that the wife never has to request I stop for a bathroom break, sometimes she just stays in the truck because she doesn't even need to go. :(
  16. May 8, 2023 at 2:59 PM
    For a time it was only in trucks with a certain package. Column shift bench seat trucks had the smaller tank, regardless of cab size.
  17. May 8, 2023 at 3:12 PM
    Scorpion006
    Austin, TX
    I mean on all 5.7 - Gen 2.5s (2014+); from what I remember reading it was standard 38 Gallons.
  18. May 8, 2023 at 3:20 PM
    Nope. The tank wasn't added to the Tundra until 2016 or 2017. Prior to that they all had the smaller tank.
  19. May 8, 2023 at 3:23 PM
    #49
    Scorpion006
    Austin, TX
    Maybe my memory is failing me... :(
