Fuel Pump
Discussion in '2.5 Gen Tundras (2014-2021)' started by Gbart42, Nov 11, 2017.
  1. Nov 11, 2017 at 4:49 PM
    Gbart42
    Gbart42 [OP] New Member
    Greg
    2017 Grey Tundra TRD
    I have a 2017 Tundra TRD after the vehicle has been off for several hours I heard the the fuel pump running. I took the gas cap off and there was a lot of pressure built up then the fuel pump immediately turned off and has stayed off? I recently has a tree fall on the bed which did some damage but it is still driveable and nothing underneath the truck seemed to be damaged. Any thoughts?
  2. Nov 11, 2017 at 5:05 PM
    muisejt
    muisejt New Member
    2017 Sunset Bronze 1794 Edition 4x4
    Auburn LSD, TRD rear sway bar, LED interior lights, Weathertech floormats, Fumoto valve
  3. Nov 11, 2017 at 5:08 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    Welcome! let’s see your ride.
  4. Nov 11, 2017 at 5:13 PM
    Gbart42
    Greg
    Thanks for the link. Is it normal to have that much pressure in the fuel tank. I owned a 2011 tundra for 6 years (sold it to my son) and I never heard the fuel pump run like that or noticed that much pressure when removing the gas cap.
  5. Nov 11, 2017 at 5:16 PM
    Gbart42
    Greg
    I will post a picture of the truck after it is fixed. 2 months old and a tree fell on it while I was driving, ripped the tail gait off. Needs an entire new bed. Luckily no doors or anything up front was damaged.
  6. Nov 11, 2017 at 5:34 PM
    muisejt
    muisejt New Member
    it's not the fuel pump, it's an air pump injecting air into the system to check for leaks
  7. Nov 11, 2017 at 7:07 PM
    It’s self testing the evap system. Normal
    Watt maker likes this.
  8. Nov 11, 2017 at 7:09 PM
    Gbart42
    Greg
    how often will the air pump run? I have only noticed it twice since owning it.
  9. Nov 11, 2017 at 8:00 PM
    The test will run on random. Just drive it and relax :)
  10. Nov 11, 2017 at 8:51 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    You sure its a pressure build-up and not vacuum?
  11. Nov 11, 2017 at 9:07 PM
    Yessir. Relax, ejaculate, and drive it
  12. Nov 11, 2017 at 9:11 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    ...who do I report posts to?
    This makes me very uncomfortable....how'd you know whats I was doing? You outside?
  13. Nov 11, 2017 at 9:21 PM
