Fuel Pump Resistor
Discussion in '1st Gen Tundras (2000-2006)' started by remington351, Oct 3, 2019.
  1. Oct 3, 2019 at 7:00 PM
    remington351
    remington351 [OP] New Member
    2006 SR5 DoubleCab
    Long story short, my truck has always had a bog/hesitation from 2100 to 2600 rpm. You could really feel it pulling up a hill at that rpm, more so even in 3rd and 4th gear.
    A couple posts here lead me to the fuel pump resistor, low speed high speed action in fuel pump not working as it should, so when pump is in low speed mode at 2500 rpm, the fuel pressure is slightly weak creating my problem.
    Installed new OEM resistor, hesitation still remained.
    Have unplugged the resistor and put a jumper wire across the terminal so my pump is always in high speed mode and the hesitation has been eliminated.
    My question is has anyone else been running the pump in this mode for thousands of miles or years? I'm curious as I'm planning a couple of winter ski trips and was hoping some of your experience will give me peace of mind. Thanks.
  2. Oct 4, 2019 at 9:49 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I don't have mine bypassed but I wouldn't hesitate to run it that way. The Tundra is the only vehicle I've ever owned that had a resistor in the fuel pump circuit.
    It may shorten the pump life but if you're having issues with pressure I'd guess your pump is worn as it is.
  3. Oct 6, 2019 at 7:58 AM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    agreed, your just juicing it up a bit before it takes a final dump.
  4. Oct 6, 2019 at 12:07 PM
    remington351
    2006 SR5 DoubleCab
    Thanks guys.
  5. Dec 11, 2020 at 4:28 PM
    Filthyphil
    Phil
    Are you still running your resistor jumped? Im experiencing similar problems and have a P0171 code, when you jumped your resistor you just unplugged it and ran a wire to both terminals of the plug?
    FrenchToasty likes this.
