Fuel pump replacement
Discussion in '2.5 Gen Tundras (2014-2021)' started by Guydude67, Mar 5, 2024.
  1. Dec 29, 2024 at 11:38 AM
    #61
    Cyotec6
    Cyotec6 New Member
    Ronald
    Tennessee
    2015 Tundra 1794 crewmax 5.7(flex fuel)
    Remote start Lightbar
    Yes
    And it's flexfuel
  2. Dec 29, 2024 at 9:33 PM
    #62
    lr172
    lr172 New Member
    07 DC
    Just offering a second opinion here. My guess based upon your symptoms is a failing check valve in your fuel pump. Fuel leaks out of system due to bad fuel pump check valve after shut down. On next crank, it takes a while to refill and pressurize, hence the delay before it starts . You even note this in your reply. You have to wait for the pressure to rebuild and as soon as it does, engine runs fine. Pretty much text book symptoms for failed check valve in fuel pump or a leaking injector.
  3. Dec 29, 2024 at 10:15 PM
    #63
    Cyotec6
    Cyotec6 New Member
    Ronald
    Tennessee
    Thanks for the help I will try both out and will give an update as soon as I can im hoping it's the former,for a simple fix...
    I have been smelling i super strong fuel oder when starting lately now that yall mention it.
    koditten likes this.
  4. Dec 29, 2024 at 10:23 PM
    #64
    koditten
    Kirk
    Midland of the Mitten
    That's more like a leaky injector.
    Does it start good during cold starts?
  5. Dec 29, 2024 at 10:33 PM
    #65
    AZBoatHauler
    So.Arizona
    Rich on start up is also an alcohol density issue symptom. It takes way more E85 on a cold start than gas so when it incorrectly reds high ethanol it is really rich when it does finally fire.
    Don’t make this more complicated than it is.
    ToyoMafia likes this.
  6. Dec 30, 2024 at 6:54 AM
    #66
    lr172
    lr172 New Member
    07 DC
    That points more to the ethanol setting problem, as it greatly enriches the fuel delivered during start up.. pump check valve starve the system of fuel during cranking. Leaking injectors also starve the system, but dump the fuel into one cyl. You get one puff of fuel smell followed by long cranking with no smell.
    Definately start with the easy stuff.
  7. Dec 31, 2024 at 7:27 PM
    #67
    Cyotec6
    Cyotec6 New Member
    Ronald
    Tennessee
    Thanks guys it was a high alcohol desinty problem I had a buddy reset the alchahol percentage and the truck starts like new
    AZBoatHauler and ToyoMafia like this.
  8. Dec 31, 2024 at 7:50 PM
    #68
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    100% it is not a part issue. It’s a software f up. Get a computer fix the issue. :fistbump:
    AZBoatHauler[QUOTED] likes this.
  9. Dec 31, 2024 at 7:50 PM
    #69
    ToyoMafia
    Magic carpet.
    Nope
    AZBoatHauler likes this.
  10. Dec 31, 2024 at 8:39 PM
    #70
    lr172
    lr172 New Member
    07 DC
    The original post indicated that the truck would not start until the fuel pressure rose. That matches my response and would be inconsistent with an ethanol percentage problem. Once the op indicated the smell of raw fuel, I suggested it was an ethanol issue. Like i told the other poster, not EVERY crank no start symptom is due to ethanol percentages. Clearly we got bad data with the fuel pressure.
    there was a post the other day with same symptoms. Everyone said it was ethanol, but in fact was a leaking injector. I get that it is a very common problem,but that doesn’t make it the answer to every problem.
  11. Dec 31, 2024 at 11:48 PM
    #71
    AZBoatHauler
    So.Arizona
    Get new injectors too - new fuel pump while you’re at it.
    :spending:
  12. Jan 1, 2025 at 1:15 AM
    #72
    ToyoMafia
    Magic carpet.
    So many pro mechanics round here.
  13. Jan 1, 2025 at 1:18 AM
    #73
    ToyoMafia
    Magic carpet.
    Let me ask this. Why in the world would you start throwing new parts at a problem when a simple reset with a computer could very well fix the issue? Always start small and work ur way up. I get there could be other causes but let’s eliminate the most obvious ones first
    AZBoatHauler and koditten like this.
  14. Jan 2, 2025 at 4:19 AM
    #74
    Sunfish
    Sunfish New Member
    17 4X4 CM Limited
    I recently pulled my 38 Gallon tank and fixed a fuel pump issue on my flex fuel 17. That Donut filter on the pump was stopped up. That switching valve is easy to go around with a non flex supply line and cap off the regulator line. You must leave the switching valve connected electrically. You need the URD Kit to put an external fuel filter in front of the tank. It comes with a pump I chose the DW200. There is a bunch of photos of all this just research Flex fuel threads here on the Forum. It's a fairly hard job for one person but a good helper makes all the difference. My truck is starting with gusto and runs smoother than ever. No CEL
