Fuel pump recall...more Toyotas added to include 18-20 Tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tundra234, Oct 30, 2020.
  1. Oct 30, 2020 at 8:34 AM
    Tundra234 [OP] New Member
  2. Oct 30, 2020 at 9:11 AM
    TundraPJ
    TundraPJ New Member
    JP
    DFW, Texas
    '19 SR5 TRD Off-Road
    Fox TRD Pro Shocks BFG KO2’s Dirty Deeds 14” BAMF n-fab nerf bars
    I’ll check mine in a minute, but I’ve already had mine fixed. I was under the initial recall.
    edit - says no open recalls, system must account for work already done.
    FWIW - this site did show both the fuel pump and blinker recalls before I took the truck into the dealer.
  3. Oct 30, 2020 at 9:14 AM
    Ry24000
    Ry24000 New Member
    Ryan
    Carson, WA
    2019 Tundra SR5 TRD offroad Quicksand
    Debadge, ARE z series top, Ironman Foam cell pro 3" lift, SPC UCA's, ICON vector 5 & Toyo ATIII 285 75R 17, Warn 9.5XP mounted in a Victory Blitz bumper. GTR 1000LM+XTR LP Reverse Light System
    I'm at the dealership as I type this. They told me that I'll get a notification when a solution is in place. Sounds like they don't have a plan yet. Meanwhile I'm getting my blinker lights fixed. They had a recall too.
  4. Oct 30, 2020 at 9:23 AM
    PeakIT
    PeakIT Old Member
    Utah
    2019 OR Tundra Double cab
    Coachbuilder 3” shackles, King extended travel, SPC upper arms, 5:29 gears, FN FX rims,35"tires, leer shell, grill
    I checked my 19s Vin and it does not show it . But it does show the slow front blinker wire recall.
  5. Oct 30, 2020 at 10:06 AM
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    Still no fuel pump recall on my ‘18. Im wondering if they are just gonna recall all of them in stages.
  6. Oct 30, 2020 at 10:19 AM
    :notsure:
  7. Oct 30, 2020 at 10:23 AM
    grandmabetty
    grandmabetty New Member
    MN
    2021 Barcelona Red SX
    Wait they did a recall before they had a solution? Are you saying that dealerships do not have a fix in place yet for the fuel pumps?
  8. Oct 30, 2020 at 10:24 AM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Thought i dodged a bullet when the initial recall came out, but now mine shows up. :annoyed: If you look into the FAQ'S on the recall it says 36,400 more Tundras were added.
  9. Oct 30, 2020 at 10:29 AM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    My 2019 shows up in this new recall. Sucks they don’t have a fix yet.
  10. Oct 30, 2020 at 10:31 AM
    abomb60
    abomb60 Maker of things
    Massachusetts
    2018 Tundra 1794 MGM
    Anyone know if this is flex-fuel only or does it apply to non-FFV as well? Just wondering if mine (non-FFV) might be added at some point as it doesn't show currently ... just the blinker recall.
  11. Oct 30, 2020 at 10:32 AM
    bobvrod
    bobvrod New Member
    Robert
    2019 Blue Tundra double cab
    Yes my 2019 sport is on the recall list by VIN.
  12. Oct 30, 2020 at 10:35 AM
    I'll check my 2020 again in a few days.
  13. Oct 30, 2020 at 10:43 AM
  14. Oct 30, 2020 at 10:45 AM
  15. Oct 30, 2020 at 10:46 AM
    Fearthisbeard
    Fearthisbeard New Member
    Gilbert AZ
    2019 - 1794 TRD Offroad
    My dealer replaced mine at 15K service about a month ago, was completed same day as drop-off
  16. Oct 30, 2020 at 10:47 AM
    CavBluTundra
    CavBluTundra CavBluisdabomb
    Howard
    2018 TRD Off Road Limited
    I checked my vin again today and still no recall, but I previously posted that I was noticing a start issue, mostly on cold starts that was weak. The starter turns over fine, but the motor seems to build into full cylinder detonation before it fully starts. My Uncle is a retired race car builder and a Toyota Master Mechanic and when I told him the symptoms first thing he said was weak fuel pump bleeding off pressure in between overnight starts or a weak pressure module. So I am guessing I will be included in the recall or mine will go out and we will see what happens then.
  17. Oct 30, 2020 at 10:51 AM
    Brandisher
    Brandisher Member
    UT
    2018 MGM Limited CM
    Mine is telling me “no open recalls.” Guess I need to be ready to take it into the dealership in the near future.
  18. Oct 30, 2020 at 10:51 AM
    Clemsonman14
    Clemsonman14 New Member
    2020 SR5 Crewmax 4x2
    Non FFV owner. Mine is not showing up as a recall yet
  19. Oct 30, 2020 at 11:03 AM
    BMET
    BMET New Member
    2018 Tundra Limited
    My 18 is on the list. I had it taken care of last week. Tech said he put in a new one. Non FFV.
  20. Oct 30, 2020 at 11:12 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I was under the impression folks whose vehicles were under the original recall were having the pumps replaced (which involves dropping the whole fuel tank). Maybe they found the replacement pumps are no good either?
    No outstanding recalls on my truck yet.
  21. Oct 30, 2020 at 11:13 AM
    knoxville36
    knoxville36 New Member
    Knoxville, TN
    2024 GMC Sierra 1500 Elevation w/3.0 Duramax
    This recall has been active for basically 10 months. They just added more vehicles to the list on Wednesday is all. All you do is go to your dealer and they will order the new fuel pump to replace the one that is under recall. Take 2 to 4 weeks to get the fuel pumps in for your truck. With all that being said, the pump is in short supply. Dealers do not have these laying around and have to order. Due to COVID and everything going on I am guessing the supplier of these pumps are behind. Probably hard to make a couple million at the drop of the dime.
    Cpl_Punishment likes this.
  22. Oct 30, 2020 at 11:46 AM
    pickeledpigsfeet
    pickeledpigsfeet New Member
    Sierra Foothills, Ca
    2019 Tundra/14 FJ/ 90 SASed xcab
    Kings & Icons
    My 19 does the same exact thing. Even has a big ass agm battery in it now with no change.
  23. Oct 30, 2020 at 1:01 PM
    Chucko2340
    Chucko2340 New Member
    2019 platinum
    3 inch lift, hdx running boards, under cover flex cover, nitto terra grapplers 285/65/20,trd exhaust, trd cold air intake
    I had mine replaced and blinkers addresses as well on Wednesday. Only took the deal two hours for both recalls to be completed.
  24. Oct 30, 2020 at 1:11 PM
    CavBluTundra
    Howard
    Yeah, I disconnected my battery for 15 minutes at the advice of another member to see if the computer would correct the problem. Nothing changed. I'm going with it until it either gets recalled or fails to start.
  25. Oct 30, 2020 at 1:18 PM
    RLHULK
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    Mine show no recalls. 2019 tundra sr5 made 02/2019
  26. Oct 30, 2020 at 1:35 PM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
  27. Oct 30, 2020 at 2:46 PM
    fbingha
    fbingha New Member
    Bakersfield, CA
    Thanks for this, mine being one of the last 2020s built (July 2020), I'm looking good.
  28. Nov 1, 2020 at 6:31 PM
    Ry24000
    Ry24000 New Member
    Ryan
    Carson, WA
    NO. I think they recalled the fuel pump which is in several rigs. They might be starting on other models before tundra? Dealer told me that my pump was in the recall and Ill be notified when I can get the work done. I'm sure they can't do 1,000,000+ vehicles at the same time. Then add Covid and you have a waiting game.
  29. Nov 1, 2020 at 7:36 PM
    TundraPJ
    TundraPJ New Member
    JP
    DFW, Texas
    That’s what they did for mine. I had it fixed about two months ago. Took about a week to get the part in.
  30. Nov 1, 2020 at 8:18 PM
    badmotofing3r
    badmotofing3r To be so civilized, one must tell civil lies
    Zach
    Wyoming
    Hot Tamale
    Toytec lift and the works
    Mines is a '14 that had the recall. It was surging at highway speeds and a few times the truck would not fire when cranking.
    Toyota paid for my Rent-A-Car and needless to say I am willing to bet that was enough motivation to get the fuel pump done quickly.
    The rental for one month was almost 3k.
