Fuel Pump Control Module? Ground side circuit voltage drop
Discussion in '2nd Gen Tundras (2007-2013)' started by z56o2, Mar 11, 2020.
  1. May 1, 2023 at 4:52 PM
    tracrrnd
    tracrrnd New Member
    fred
    2007 tundra xsp 4x4
    NorthTexTundraFan I did all that and everything else from this thread and others. I talked to my buddy who's a certified toyota mechanic today and he told me to just bypass the fpcm.
  2. May 2, 2023 at 11:55 AM
    NorthTexTundraFan
    NorthTexTundraFan New Member
    2007 Double Cab Tundra 2WD 5.7L
    I’m starting to think that’s the only way. I replaced the module and it didn’t fix it. It sounds different when it cranks… makes me wonder if whatever controls this fuel pump control module is simply not telling it to pump fuel, and if my FPCM was never bad in the first place.
  3. May 2, 2023 at 11:56 AM
    NorthTexTundraFan
    Does your buddy say whether or not there is any harm or loss of function / efficiency? I would hate to miss out on this amazing 14 mpg ;)
  4. May 2, 2023 at 5:38 PM
    tracrrnd
    tracrrnd New Member
    fred
    2007 tundra xsp 4x4
    he said it does affect fuel economy. He also said that all the times he's done it there have been no long term affects.
  5. Jun 24, 2023 at 11:21 AM
    Googler
    Googler New Member
    William
    2010 Tundra Double Cab 4.6L
    Cold air intake, bypass secondary air injection system, updated radio and back up cam.
    I am going through the same issue with my 2010 4.6L Double Cab...replaced the fuel pump(which was bad). Replaced the FPCM (which you can only buy as used or from the dealer, I couldn't even find one on Ebay) and now I am getting ECM not connected on my Launch X-431 scanner. Is there a way to easily check the ECM to see if that is the issue. I checked my OBDII pins and they all have drag. All of my fuses and relays are good and battery disconnected for days. When it does the scan it reports on AC, BCM, OD, ABS, TPMS, IMMO, SRS and CM. No ECM. I am taking from this that the CAN bus system is working. Am I missing something really simple or am I to the point where replacing the ECM makes sense?
    Broken-Tundra likes this.
  6. Aug 24, 2023 at 6:57 AM
    itshelly
    itshelly New Member
    Michelle
    So what is the conclusion/solution to this? I am having the same issue 2009 Tundra 5.7 V8 Flex Fuel. Replaced Fuel Pump Driver module and am still having issues. Is the only way to fix this by bypassing the FPDM?
  7. Sep 24, 2023 at 3:58 PM
    Mhenchen44
    Mhenchen44 New Member
    2015 Toyota Tundra
    I’m having similar issues with my 2015 Tundra. Had the fuel pump replaced twice and the fuel pump control module replaced twice. This last time it only ran for 30 miles before failing again. It seems like something on my truck is killing the fuel pump control modules. Does anybody know how I can bypass the fpcm on my 2015 4.6l Tundra? I have the single connector with six wires.
  8. Apr 18, 2025 at 1:30 PM
    Maniak
    Maniak New Member
    Another one here with a no start 2009 Tundra. Pulled the Module and it's quite deteriorated, mechanic assumed this was the immediate problem so I was able to get one from a donor truck, plugged it in and no luck. Apparently my module and the plug at the truck end are showing some signs of burned plastic inside the actual plugs. A friend who is a skilled mechanic said it might be the plugs themselves but I would need to get the truck towed to his garage to better diagnose. Reading that guys checked the fuses and relays, can someone give me direction as to where these are so I can help myself incase it's something simple ? Also this being a 2009 it has the older style module with the two plugs and not the single plug, which is unfortunate because it's a difficult part to find. Really appreciate some help before I go ordering parts that may not be the fix.
  9. Jun 3, 2025 at 2:44 PM
    grayscale
    grayscale New Member
    DFW
    2013 Tundra CM TSS 4X4 5.7FFV
    I think this might be my issue, I'll know for sure in the morning. I have the connectors jumped so we'll see how it goes. If this is it I want to find a permanent solution to eliminate the module.
  10. Jun 4, 2025 at 8:54 AM
    grayscale
    DFW
    Is anyone good with the electrical wiring diagrams? I'm trying to figure out what the 2 smaller wires on the one connector are for
  11. Jun 17, 2025 at 7:46 PM
    jaconrad15
    jaconrad15 New Member
    2016 White Tundra SR5
    2018 OEM LED headlights
    I am having this same issue. Truck won't start, doesn't sound like my fuel pump is working. Either the module or the pump or the wire
    I am having the same issue, came out of nowhere. Debating on throwing in a module or new wire from the module to the pump. Hoping its not a bad pump.
    What did yours end up being?
  12. Jun 17, 2025 at 8:07 PM
    grayscale
    DFW
    Just do the quick bypass (2 wires) then you'll know if that's the problem or not, easy
  13. Jun 17, 2025 at 8:23 PM
    jaconrad15
    I have a two connector module, which wires do I connect?
  14. Jun 18, 2025 at 4:13 AM
    grayscale
    DFW
    Just like in post #48
  15. Jun 18, 2025 at 3:44 PM
    jaconrad15
    Thank you. I'm a little weary of jumping it so I just ordered the module from Toyota. They will let me return it if it doesn't solve my problem.
  16. Jun 18, 2025 at 4:54 PM
    grayscale
    DFW
    Make sure to give it a couple days, sometimes changing something out like that can give false positives at first
    And disconnect your neg battery cable when you do it and leave off for at least 10mins
