Fuel pump continues to run after engine shutoff 2018 Tundra. It was running after 8 hrs
Discussion in 'General Tundra Discussion' started by C Mattox, Jun 29, 2019.
  1. Jun 29, 2019 at 3:53 PM
    C Mattox
    C Mattox [OP] New Member
    2018 Tundra crewmax
    My 2018 Tundra was shutoff more than 8 hrs when I heard the fuel pump still running. I started the engine and turned it off and the fuel pump stopped. ???
  2. Jun 29, 2019 at 4:36 PM
    Blueknights75
    Ron
    Clayton, NC
    Take it back to the dealer...
  3. Jun 29, 2019 at 4:43 PM
    DCB500
    DCB500 New Member
    David
    Oklahoma City
    2019 Tundra SR5 TSS Double Cab
    Wheels, sound system, antenna, tailgate letter inserts, Grill/Hood Bulge, Exhaust, Leather
    I heard the same thing right after I bought my 19’....went out in the garage late one night and heard a noise and definitely was coming from the truck and sound like a fuel pump. Asked the dealer and they said sometimes the computer will run “checks” on things periodically and I have heard it a couple times since then....nothing appears to be affecting with normal operation. It doesn’t stay on but will come on after the truck had been sitting.
  4. Jun 29, 2019 at 5:13 PM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    8 hours is about when it runs the pressure test for emissions iirc
    Ruggybuggy and (deleted member) like this.
  5. Jun 29, 2019 at 5:45 PM
    markg
    markg New Member
    Mark
    NC
    2007 TRD
    Welcome from NC
  6. Jun 29, 2019 at 7:31 PM
    koditten
    koditten New Member
    It's the charcoal canister vacuum pump. It's normal for it to come on add very odd times.
    GODZILLA likes this.
  7. Sep 15, 2020 at 2:16 PM
    djhase
    djhase New Member
    This happen last night to our 19 Tundra. Went out to the garage and heard some buzzing noise. It was coming from back end of the Tundra. The truck had been parked for several hours. I started it and shut it off and it stopped. Have not asked the dealer about it but will tomorrow. Its getting the trailer brake controller update so it stops crying about the trailer not being connected. At least I hope.
  8. Sep 15, 2020 at 2:37 PM
    timsp8
    NY
    Still running, as in 8 hours straight or you just noticed it making a sound 8 hours later? It will come on at random times for emissions bs.
  9. Sep 16, 2020 at 2:31 PM
    djhase
    djhase New Member
    No I don't think it was running for 8 hours. I asked the service tech about it today. Turns out its some kind of emissions thing Toyota vehicles do. Supposedly it only runs for a few minutes. I just happened to go out in the garage when it was running.
    Black@Blue19 likes this.
  10. Sep 16, 2020 at 5:20 PM
    timsp8
    NY
    Mine does that. But the op made it sound like his ran 8 hours straight.
    AggiePhil likes this.
  11. Dec 28, 2021 at 10:42 PM
    Guillaume38
    Guillaume38 New Member
    Guillaume
    Edmonton, AB, CA
    2019 Tundra TRD Sport 4x4 Crew cab
    Nothing. Followed by Toyota Maintenance Agreement.
    Two times heard the fuel pump was running. Two times alarme was off. Car is just off and not closed in the garage. To stop that running, only when I put contact ON then OFF. After I closed vehicle with alarm ON then fuel pump is stopped. I don't know if it can start with vehicle closed with alarm. Also, is that a normal function to have a fuel pump started in my garage without knowing it ?
    Anyway, I need to know if it is a normal function. Tomorrow I will ask the question at Toyota.
    I hope it is not the reason they replaced a lot of fuel pump because this one is running maybe more than expected. I hope also it is not an "obsolescence programed" hidden to replace before 10 years a fuel pump.
    I don't like having something operating when system should be off.
  12. Dec 29, 2021 at 5:22 AM
    Wahayes
    Wahayes Older I get the wiser I realize my dad was
    Will
    2017 tundra limited
    325/60r20 falken at3w, 2.25 dobinsons ,20x9 +20 fuel torque wheels, leer xr100, bmc
    My wife's lexus does that too. Apparently normal. My 2017 tundra doesn't though fwiw. Maybe they added it after that
    Guillaume38 likes this.
  13. Dec 29, 2021 at 7:01 AM
    DCB500
    DCB500 New Member
    David
    Oklahoma City
    its a fuel system check/test. Have walked out into my garage in the middle of the night and heard it running. It’s normal - I have a 2019
    Guillaume38[QUOTED] likes this.
  14. Dec 29, 2021 at 7:48 AM
    blanchard7684
    blanchard7684 New Member
    running fuel pump for 8 hrs straight dead headed is a good leak down test for the injectors.
  15. Dec 29, 2021 at 9:25 AM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    It's an evap test that the vehicle does to check for leaks. Basically there is a little pump that applies a vacuum to the tank and lines then looks for a leak in the system by monitoring how long the vacuum is held. If it fails it's will turn on the check engine light. The test only happens (correct me if I'm wrong on the temp) at 10C or above.
  16. Dec 29, 2021 at 9:40 AM
    Guillaume38
    Guillaume
    Edmonton, AB, CA
    Okay thanks everyone to explain me that function test. Also, the temperature is currently cold in my garage not insulated yet (-6°C) outside (-30°C), today.
  17. Dec 29, 2021 at 10:16 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    It will definitely not do the test at -30c.
