Fuel Mileage on 6" lift Trucks with 35s
Discussion in 'General Tundra Discussion' started by jdud, Mar 13, 2015.
  1. Mar 13, 2015 at 5:31 AM
    jdud
    jdud [OP] New Member
    VERY CURIOUS TO HEAR REALLY FULE ECONOMY ON 6"vs Leveling KIT
    I am looking to get a new Tundra and i am really debating the 6" lift with 35s. I have ran the 2" leveling Kit and 33s any probably averaged around 15mpg. Any help would be appreciated.
    My specs will probably be a 295/60/20 or the 35/12.50/20 Trail grappler or Toyo
  2. Mar 13, 2015 at 7:55 AM
    FunkinTundra
    FunkinTundra New Member
    Cody
    2012 Tundra 5.7 CM
    OME614 full suspension\ Ekstrom design 3" shackles and poly bushing kit\ 295/70r18 Toyo MTs/ +20 offset Fuel Anzas\ 8" BAmuffler....etc...
    Just from what I have seen/read on here or other forums, you are probably looking to be around 11-13 MPG depending on how you drive and assuming you have the 5.7 .
  3. Mar 13, 2015 at 8:01 AM
    T-Rex266 Moderator Staff Member
    Not sure the lift will impact the mileage as much (yes, I'm aware of wind, etc)
    But the tires will have an impact
    On my last truck I had a 3" lift with 35" and was getting around 11-12'ish mixed
    I see you're also wanting 20"
    Wheels....that may add more of a weight difference so it may be 1-2mpg less...just a guess.
    Oh, and welcome to our forum!
  4. Mar 13, 2015 at 11:04 AM
    ausei
    ausei New Member
    Ause
    Baton Rouge, LA
    2011 Spruce Tundra TRD SR5 2WD
    3" Leveling Kit 3.5" Spindle Lift 4" Rear Blocks AirAid Intake 20" XD Monsters w/ Nitto Grapplers 1" wheel spacers for rear Magnaflow Exhaust Pro Comp Shocks for rear
    i have 33 with 20 and 6" lift and i did the lift after the wheels on a 4.6 the biggest thing that killed me were the wheels. im getting 11/12 mpg.
  5. Mar 13, 2015 at 11:25 AM
    chphilo
    chphilo Tundra addict
    Western PA
    From what I understand, city mpg is little affected by the lift itself whereas the highway mpg is. It's has something to do with turbulent flow of air under the truck that affects the efficiency of the truck. If you are concerned with the mpg, stay with 3 inch lift. You could fit 35 inch tires with carefully chosen offset.
    I personally think that around 3 inches is of lift is most efficient (best compromise between ground clearance, stability of the truck, etc.). The off road trucks that race aren't lifted very high for a good reason. If you want a monster truck, that's whole another story.
  6. Mar 13, 2015 at 3:01 PM
    AxelsHumanDad
    AxelsHumanDad Get off my lawn.
    KAIG, NW of The Frozen Tundra
    2015 CM Platinum
    Some suspension tweaks
    2014 Crewmax, 5.7 flexfuel, 7" lift, 35x12.5x20 Trail Grapplers, 5675 miles.
    According to my handy-dandy Excel spreadsheets tracking my fuel, my average is 11.95 with a low of 10.2 and a high of 14.
    That's mixed driving all over northern Wisconsin and to Tennessee and back.
    I have noticed on highway drives I can do a better job keeping it locked up in overdrive by feathering the throttle myself than using cruise.
  7. Mar 13, 2015 at 7:20 PM
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    @AxelsHumanDad do you have any pics? Like to see how the 7"'s of lift looks with 35's compared to my 2.5" with 35's. Maybe I need more!
  8. Mar 13, 2015 at 7:21 PM
    jdud
    Do you have a photo of your truck?
  9. Mar 14, 2015 at 8:53 AM
    jdud
    Thats good numbers. Pretty cool.
  10. Mar 15, 2015 at 10:31 AM
    Great excel sheet!
  11. Mar 15, 2015 at 1:57 PM
    AxelsHumanDad
    2015 CM Platinum
  12. Mar 26, 2015 at 11:34 AM
    bonedog
    bonedog New Member
    salt lake city, ut
    2014 sunburst bronze tundra crewmax limited
    6" lift Trd dual exhaust Fender flares
    Im getting 11.5 with toyo open country II on a 20" wheel. 35x12.5. But i have trd dual exhaust which sounds good with your foot on the gas.
    1_thirsty_tundra and T-Rex266 like this.
