Fuel Mileage After Larger Tires - 3rd Gen
Discussion in '3rd Gen Tundras (2022+)' started by Rwaters, Jan 27, 2022.
  1. Feb 14, 2022 at 1:43 PM
    KroppDuster
    KroppDuster A normal guy trying to survive this crazy world
    Here. There. Everywhere.
    2021 SR5 TRD Off Road - Cavalry Blue
    Bilstein 5100s
    It's not outside the realm of believability. The stock Michelin's are passenger tires ("P"-rated) and not Light Truck tires. I don't know the weight of the OEM Michelin's, but many P-rated tires weigh around 35-41lbs lbs (in that size). That leaves 25-30 lbs for the stock rim. My aftermarket 18x9 rims are 33 lbs, but there are certainly lighter ones out there.
  2. Feb 14, 2022 at 2:26 PM
    ekmason
    ekmason New Member
    2021 Tundra SR5 TRD Off-Road MBM
    2021 TRD OR 18" wheels are 31 just the wheel and 91 wheel and tire
  3. Feb 14, 2022 at 3:03 PM
    gmcguire7220
    gmcguire7220 New Member
    Ontario Canada
    2022 Limited TRD OR Crewmax - WCP- 2019 Toyota RAV4 Hybrid XSE
    TRD running boards & Bridgestone Dueller Ascent tires
    Michelin tire only that’s on the TRD 18 in rim is 37 lbs ( seen on a cpl of tire shop websites)
  4. Feb 14, 2022 at 3:33 PM
    Rwaters
    Rwaters [OP] New Member
    2022 Tundra TRD SR5 Crewmax
    Don’t know what to tell you. I measured it three times and it was 65
  5. Feb 14, 2022 at 3:49 PM
    randomquickness
    randomquickness New Member
    That’s 9 lbs per wheel lighter than the 20” trd wheel with tires. Makes sense though since those aren’t P rated like those michelins. I think anyone upgrading from those 65lb wheels is going to notice some drop in MPG for sure. More so than someone like me going from 74 to 78 lbs.
  6. Feb 14, 2022 at 3:53 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Usually 1mpg is lost for a Lift, Larger tires (2x) and/or heavier bumpers/winches.
    That is 1mpg lost for each of the above...its not a group deal!
  7. Feb 14, 2022 at 3:56 PM
    gmcguire7220
    Ontario Canada
    I believe the Falkens (even as a P rated tire) brand are heavier than Michelins ( can’t recall the weight but 40-45 ish lbs to fit the 18 in rim) - add a slightly larger rim & 20 in vs 18 n tire on that rim…..
  8. Feb 14, 2022 at 4:00 PM
    Rwaters
    I didn’t expect them to be that light. With my new setup I’ve noticed a drop. So far only 1 mpg
  9. Jul 24, 2022 at 5:26 PM
    Mikemikha
    Mikemikha New Member
    2022 Tundra Platinum
    I just upgraded to 35x12.5x18’s and just did a road trip for about 120 miles each way. I got close to 15 mpg. But it looks really cool 73C7E9B8-A83A-4697-A5AD-9EF801B155F1.jpg
    Justinfro, Bneff89, dutch2112 and 6 others like this.
  10. Jul 25, 2022 at 2:47 AM
    SWB Tundra
    SWB Tundra New Member
    T
    Cenral Arkansas
    2024 Tundra Platinum 4x4 CM Hybrid
    You can get weight of tires on Tire Rack website.
  11. Jul 25, 2022 at 5:01 AM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    Been down this road on my Gen 2.5…it’s all about the added weight and rolling resistance (Load range E).
    Pay attention to the tire and wheel weight as compared to stock setup…for example, BFGs (59lbs) are heavier than most…typically an off-road wheel will be heavier than the stock wheel.
    I went with AT IIIs (51lbs) simply due to less weight and stock 18” TRD wheels (31lbs).
    Looks great but…
    Overall, the looks are killer yet it’s also about what you can tolerate when it comes to mileage, stopping, acceleration, ride, etc.
  12. Jul 25, 2022 at 10:03 AM
    nrm91
    nrm91 New Member
    Boise, ID
    2022 Platinum CrewMax Magnetic Grey
    35/11.5/20 Toyo AT III's
    I am looking at getting Toyo A/T IIIs in 35/11.5/R20 to put on the stock rims of my Platinum CrewMax 5.5'. What was your gas mileage before? I am hoping I can have better than 15mpg.
  13. Jul 25, 2022 at 10:10 AM
    Coasty
    Coasty New Member
    Pat
    Oregon
    2022 SRS Crew Max 6.5 4x4
    That would be something to see, the stock tires are pretty thin n light...
  14. Jul 25, 2022 at 12:49 PM
    ToyoMon
    ToyoMon New Member
    2022 White Tundra SR5
    275/70/18 Cooper AT3 XLT (Load E)
    Currently at 14city/19highway.
    Lost about 3mpg according to computer, but worth it.
  15. Jul 25, 2022 at 5:57 PM
    Jkwolfe09
    Jkwolfe09 New Member
    Jerren
    I get about 15.5 with the exact set up you’re asking about. Only difference is I have a 1794.
  16. Jul 25, 2022 at 6:22 PM
    mass-hole
    mass-hole New Member
    Ridiculously light. 275/60R20 on my oem ford wheel was 91.5 lbs.
    Although Tire rack is saying that tire is only 37 lbs which would leave 28 lbs for the wheel, so I guess that could be right.
    Thats like sedan tire light lol
  17. Jul 25, 2022 at 7:46 PM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    Just got back from Boise-Missoula-Flathead Lake- Boise (lots of mountain passes and mostly 2 lane roads so lots of passing) and averaged 21 both ways (taking into account the increased tire size)- pretty dang good if you ask me. Our major highways are 80+ mph and the fuel mileage takes a big hit there
    Henry1jg and rruff like this.
  18. Jul 26, 2022 at 8:45 AM
    nrm91
    nrm91 New Member
    Boise, ID
    Hoping I get close to that. I have been averaging 16.5mpg but almost all city driving. Once I move, hoping the gas mileage goes up....though about to install 35" tires might eat into it :/
  19. Jul 26, 2022 at 1:07 PM
    #49
    Dfrink
    Dfrink New Member
    SR5 CM 4wd
    I put 265 75 18 BFG AT KO2 (range E) on 18x9 aftermarket wheels. I lost a good bit. I'm around 13.5 city and 17 hwy. Not thrilled with that. I tow a travel trailer so I needed the heavy tire. Oh well...
    OnThaLake likes this.
  20. Jul 26, 2022 at 1:11 PM
    #50
    Outbound
    Aaron
    Northern Alberta
    Do you have pics of your truck? I'm looking at the same tire and size, I'd love to see how it looks.
    smallt0wnmoon likes this.
  21. Jul 26, 2022 at 1:22 PM
    #51
    Dfrink
    Dfrink New Member
    SR5 CM 4wd
    Here you go.
    Outbound and ToyoMon like this.
  22. Jul 26, 2022 at 1:45 PM
    #52
    Troa
    Troa I blue it again.......
    Nomad
    2022 Blueprint Limited
    17.5mpg average on 275/65r20 Pirelli Scorpion AT+ (126s load) (Approx 34"x11")
    That's mainly 80mph highway with lots of elevation change and some city driving mixed in
    Dfrink likes this.
  23. Jul 26, 2022 at 1:51 PM
    #53
    ToyoMon
    ToyoMon New Member
    Outbound[QUOTED] likes this.
  24. Jul 26, 2022 at 3:09 PM
    #54
    Outbound
    Aaron
    Northern Alberta
    Thanks. Looks good!
  25. Jul 26, 2022 at 3:10 PM
    #55
    Outbound
    Aaron
    Northern Alberta
    Nice, thanks!
    Dfrink[QUOTED] likes this.
  26. Jul 28, 2022 at 9:08 AM
    #56
    DBWA
    DBWA New Member
    Dave
    2022 Tundra TRD Limited 6.5' Bed
    I'm in western Washington as well and I've been seeing a similar mpg (16.8). I wonder if that just has to do with the hilly terrain more than anything else.
  27. Jul 28, 2022 at 9:39 AM
    #57
    Troa
    Nomad
    I'm in Eastern WA (Spokane) and get around the same. It also could be our watered down E10 fuel. I seem to get better MPG when I fill up in Idaho or Montana.
  28. Jul 28, 2022 at 9:41 AM
    #58
    DBWA
    DBWA New Member
    Dave
    I believe you meant to say "corned down":rofl:
    OnThaLake and Troa[QUOTED] like this.
  29. Jul 29, 2022 at 5:38 PM
    #59
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    Weight is a negligible effect compared to the weight of the whole truck. Rolling resistance is big factor, but unfortunately no one measures truck tires for this... so it's a guess.
  30. Jul 29, 2022 at 7:51 PM
    #60
    DexterL
    DexterL New Member
    No tire and wheel weight make a HUGE difference, especially in getting up to speed. Guaranteed a 60lbs set of wheels and tires (per corner) gets better fuel economy than a 90lbs per corner set
