Fuel leak 09 Tundra
Discussion in '2nd Gen Tundras (2007-2013)' started by Briantman, Mar 9, 2019.
  1. Mar 9, 2019 at 11:59 AM
    Briantman
    Briantman [OP] New Member
    Second gen
    upload_2019-3-9_13-59-1.jpg Gentleman, I need your help. My friend has an 09 Tundra extra cab. Directly under the left rear door on the frame there is something that looks like a pressure regulator leaking fuel. Any ideas? upload_2019-3-9_13-59-1.jpg
  2. Mar 9, 2019 at 1:29 PM
    15whtrd
    15whtrd Mr. Blonde
    I think the fuel pressure regulator is up in the engine compartment. That is something else
  3. Mar 9, 2019 at 1:50 PM
    15whtrd
    15whtrd Mr. Blonde
    After doing a little looking around. It looks like that may be your vapor canister and or vapor canister purge solenoid.
    Slayer likes this.
  4. Mar 9, 2019 at 1:56 PM
    Mwray8909
    Mwray8909 New Member
    Chino Valley
    18 TRD offroad cement CM
    There could be an issue with a clogged injection or fuel rail. That's so you dont blow a seal under the hood if I recall correctly.
  5. Mar 9, 2019 at 2:08 PM
    15whtrd
    15whtrd Mr. Blonde
  6. Mar 9, 2019 at 3:06 PM
    Briantman
    Second gen
    I’m seeing what’s called a fuel tank solenoid valve looks just like it. upload_2019-3-9_17-5-29.jpg
    Anyone ever seen this go bad?
  7. Mar 10, 2019 at 6:24 AM
    Slayer
    Slayer Member
    Slayer
    your such a good man.. always thinking of ways to help
    love your troubleshooting skills
    15whtrd[QUOTED] likes this.
  8. Mar 10, 2019 at 9:17 AM
    15whtrd
    15whtrd Mr. Blonde
    Thanks. I try. Looks like I was wrong this time though haha.
    :cheers:
  9. Dec 24, 2022 at 8:45 AM
    JPA2002
    JPA2002 New Member
    Jon
    2015 Silver Sky Metallic
    4" Toytec lift, TRD Pro grill
    My fuel tank valve solenoid is also leaking. How big of a job is this one?
    thanks
    Jon
  10. Feb 14, 2023 at 12:56 PM
    creektrails
    creektrails New Member
    My solenoid valve is leaking too. How was the fix?
  11. Mar 13, 2023 at 9:10 PM
    jtw
    jtw New Member
    Me three. Anyone have info on replacing this? Does the tank need to be dropped? What does it do?
