Fuel filter location
Discussion in '1st Gen Tundras (2000-2006)' started by Cody06tundra, Nov 2, 2019.
  1. Nov 2, 2019 at 11:08 AM
    Cody06tundra
    Cody06tundra [OP] New Member
    Cody
    2006 Tundra Crew Cab SR5 4.7L
    I have a crew cab 2006 4.7 L rear wheel drive. Does anyone know where the fuel filter is?
  2. Nov 2, 2019 at 11:12 AM
    Professional Hand Model
    Hand Protectors
    The 2002 is under the drivers seat located on the under chassis frame. Try there and report back.
  3. Nov 2, 2019 at 1:17 PM
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    My 2006 access cab 4.7 doesn't have a fuel filter.
  4. Nov 2, 2019 at 3:04 PM
    Hand Protectors
    Hard to find if it isn’t there!
  5. Nov 2, 2019 at 3:29 PM
    Cody06tundra
    Cody
    Yeah trace the lines from the fuel tank up to the engine compartment so I'm assuming there must just be the screen in the fuel tank. If so I'm obviously not going to mess with that. I figure I'll just buy a good quality fuel system cleaner and probably run that in this tank and in the next tank and that should be good enough to get some of the carbon and crap out of there.
  6. Nov 2, 2019 at 4:08 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Don't do it. Take it to a shop. That thing is a pain and I hate it.
  7. Nov 2, 2019 at 4:15 PM
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
    Most fuel filters on toyotas are in the tank and considered a permanent filter with no maintenance required. Not sure on your tundra because I haven’t worked for toyota in a while so double check with the dealer.
  8. Nov 2, 2019 at 4:19 PM
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
  9. Nov 2, 2019 at 4:20 PM
    Hand Protectors
    The 02’ has a little external filter as I described. It also has a ‘sock’ type filter on the pump inside the fuel tank. Double protection, if you will.
  10. Nov 2, 2019 at 4:31 PM
    MOTORHEAD
    MOTORHEAD New Member
    DAVID
    LOS ANGELES CA
    2002 Toyota Tundra SR5 V-8 4.7L WHITE
    RCD 6" SUSPENSION LIFT,ICON EXTENDED FRONT COILOVERS,3" BODY LIFT,CAMBURG UPPER CONTROL ARMS.REAR DISK BRAKE CONVERSION,BIG BRAKE FRONT CONVERSION, AND MANY MORE
    My 2002 sr5 v8 is on drivers side up on the frame rail , it is a metal canister type with metal line going to it use 14 mm line lock wrench to remove
  11. Nov 2, 2019 at 4:54 PM
    because_wumbo-truck
    Jon
    Houston, Texas
    If your looking for a bump in power.and fuel flow, check out dirty deeds industries 270cc 12 hole fuel injectors. Quite a few of us are.running them.
  12. Nov 3, 2019 at 3:57 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    I asked dealer tech about filter the other day and sent him a pic of what I thought was the filter located under driver door. The quote is response....
    My plan when I get back in town is to look into this further by getting better view of part # seen in pic above. I have seen a few utubes of that same object being replaced as a fuel filter.
  13. Nov 3, 2019 at 6:28 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    His response is 100% wrong, it's a fuel filter. The vapor canister on your 04 is located on the passenger side of the fuel tank and looks nothing like that
  14. Nov 3, 2019 at 6:32 AM
    Hand Protectors
    Scary isn’t it? Stealership Guy had the picture with part # and everything!
    I am finding more and more unqualified people working where they shouldn’t. DIY is becoming a necessity these days due to others laziness.
    Edit: Bubbas copied text from stealer response reeks of modern day English Class participation trophy winning.
  15. Nov 3, 2019 at 7:11 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Totally agree and probably good we were texting so he did not hear me say....”You ain’t too suckin fart are ya”....bunch a mumbo jumbo
  16. Nov 3, 2019 at 8:19 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    I don’t know why everyone is so scared to change this filter. Yeah, some fuel gets on you but no more than when you change your own oil.
    Call the dealership back and give them that part number and see what they tell you it is lol. It’s right where everyone says it is and is really easy to change.
  17. Nov 4, 2019 at 2:50 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    It's super easy assuming everything comes apart. Mine started to twist the whole line trying to remove the fitting.
  18. Nov 4, 2019 at 4:26 AM
    BIGUGLY
    Paul
    2018 Limited
    The pic is the fuel filter. They were still being used on 2004 models. Not sure how far forward in years it went. My 04 Sequoia had it where your pic is.
  19. Nov 4, 2019 at 4:32 AM
    MOTORHEAD
    DAVID
    LOS ANGELES CA
    The guy at the dealer parts counter are not mechanics, they usually don’t know anything about auto repair. They just know how to use a computer and look up part numbers,prices, and stuff like that. I have been to the dealer and have asked them question which they have no idea about. Either ask a mechanic or the parts guy at auto parts store, they know more
  20. Nov 4, 2019 at 5:42 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    They switched to plastic fuel tanks in 05 (on the Tundra at least) and dropped the external filter. My understanding is the external filter is necessary to deal with the possible rust from metal tanks to prevent it from plugging injectors.
  21. Nov 4, 2019 at 9:37 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Roman likes this.
  22. Nov 4, 2019 at 9:45 AM
    SouthPaw
    2000 Limited 4x4 AC
    Just pickup a new one at Napa for $8. I just replaced mine a couple of weeks ago using this video as a reference. It's easy to do without the video but it does save time knowing exactly where to go and what size of wrenches to bring.
    https://www.youtube.com/watch?v=drhUO438HOk
  23. Nov 4, 2019 at 10:41 AM
    Cody06tundra
    Cody
  24. Nov 4, 2019 at 11:38 AM
    SouthPaw
    2000 Limited 4x4 AC
    Yup, napa numbers Gold - 3236 and Silver - 23236
  25. Dec 27, 2020 at 8:21 PM
    shootemintheface
    shootemintheface New Member
    01' Tundra V8 Limited New Frame
    What type and thread size are those fittings?
  26. Dec 28, 2020 at 7:31 PM
    SouthPaw
    2000 Limited 4x4 AC
    For the lines?
  27. Dec 29, 2020 at 12:49 PM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    I just looked under my 2006 DC 2wd . . . plastic tank, and no fuel filter between it and the engine compartment. Nothing on the frame rail. Weird.
  28. Dec 29, 2020 at 2:11 PM
    Hand Protectors
    06 has no external filter. Just the sock in the tank.
    abcinv and HBTundra[QUOTED] like this.
  29. Dec 29, 2020 at 3:17 PM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    Thanks . . .'again'.
  30. Dec 30, 2020 at 3:28 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    And apparently not even that. When I Google the part number in the photo I get several Toyota dealer listings for a Tundra fuel filter.
